Oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sdrowmodnar, this thread has received 1 replies and been viewed 551 times.
post #1 of 2 (permalink) Old 04-28-2009, 06:10 PM Thread Starter
Oasis please
VIN is 1FTSW31P33EB46338
It is a Canadian truck, so hope it works. Thanks in advance!
sdrowmodnar is offline
post #2 of 2 (permalink) Old 04-29-2009, 04:09 AM
4play's Avatar
candadians too here ya go
OASIS RESULT:
1FTSW31P33EB46338
USA
EN
04/29/2009
00:07:24
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/08/2003 BUILD DATE
12/20/2002 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 3 3Y11 070701 YC3Z 7G360 AA P82 42 3630
AWS Claim Key: 894729 Trx Code: 2 Labor Hrs: 3.5
Dlr Cd-Sub Cd: B7236 - * Name: KOKANEE FORD SALES LTD Ph: 250-4282207 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:10-MAR-2003 Doc #:21280501
Cust Comments: WHEN SWITCHED TO 4X4 NOTHING HAPPENS
Tech Comments: 113 025 301 DIAG NO 4X4 CK OASIS AND TSB SSM QUICK TEST NO DTC'S ON DEMAND C1728 NO SWITCH HIGH TO LOW PIN POINT TEST C1 YES C3 NO PROVE OUT SECTI 01 SYSTEM CHART PPT T1 YES T2 YES T3 NO T8 REPLACE MODULE IT IS FAILING DIAGNOSIS BY SYSTEM TRANSFER CASE E1 YES E2 NO E3 YES E10 YES E11 YES E53 YES REPLACE GEAR MOTOR ENCODER ASSEMBLY WORKS GOOD
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 3 2E06 NANANA 3C3Z 9F838 DA D03 42 3630
AWS Claim Key: 904053 Trx Code: S07 Labor Hrs: 3.5
Dlr Cd-Sub Cd: B7236 - * Name: KOKANEE FORD SALES LTD Ph: 250-4282207 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:10-MAR-2003 Doc #:21280502
Cust Comments: CK COLD START SHAKES VIOLENTLY
Tech Comments: 311 324 792 CK FOR ROUGH RUNNING COLD CAME IN HOT UNABLE TO VERIFY QUICK TEST NO DTC'S CK OASIS TSB SSM SSM16670 WDS PID MONITOR ICP SENSOR BAD
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 4 2E01 * * * * * * 5316
AWS Claim Key: 1001632 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B7236 - * Name: KOKANEE FORD SALES LTD Ph: 250-4282207 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:24-APR-2003 Doc #:21317101
Cust Comments: CK FOR LACK OF POWER UP HILLS AND WHEN PASSING
Tech Comments: PERFORM RECALL 03B05 AND RECALL 03B06 AS PER INSTRUCTIONS
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 4 5O88 000615 * NPF * H22 33 5316
AWS Claim Key: 1087346 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: B7236 - * Name: KOKANEE FORD SALES LTD Ph: 250-4282207 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:24-APR-2003 Doc #:21317103
Cust Comments: CK STEERING IS HARD TO HANG ON TO AT HIGHER SPEEDS AND WHEN PASSING
Tech Comments: ROAD TEST UNABLE TO DUPLICATE PROBLEM
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 4 2G05 * * * * * * 5316
AWS Claim Key: 1011939 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B7236 - * Name: KOKANEE FORD SALES LTD Ph: 250-4282207 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:24-APR-2003 Doc #:21317102
Cust Comments: CK SHAKES WHEN STARTING
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 5 2H02 030008 3C3Z 6F089 AA D36 42 6723
AWS Claim Key: 1501015 Trx Code: S07 Labor Hrs: 3.2
Dlr Cd-Sub Cd: B7236 - * Name: KOKANEE FORD SALES LTD Ph: 250-4282207 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:15-MAY-2003 Doc #:21330201
Cust Comments: CUSTOMER STATE IT WILL NOT GO OVER 90K TO PASS
Tech Comments: SSM 16774 FAILED REPLACE VGT SOLENOID REPROGRAM PCM LATEST CALIBRATIONPER SSM 16839 MT EXTRA TIME FOR REPROGRAM TCM MT TIME R & R VAT SOLENOID
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 8 2E06 030008 * 9F838 * D36 42 11461
AWS Claim Key: 2105155 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B7236 - * Name: KOKANEE FORD SALES LTD Ph: 250-4282207 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:13-AUG-2003 Doc #:21404902
Cust Comments: CK ENGINE HISTATES
Tech Comments: CK FOR CODES NONE PER SSM 16839 UPDATE CALIBRATIONS
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 12 2G04 000615 * DIAG * D03 42 18706
AWS Claim Key: 4188704 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: B7236 - * Name: KOKANEE FORD SALES LTD Ph: 250-4282207 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:11-DEC-2003 Doc #:21491802
Cust Comments: CK ROUGH RUNNING COLD
Tech Comments: WDS EEC TSB 03 20 12 UPDATE COMPUTER PROGRAM
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 13 2G01 * * * * * * 21385
