Oasis request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Banshee365, this thread has received 1 replies and been viewed 581 times.
post #1 of 2 (permalink) Old 04-25-2009, 09:58 PM Thread Starter
Oasis request
Buddy is looking at an 05 F-250 with 102k miles. Here's the VIN, I really appreciate it!
1FTSX21P15EA32235
2005 King Ranch F-250 PSD 4x4 Auto
6" Pro-comp stage 1 lift
5" exhaust
Air-raid intake and filter
Eagle 17x10's and 37x12.50's Pro-Comp XTreme M/T's
Banshee365 is offline
post #2 of 2 (permalink) Old 04-27-2009, 02:32 AM
4play's Avatar
OASIS RESULT:
1FTSX21P15EA32235
USA
EN
04/26/2009
22:30:30
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/08/2005 BUILD DATE
08/14/2004 SALE MILEAGE
00010
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/19/2009
DEALER: Matthews-Currie Ford Company
WARRANTY CLAIM NUMBER: 030631 ODOMETER: 096529M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 12B599AARM IDM MOD ASY-FUELINJ 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F2
000 6005F6
000 6005F8
000 6005F11
000 6005F13
000 6005F14
000 6005F18A
000 12650D67
000 12650D47
000 6005F21
VERIFY RUNS ROUGH DIAG NUMEROUS CODES PRESENT PER 08 26 3 CHK BATTERY VOLTS OK MNTR PIDS FND FICM VOLTS DROP BELOW 45 WHEN RPMS WENT UP DROPPED TO 28 RE PLACE FICM ROAD TEST RETEST PASS
01/19/2009
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 12A697AA AIR CHARGE TEMP SENS 001 081103A 42 DOES NOT OPERATE PROPERLY
VC 7B 003 081103B
XT 6QSP 002 081103E
388898S 002 MT6K682
3C3Z 6C683AA FLTER-ENG OIL 001 MT9424
3C3Z 6731AA ELEMENT ASY OIL FILT 001 12650D30
XO 15W40QSD 016
4C3Z 6051EB GASKET CYL HEAD 002
3C3Z 6619AA GASKET (OIL PUMP) 001
3C3Z 6619BA GASKET (OIL PUMP) 001
3C3Z 9N693EA RING-SEALING 001
VC 1 BATTERY ASY 001
ZC 31A MOTORCRAFT BATTERY 001
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001
3C3Z 9A375AA GSKT F/P DISC HOS RE 001
3C3Z 9J469AA SEAL EGR TUBE 001
4C3Z 9P456AF COOLER - EGR 001
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001
VERIFY LOW COOLANT DIAG CODES P0401 P0299 P0275 EGR TEST FAILS REPLACE EGR V LV PER TSB 08 11 3 PRESS TEST DEGAS AND CAP BOTH OK NO EXTERNAL LEAKS APPLY 20" OF VAC FOUND DOESN'T HOLD PRESS REMV EGR COOLER LEAK TEST FAILS REPL EGR COOLER LEAK TEST OIL COOLER OK DRIVE WOT FND PRESS GREATER THAN HOLDING PRE SS TURBO BOOST 29.1 PSI ECT 195 EOT 203 TEST FAN CLUTCH OK REMV HEADS FND HD
12/15/2008
WARRANTY CLAIM NUMBER: 029195 ODOMETER: 095296M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9T289AA KIT-TUB FU/FLTR RTN 001 6005F 42 DOES NOT OPERATE PROPERLY
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 001 6005F1
5C3Z 9A332A HOSE ASY (FUEL HIGH 001 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F13
000 6005F14
000 6005F18A
000 6005F21
000 9527AL
000 12650D47
000 12650D84
VERIFY RUNS ROUGH COLD DIAG CODE P0272 REPROGRAM PERF INJ TEST WEAK CLICK ON INJ 4 PWR BAL SHOWS CYL 4 LOW FUEL PRESS 51 PSI REPL INJ 4 ROAD TEST RETEST PASS
1FTSX21P15EA32235 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 14-AUG-2004 08-APR-2005 124542 USA 14 * * * * * * * 26230
AWS Claim Key: 4552731 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03037 - * Name: ROLLING HILLS FORD, INC. Ph: 352-3946161 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:04-MAY-2006 Doc #:06482841
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: ROAD TEST
AWS Claim Key: 4552732 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03037 - * Name: ROLLING HILLS FORD, INC. Ph: 352-3946161 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:04-MAY-2006 Doc #:06482842
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: INSTALL DEGAS LABEL AND SET COOLANT LEVEL
AWS Claim Key: 4552730 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 03037 - * Name: ROLLING HILLS FORD, INC. Ph: 352-3946161 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:04-MAY-2006 Doc #:06482840
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM A
Tech Comments: PROGRAM ALL MODULES AND REPLACE EBP SENSOR AND EBP CONNECTOR
1FTSX21P15EA32235 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 14-AUG-2004 08-APR-2005 124542 USA 33 1H03 030804 4C3Z 9P456 AF D42 42 81855
AWS Claim Key: 9146059 Trx Code: S07 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 00276 - * Name: DAWSON MOTOR COMPANY, INC. Ph: 229-9952161 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:30-NOV-2007 Doc #:05557401
Cust Comments: LOST POWER. BLOWING WHITE SMOKE.
