report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by yadaddy99, this thread has received 2 replies and been viewed 627 times.
post #1 of 3 (permalink) Old 04-29-2009, 03:04 AM Thread Starter
report
1FTWW32P53ED05053
please run this when you have the time
thank you
yadaddy99 is offline
post #2 of 3 (permalink) Old 04-29-2009, 04:10 AM
4play's Avatar
OASIS RESULT:
1FTWW32P53ED05053
USA
EN
04/29/2009
00:09:34
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
6 SPEED MANUAL AXLE CODE
F2 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
Click here for CUDL
OTHER WTYS MAY APPLY/REACQUIRED VEH WTY EXP 11-27-2007 DISTANCE 43409
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/17/2003 BUILD DATE
04/25/2003 SALE MILEAGE
00123
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
03/10/2008
DEALER: Ted Russell Ford Lincoln Mercu
WARRANTY CLAIM NUMBER: 609062 ODOMETER: 060932M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9T515A KIT-TUBE TRBCH OIL R 000 070504A 42 DOES NOT OPERATE PROPERLY
3C3Z 6K682CBRM TURBO CHG-EXH DRIVE 000 080407A
4C3Z 12B599AARM IDM MOD ASY-FUELINJ 000 MTDIAG
000 12650D67
PERFORM TSB 07-0504A, TSB 07-16-01A, CALLED HOTLINE VEH STILL HAD ROUGH IDLE , DIESEL DIAG 1-16, REPLACE IDM AND PERFORM PMI ON MODULES RD TEST RETEST
03/10/2008
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 3050DA KIT-FRT SUSP LWR SPD 001 3049AA 33 LOOSE PART
000 3001A
000 3001A1T
1 REPLACE LOWER RIGHT BALL JOINT SPW - SEE ATTACHED RO 94171 AT 49804 MIL ES ON 6-14-07
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 0 2G01 * * * * * * 28
AWS Claim Key: 2449692 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06192 - * Name: TOWN EAST FORD Ph: 972-2706441 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-SEP-2003 Doc #:850501A
Cust Comments: REMOVE & INSTALL EECI LABEL 6.0 SUPER DUTY EXCURSIONS
Tech Comments: INSTALL LABEL
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 1 6A12 011801 * ENTRE * F12 P1 125
AWS Claim Key: 2628238 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 02622 - * Name: SYKORA FAMILY FORD, INC. Ph: 254-8265314 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-SEP-2003 Doc #:07834751
Cust Comments: CHECK FOR RAIL DUST ENVIRO FALLOUT ALL OVER VEHICLE
Tech Comments: RAIL DUST ON VEHICLE PAINT IRON PARTICLE REMOVAL INDUSTRIAL FALLOUT ACID RA
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 5 2E02 030008 3C3Z 9N693 HA D50 D8 5820
AWS Claim Key: 4294177 Trx Code: 2 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 02622 - * Name: SYKORA FAMILY FORD, INC. Ph: 254-8265314 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2004 Doc #:08253051
Cust Comments: CHECK FOR AN OIL LEAK
Tech Comments: 9N963 O RING FAILURE LEAK ENGINE OIL LEAKS DIAGNOSIS
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 9 7V01 080205 1C3Z 11A152 AA N59 42 10014
AWS Claim Key: 6345470 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02622 - * Name: SYKORA FAMILY FORD, INC. Ph: 254-8265314 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2004 Doc #:08693853
Cust Comments: CLUTCH PEDAL IS SQUEAKING
Tech Comments: 11A152 SWITCH INTERNAL DEFECT TIME TO DIAGNOSE AND REPLACE NECESSARY PART.
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 9 4C01 09XXXX F81Z 5260 AA N59 01 10014
AWS Claim Key: 6345469 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02622 - * Name: SYKORA FAMILY FORD, INC. Ph: 254-8265314 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2004 Doc #:08693852
Cust Comments: CHECK FOR RATTLE IN REAR END
Tech Comments: 5260 HANGER BROKEN FAILURE HANGER OR BRACKET EXHAUST SYSTEM REPLACE
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 9 2H02 030008 3C3Z 6F089 AA E29 42 10014
AWS Claim Key: 6681669 Trx Code: S07 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 02622 - * Name: SYKORA FAMILY FORD, INC. Ph: 254-8265314 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2004 Doc #:08693851
Cust Comments: CHECK ENGINE LIGHT IS ON
Tech Comments: 6F089 TURBO ACTUATOR INT. DEFECT ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 10 2H01 030008 3C3Z 6K682 AARM D50 69 10258
AWS Claim Key: 6533170 Trx Code: S07 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 02622 - * Name: SYKORA FAMILY FORD, INC. Ph: 254-8265314 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-JUN-2004 Doc #:08751251
Cust Comments: CHECK FOR NO POWER
Tech Comments: 6K682 TURBO ASSY INTERNAL DEFECT ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 10 1D01 030008 3C3Z 6701 AA D50 D8 10818
AWS Claim Key: 6805853 Trx Code: 2 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 02622 - * Name: SYKORA FAMILY FORD, INC. Ph: 254-8265314 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2004 Doc #:08791351
Cust Comments: CHECK FOR OIL LEAK
Tech Comments: SEAL FAILURE ENGINE OIL LEAKS DIAGNOSIS
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 23 2H01 030008 3C3Z 6K682 AARM D42 41 28300
AWS Claim Key: 11564022 Trx Code: S07 Labor Hrs: 8.3
Dlr Cd-Sub Cd: 02622 - * Name: SYKORA FAMILY FORD, INC. Ph: 254-8265314 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2005 Doc #:00081251
Cust Comments: CHECK FOR LACK OF POWER
Tech Comments: TURBO FAILURE DEFECT ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 24 2G05 031405 * RECAL * D50 79 28654
AWS Claim Key: 11947917 Trx Code: E84 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 02622 - * Name: SYKORA FAMILY FORD, INC. Ph: 254-8265314 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-AUG-2005 Doc #:00148651
Cust Comments: CHECK FOR NO POWER AT LOW END
Tech Comments: RECAL ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 37 6Y20 000001 * MISC * A99 82 30891
AWS Claim Key: 14468222 Trx Code: P86 Labor Hrs: 0
Dlr Cd-Sub Cd: 01706 - * Name: TEXAS MOTORS FORD Ph: *-* St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-SEP-2006 Doc #:01344307
Tech Comments: THIS LINE FOR 100.00 DEDUCT FOR REOAIR ON LINE ONE
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 37 * * * * * * * 30891
AWS Claim Key: 14456254 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02584 - * Name: TEXAS MOTORS FORD Ph: 817-9357000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-SEP-2006 Doc #:01344305
Cust Comments: CAMPAIGNS 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: ROAD TESTED, OTHER CONCERNS PRESENT SEE JOB 1 FOR DIAG AND REPAIRS.
