oasis please? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mxracer201, this thread has received 1 replies and been viewed 548 times.
post #1 of 2 (permalink) Old 04-22-2009, 08:44 PM Thread Starter
oasis please?
VIN: 1FTSW31P53EC05874
Thanks in advance
mxracer201 is offline
post #2 of 2 (permalink) Old 04-23-2009, 01:04 AM
4play's Avatar
OASIS RESULT:
1FTSW31P53EC05874
USA
EN
04/22/2009
21:04:10
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/16/2003 BUILD DATE
01/22/2003 SALE MILEAGE
00010
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
08/26/2008
DEALER: Yankee Ford Sales
WARRANTY CLAIM NUMBER: 278910 ODOMETER: 095675M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6007D D8 FAILED GASKET/SEAL
XO 10W30QSD 007 9838A
INSPECT AND CONFIRM OIL LEAK,CLEAN AND DIO,REPLACE LEAKING ICP SENSOR,REFI LL OIL AND CONFIRM REPAIR
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 1 5K01 040401 * 1007 * N24 42 1561
AWS Claim Key: 2787696 Trx Code: 2 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 04378 - * Name: MILLER FORD, INC. Ph: 207-3244123 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:06-OCT-2003 Doc #:03691901
Cust Comments: CUST STATES THERE IS A THUMPING IN THE VIBRATION
Tech Comments: CHECK FOR VIBRATION AT 35 65 ROTATE TIRES VIBRATION STILL THERE TOOK OFF TIRES AND BALANCE TIRES ROAD TEST WITH CUSTOMER AFTER BALANCE VIBRATION GONE
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 7 2E01 * * * * * * 14775
AWS Claim Key: 5562439 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04378 - * Name: MILLER FORD, INC. Ph: 207-3244123 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2004 Doc #:54194501
Tech Comments: PERFORM 03B05 FSA
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 7 2G05 * * * * * * 14775
AWS Claim Key: 5562441 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04378 - * Name: MILLER FORD, INC. Ph: 207-3244123 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2004 Doc #:64194501
Tech Comments: PERFORM PROGRAM 03B06
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 7 * * * * * * * 14775
AWS Claim Key: 5562440 Trx Code: 03E03 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04378 - * Name: MILLER FORD, INC. Ph: 207-3244123 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2004 Doc #:74194501
Tech Comments: PERFORM REPROGRAM
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 9 1C03 030008 3C3Z 6079 AA L65 D8 18202
AWS Claim Key: 6496313 Trx Code: E84 Labor Hrs: 18.1
Dlr Cd-Sub Cd: 04378 - * Name: MILLER FORD, INC. Ph: 207-3244123 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2004 Doc #:44194501
Cust Comments: CUSTOMER STATES OIL LEKAING AT HEADSTECHNICIAN STATES CHECK COMPRESSION AND EXTERNAL LEAKING
Tech Comments: DIAGNOSE AND REPLACE GASKETS
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 17 7K11 130101 3C3Z 10849 HA G29 42 26529
AWS Claim Key: 9511212 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:31-JAN-2005 Doc #:36226802
Cust Comments: LOW FUEL INDICATOR LIGHT ON BUT THE GAUGE SAYS IT HAS 1 4 OF A TANK
Tech Comments: DIAGNOSED AS CLUSTER REPLACED CLUSTER
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 17 * * * * * * * 26529
AWS Claim Key: 9456586 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:31-JAN-2005 Doc #:36224701
Cust Comments: RECALL 04S15 NEGATIVE BATTERY TERMINAL TO BLOCK CONNECTION
Tech Comments: PERFORMED RECALL, REPLACED NEGATIVE STUD
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 17 2H01 030008 * 6K854 * L65 D1 26529
AWS Claim Key: 9511213 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:31-JAN-2005 Doc #:36226801
Cust Comments: ENGINE OIL LEAK
Tech Comments: STEAM CLEAN AND ADD DYE, TIGHTEN CAC TUBE HOSE CLAMPS
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 17 2E05 100106 3C3Z 9B249 AB G29 42 26540
AWS Claim Key: 9550993 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:04-FEB-2005 Doc #:36290001
Cust Comments: WIF LIGHT WONT SHUT OFF
Tech Comments: DRAIN SEPERATOR, STILL ON, CHANGED FUEL FILTERS ON CUST PAY RO, STILL ON. CHENGED WIF SENSOR, LIGHT OUT, ROADTEST ALL OK.
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 31 * * * * * * * 47411
AWS Claim Key: 13403247 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:20-MAR-2006 Doc #:40693701
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION
AWS Claim Key: 13403246 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:20-MAR-2006 Doc #:40693702
Cust Comments: RECALL DUE 59V01
Tech Comments: RECALL COMPLETED
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 51 2I04 NANANA YC3Z 12B533 AA L65 D1 80619
AWS Claim Key: 15622842 Trx Code: E72 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2007 Doc #:45742902
Cust Comments: C S THAT THE ENGINE IS LEAKING OIL
Tech Comments: LEAKING GLOW PLUG HARNESS STEAM CLEANED ENGINE AND ADDED DYE. INSPECTED FOR LEAKS AND FOUND THE RIGH GLOW PLUG HARNESS LEAKING. UPON DISASSEMBLING FOUND GLOW PLUG CONTROLLER TABS BROKEN. REPLACED THE CONTROLLER AND THE HARNESS. RECHECKED FOR LEAKS AND NONE.
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 51 1H03 030008 4C3Z 9F452 A E29 42 80619
AWS Claim Key: 15622843 Trx Code: E72 Labor Hrs: 1
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2007 Doc #:45742901
Cust Comments: C S THAT THE CHECK ENGINE LIGHT IS ON
Tech Comments: EGR MALFUNCTION3 PERFORMED EEC TESTS CODES P0713, P0404, AND P0505 PERFORMED PIN POINT TESTS AND EGR SELF TESTS EGR FAILED REPLACED EGR. CLEARE
1FTSW31P53EC05874 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 22-JAN-2003 16-SEP-2003 111546 USA 61 2E06 030008 3C3Z 9F838 EA L65 D8 95675
AWS Claim Key: 16167550 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 09035 - * Name: YANKEE FORD SALES Ph: 207-7995591 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:26-AUG-2008 Doc #:27891001
Cust Comments: CUSTOMER STATES VEHICLE IS LEAKING OIL
Tech Comments: INSPECT AND CONFIRM OIL LEAK,CLEAN AND DIO,REPLACE LEAKING ICP SENSOR,REFILL OIL AND CONFIRM REPAIR
4play is offline