AWS Claim Key: 4245961 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: B7236 - * Name: KOKANEE FORD SALES LTD Ph: 250-4282207 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:26-JAN-2004 Doc #:21517402
Cust Comments: RECALL 03L12
Tech Comments: PERFORM RECALL AS PER INSTRUCTIONS
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 16 2G04 000615 * NPF * D03 42 26484
AWS Claim Key: 5666072 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: B7236 - * Name: KOKANEE FORD SALES LTD Ph: 250-4282207 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:26-APR-2004 Doc #:21574402
Cust Comments: CK HARD START ALL THE TIME
Tech Comments: WDS NO CODES CK GLOW PLUGS MODULE CONNECTOR ALL OK
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 26 * * * * * * * 37357
AWS Claim Key: 9440161 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: A7051 - * Name: TOTEM AUTOMOTIVE GROUP FORD LINCOLN SALES & LEASIN Ph: 604-3270431 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:31-JAN-2005 Doc #:153313A
Cust Comments: CERTAIN 03 F SUPER DUTY & EXCURSION VEHICLES EQUIPED WITH 6.0L DIESEL NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION
Tech Comments: COMPLETE RECALLL
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 34 2A01 031202 6C3Z 6C646 AA D50 42 47033
AWS Claim Key: 12638193 Trx Code: E72 Labor Hrs: 1.5
Dlr Cd-Sub Cd: B7196 - * Name: METRO MOTORS LTD Ph: 604-4640271 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:26-SEP-2005 Doc #:277462A
Cust Comments: ATTEND TO TURBO CHARGE AIR HOSE LEAKING
Tech Comments: 75693 TURBO CHARGE TUBE BLOWN OFF. SSM 17288, REPLACE ENTIRE CHARGE TUBE. ALSO BLOWN CHARGE TUBE DAMAGED HOOD INSTULATION, BOTH NEW CHARGE TUBE AND HOOD INSTULATION ON ORDER. CHECKED FOR CODES, NO CODES. TURBO NEEDS TO BE DIA FOR OVER BOOSTING WITH NEW TUBE INSTALLED. TECH 19 REPLACED CHARGE AIR TUBE. DIA FOR TURBO PROBLEMS ( OVER BOOSTING ). REMOVED END CAP FOR VGT OIL
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 40 * * * * * * * 53532
AWS Claim Key: 13608252 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B7196 - * Name: METRO MOTORS LTD Ph: 604-4640271 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:10-APR-2006 Doc #:289125A
Cust Comments: RECALL # 06E17; CONTROL MODULE RE CALIBRATION
Tech Comments: 86152 TECH 15 RECALL 06E17, MODULE RECALIBRATION.
AWS Claim Key: 13608253 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B7196 - * Name: METRO MOTORS LTD Ph: 604-4640271 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:10-APR-2006 Doc #:289125B
Cust Comments: RECALL # 59B01; ASSURANCE TEST DRIVE
Tech Comments: COMPLETED RECALL
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 44 2E06 030008 3C3Z 9F838 EA D21 42 55577
AWS Claim Key: 14518407 Trx Code: E72 Labor Hrs: 2
Dlr Cd-Sub Cd: B7196 - * Name: METRO MOTORS LTD Ph: 604-4640271 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:31-JUL-2006 Doc #:501084A
Cust Comments: ATTEND TO ENGINE STALLING LIGHT WAS ON
Tech Comments: CHECK FOR CAUSE OF CEL ON AND ENGINE STALLING, FOUND CEL NOT ON WHEN IN SHOP, PERFORM PERFORMANCE DIAG AND NEC PINPOINT TESTS NEEDS ICP SENSOR. REPLACE SENSOR
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 44 2E05 100106 6C3Z 9B249 A D50 42 55577
AWS Claim Key: 14522991 Trx Code: E72 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B7196 - * Name: METRO MOTORS LTD Ph: 604-4640271 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:31-JUL-2006 Doc #:501084E
Cust Comments: ATTEND TO WATER IN FUEL LIGHT COMING ON INTERMITTENTLY
Tech Comments: 89443 JOB NOT DONE. WATER DRAIN PLUG ROUNDED. NEW PARTS ON ORDER. REPLACED WATER FUEL SEPERATOR.
1FTSW31P33EB46338 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-DEC-2002 08-JAN-2003 4A7051 CAN 49 2G02 031201 3L3Z 12B579 AB D42 42 60156
AWS Claim Key: 14713878 Trx Code: E72 Labor Hrs: 3.2
Dlr Cd-Sub Cd: B7196 - * Name: METRO MOTORS LTD Ph: 604-4640271 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:19-DEC-2006 Doc #:509073B
Cust Comments: ATTEND TO FLUTTERING SOUND ON FULL THROTTLE AND WHEN LETTING OFF ON DECELL
Tech Comments: 96813 TECH 24 CHECK FOR CAUSE OF FLUTTERING NOISE AND ENGINE SURGE, PERFORM NEC PERFORMANCE DIAG, REPAIRS AS PER TSB 06 22 3, FOUND STILL ENGINE SURGE, CONTINUE PERFORMANCE DIAG, PERFORM PINPOINT TEST RE RE FAULTY EBP SENSOR, FOUND VOLTAGE ONLY GOING AS LOW AS 1.2 1.3 VOLTS, AFTER REMOVAL FOUND VALVE STEM NOT SITTING STRAIGHT ON SEAT AND THEREFORE NOT CLOSING FULLY
4play is offline