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 37 1A03 030101 * 6009 * N11 14 30891
AWS Claim Key: 14468221 Trx Code: E72 Labor Hrs: 1
Dlr Cd-Sub Cd: 01706 - * Name: TEXAS MOTORS FORD Ph: *-* St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-SEP-2006 Doc #:01344304
Tech Comments: ROAT UNIT FOR 1 HOUR PER RAV
AWS Claim Key: 14456255 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02584 - * Name: TEXAS MOTORS FORD Ph: 817-9357000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-SEP-2006 Doc #:01344306
Cust Comments: CAMPAIGNS 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: REPORGRAMMED WITH THE LATEST CALIBRATIONS.
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 37 7S06 030008 3C3Z 12B637 BA D50 46 30891
AWS Claim Key: 14473341 Trx Code: S07 Labor Hrs: 14.3
Dlr Cd-Sub Cd: 01706 - * Name: TEXAS MOTORS FORD Ph: *-* St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-SEP-2006 Doc #:01344301
Cust Comments: ENGINE LOOSES ALL POWER WHILE DRIVING.
Tech Comments: RUN ALL TEST AND REPLACE ALL DIESEL WIRE HARNESSES THAT WERE SHORTED OUT DUE TO DIESEL FUEL CONTANATION
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 37 2A01 031202 * 6C646 * L65 D1 30891
AWS Claim Key: 14468219 Trx Code: E72 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01706 - * Name: TEXAS MOTORS FORD Ph: *-* St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-SEP-2006 Doc #:01344302
Tech Comments: RESEAL TURBO TUVES TO STOP LEAKING
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 37 6Y20 000079 * RAV * A99 82 30891
AWS Claim Key: 14468220 Trx Code: RAV Labor Hrs: 1
Dlr Cd-Sub Cd: 01706 - * Name: TEXAS MOTORS FORD Ph: *-* St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-SEP-2006 Doc #:01344303
Tech Comments: RAV INSPECTION PER FORD
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 46 2G02 030008 3C3Z 12A690 AA L65 D8 49804
AWS Claim Key: 15289156 Trx Code: E72 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 06856 - * Name: JACK KISSEE FORD, INC. Ph: 918-3410101 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2007 Doc #:09417103
Cust Comments: CUSTOMER STATES HAS OIL LEAKING ON TOP SIDE OF ENGINE CHECK AND ADVISE
Tech Comments: BP 12A690 CC D8 DIAG.OIL LEAK.R AND R DEGAS BOTTLE AND AIR INLET FOR ACCESS. REPLACE LEFT SIDE GLOW PLUG HARNESS.CLEAN OFF RESADUE AND RETEST,CHECKS O.K. QC BY JH 174
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 55 5G03 060302 5C3Z 3050 DA H62 33 60932
AWS Claim Key: 15879205 Trx Code: SPW Labor Hrs: 2.9
Dlr Cd-Sub Cd: 03795 - * Name: TED RUSSELL FORD LINCOLN MERCURY Ph: *-* St:TN Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2008 Doc #:60906202
Cust Comments: C S PREMATURE TIRE WEAR
Tech Comments: 1 REPLACE LOWER RIGHT BALL JOINT SPW SEE ATTACHED RO 94171 AT 49804 MILES ON 6 14 07
1FTWW32P53ED05053 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 25-APR-2003 17-SEP-2003 152473 USA 55 2H01 030407 3C3Z 6K682 CBRM D42 42 60932
AWS Claim Key: 15882588 Trx Code: E72 Labor Hrs: 0
Dlr Cd-Sub Cd: 03795 - * Name: TED RUSSELL FORD LINCOLN MERCURY Ph: *-* St:TN Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2008 Doc #:60906201
Cust Comments: C S INTERMITTENTLY ENGINE SPUTTERS ADVISE
Tech Comments: PERFORM TSB 07 0504A, TSB 07 16 01A, CALLED HOTLINE VEH STILL HAD ROUGH IDLE, DIESEL DIAG 1 16, REPLACE IDM AND PERFORM PMI ON MODULES RD TEST RETEST
4play is offline
post #3 of 3 (permalink) Old 04-29-2009, 12:02 PM Thread Starter
thank you very much
Report Please Bruiser6.0 Ford Oasis requests 1 03-05-2008 12:41 AM
report please outlawcrewcab Ford Oasis requests 1 01-06-2008 01:01 AM
could i please get a report? Stroker03 Ford Oasis requests 2 11-10-2006 01:57 AM
Report Please. Rocky Ford Oasis requests 1 08-23-2006 02:54 AM
Report Please surveyingdawg Ford Oasis requests 1 04-15-2006 05:06 AM