Tech Comments: RAN TEST, REPLACED COOLER ASSY.
1FTSX21P15EA32235 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 14-AUG-2004 08-APR-2005 124542 USA 33 1B03 030204 3C3Z 6A642 AA D02 42 82130
AWS Claim Key: 9486209 Trx Code: E72 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 08951 - * Name: FORD OF CLERMONT, INC. Ph: 352-3946161 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-DEC-2007 Doc #:01599551
Cust Comments: CUSTOMER STATES BLOWING WHITE AND BLUE SMOKE OUT OF EXHAUST
Tech Comments: ROAD TESTED AND DATTA LOGGER AND FOUND EOT 35 DEGREES HOTTER THAN ECT REPLACED OIL COOLER ASSEMBLY AND REASSEMBLED HAD TO REPLACE FAN SHROUD WAS BROKEN BY PREVIOUS DEALER DRAIN COOLANT AND FLUSH SYSTEM ROAD TESTED AND RETESTED SYSTEM
1FTSX21P15EA32235 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 14-AUG-2004 08-APR-2005 124542 USA 33 2E03 03XXXX * 9E527 * D42 42 82130
AWS Claim Key: 9458317 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08951 - * Name: FORD OF CLERMONT, INC. Ph: 352-3946161 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-DEC-2007 Doc #:01599554
Cust Comments: CUSTOMER STATES HAS ODD ODOR COMMING FROM ENGINE INTO CAB. EGR TUBE WAS REPLACE ABOUT 500 MILES AGO IN ATTEMPT TO CORRECT CONCERN. CUSTOMER THINKS HE HAS A BLOWN HEAD GASKET.
Tech Comments: 070504A .7 2003 2007 F SUPER DUTY, 2003 2005 EXCURSION, 2004 2007 ECONOLINE 350 450 6.0L: REPROGRAM THE FUEL INJECTOR CONTROL MODULE (FICM) (DO NOT USE WITH 12650D, 12650D84)
1FTSX21P15EA32235 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 14-AUG-2004 08-APR-2005 124542 USA 45 2E03 030402 4C3Z 9E527 BRM D41 42 95296
AWS Claim Key: 10658201 Trx Code: S07 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-DEC-2008 Doc #:02919504
Cust Comments: CUSTOMER STATES AT TIMES VEHICLE LOPES, MORE SO WHEN COLD, BLOWS WHITE SMOKE FROM EXHAUST. CUSTOMER HAD REPLACED TURBO WITH FORD REMAN.
Tech Comments: VERIFY RUNS ROUGH COLD DIAG CODE P0272 REPROGRAM PERF INJ TEST WEAK CLICK ON INJ 4 PWR BAL SHOWS CYL 4 LOW FUEL PRESS 51 PSI REPL INJ 4 ROAD TEST RETEST PASS
1FTSX21P15EA32235 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 14-AUG-2004 08-APR-2005 124542 USA 47 2G01 03XXXX 4C3Z 12B599 AARM D13 42 96529
AWS Claim Key: 10748764 Trx Code: S07 Labor Hrs: 3
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2009 Doc #:03063103
Cust Comments: CUSTOMER STATES WHEN COLD VEHICLE RUNS POOR/LOPES/BLOWS WHITE SMOKE.
Tech Comments: VERIFY RUNS ROUGH DIAG NUMEROUS CODES PRESENT PER 08 26 3 CHK BATTERY VOLTS OK MNTR PIDS FND FICM VOLTS DROP BELOW 45 WHEN RPMS WENT UP DROPPED TO 28 REPLACE FICM ROAD TEST RETEST PASS
1FTSX21P15EA32235 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 14-AUG-2004 08-APR-2005 124542 USA 47 1A02 030102 4C3Z 6051 EB L87 42 96529
AWS Claim Key: 10771416 Trx Code: E72 Labor Hrs: 27.1
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2009 Doc #:03063104
Cust Comments: CUSTOMER STATES HAS TO ADD APPROX 1/4 GALLON OF COOLANT TO TRUCK ON A WEEKLY BASIS.
Tech Comments: VERIFY LOW COOLANT DIAG CODES P0401 P0299 P0275 EGR TEST FAILS REPLACE EGR VLV PER TSB 08 11 3 PRESS TEST DEGAS AND CAP BOTH OK NO EXTERNAL LEAKS APPLY 20 OF VAC FOUND DOESN'T HOLD PRESS REMV EGR COOLER LEAK TEST FAILS REPL EGR COOLER LEAK TEST OIL COOLER OK DRIVE WOT FND PRESS GREATER THAN HOLDING PRESS TURBO BOOST 29.1 PSI ECT 195 EOT 203 TEST FAN CLUTCH OK REMV HEADS FND HD GSKTS LEAKING BLOCK
4play is offline
Banshee365 (04-27-2009)
Oasis request. thank you very much calebgriffin31 Ford Oasis requests 2 02-02-2008 11:15 PM
Oasis request jjcar Ford Oasis requests 1 02-02-2008 01:54 AM
Oasis Request - Looking to buy jvargosko Ford Oasis requests 1 08-16-2007 04:38 AM
Oasis Request 91rangerturbo Ford Oasis requests 5 06-21-2007 01:11 PM
OASIS Request please Ohio Eddie Ford Oasis requests 2 06-13-2006 03:36 AM
