oasis request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mxracer201, this thread has received 1 replies and been viewed 605 times.
post #1 of 2 (permalink) Old 04-30-2009, 10:59 PM Thread Starter
oasis request
VIN:1FTSW31P34EA97238
thanks again
mxracer201 is offline
post #2 of 2 (permalink) Old 05-01-2009, 06:29 AM
4play's Avatar
OASIS RESULT:
1FTSW31P34EA97238
USA
EN
05/01/2009
02:27:44
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
4F710N0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/31/2004 BUILD DATE
10/09/2003 SALE MILEAGE
00018
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
05/27/2008
DEALER: Wareham Ford, Inc.
WARRANTY CLAIM NUMBER: 150025 ODOMETER: 095740M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001 080407D 42 DOES NOT OPERATE PROPERLY
W302725 001
NGS P0299 P0478 P0528 PIDS MGP EP HIGH FANSS IDLE COLD 240 RPM 28 PSI OVERBO OST FOUND THE TURBO OVERBOOSTING AND BURPING THROUGH THE AIR FILTER UNDER A LOAD R AND R TURBOCHARGER , CLEARED CODES AND ROADTEST AND RETESTED NFP
1FTSW31P34EA97238 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-OCT-2003 31-JAN-2004 111206 USA 7 1H03 030008 3C3Z 9F452 AC E29 41 21259
AWS Claim Key: 1742583 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 08862 - * Name: PORTSMOUTH FORD LINCOLN MERCURY Ph: 603-4331221 St:NH Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-2004 Doc #:384144A
Cust Comments: CUSTOMER STATES THAT THE CHECK ENGINE LIGHT IS ON
Tech Comments: 21259 41 STICKS EEC TESTED P0401 I WENT TO PINPOINT TEST AND FOUND A BAD EGR VALVE I REPLACED THE EGR VALVE CLEARED DTCS AND ROAD TESTED OK
1FTSW31P34EA97238 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-OCT-2003 31-JAN-2004 111206 USA 7 1H03 030804 * 9D475 * E29 42 21259
AWS Claim Key: 1617882 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08989 - * Name: CASCO BAY FORD Ph: 207-8465577 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-2004 Doc #:15279701
Cust Comments: CHK ENGINE LIGHT IS ON BUCKS AT LOW SPEEDS
Tech Comments: ROAD TES BUCKS UNDER LOAD CEL IS ON EEC TEST PO404 EGR VALVE PERFROMANCE FAULT MONITERED PID NEEDS EGR
1FTSW31P34EA97238 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-OCT-2003 31-JAN-2004 111206 USA 7 2E06 100106 3C3Z 9G282 AF N11 42 23826
AWS Claim Key: 2011587 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 08886 - * Name: WHITED FORD Ph: 207-9473673 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:23-AUG-2004 Doc #:103841A
Cust Comments: UNUSUAL ENGINE NOISE AT IDLE
Tech Comments: VERIFIED CONCERN,FOUND THE PUMP ON THE FRAME IS NOISY AND IS CAUSING A LOW POWER ISSUE. HAS 17 PSI BOOST AND HAS NO PRESSURE UNDER LOAD PUT ON THE LIFT AND REMOVED THE PUMP,REPLACED WITH A NEW PUMP AND TESTED FOR LEAKS,TESTED WITH WDS AND HAS 26 PSI BOOST AND GOES FINE VERIFIED REPAIR,CAUSAL PART #9G282 CONDITION CODE 42
1FTSW31P34EA97238 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-OCT-2003 31-JAN-2004 111206 USA 32 * * * * * * * 85825
AWS Claim Key: 10404749 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08961 - * Name: MILLBURY FORD MERCURY Ph: 508-8326261 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2006 Doc #:44087103
Cust Comments: RECALL 05E15
Tech Comments: PERFORM RECALL 05E15
AWS Claim Key: 10404748 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08961 - * Name: MILLBURY FORD MERCURY Ph: 508-8326261 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2006 Doc #:44087104
Cust Comments: 59B01 CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: PERFORM CUSTOMER ASSURANCE TEST DRIVE
AWS Claim Key: 10404750 Trx Code: 05S34 Labor Hrs: 1
Dlr Cd-Sub Cd: 08961 - * Name: MILLBURY FORD MERCURY Ph: 508-8326261 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2006 Doc #:44087102
Cust Comments: RECALL 05S34
Tech Comments: PERFORM RECALL 05S34
1FTSW31P34EA97238 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-OCT-2003 31-JAN-2004 111206 USA 32 1A01 030102 6C3Z 6049 C E23 42 85825
AWS Claim Key: 10414160 Trx Code: E72 Labor Hrs: 22.9
Dlr Cd-Sub Cd: 08961 - * Name: MILLBURY FORD MERCURY Ph: 508-8326261 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2006 Doc #:44087101
Cust Comments: CUST RPORTS VEHICLE HAS NO POWER WHIT SMOKE AND ENGINE OVERH EATED ON HIGHWAY
Tech Comments: VERIFY WHITE SMOKE SMELLED LIKE COOLANT PREASURE TEST SYSTEM REMOVE GLOW PLUGS FOUND COOLANT IN CYLINDERS R R CYLINDER HE ADS REPLACE HEADS AND EGR COOLER RROAD TEST AND RECHECK ENGI NE
1FTSW31P34EA97238 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-OCT-2003 31-JAN-2004 111206 USA 38 1H03 030008 4C3Z 9F452 A D42 55 88981
AWS Claim Key: 11278659 Trx Code: E72 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 03833 - * Name: GILMOUR FORD, INC. Ph: 802-7484444 St:VT Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2007 Doc #:073276E
Cust Comments: CHECK ENGINE LIGHT ON HOOKED UP SCAN TOOL AND CHECKED FOR CODES HAD A CODE PO404 AND
Tech Comments: HOOKED UP SCAN TOOL AND CHECKED FOR CODES HAD A CODE PO404 AND P1335 DIAGNOSED PROBLEM TO THE EGR VALVE REPLACED WITH A NEW VALVE. CLEARED CODES AND ROAD TESTED OK.
1FTSW31P34EA97238 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-OCT-2003 31-JAN-2004 111206 USA 38 2E06 030008 4C3Z 9A543 AARM D02 42 88981
AWS Claim Key: 11272864 Trx Code: E72 Labor Hrs: 9.5
Dlr Cd-Sub Cd: 03833 - * Name: GILMOUR FORD, INC. Ph: 802-7484444 St:VT Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2007 Doc #:073276D
Cust Comments: VEHICLE WILL NOT RUN NOTICED OIL PRESSURE WAS BAD (OIL PRESSURE FIRES INJECTORS)
Tech Comments: NOTICED OIL PRESSURE WAS BAD (OIL PRESSURE FIRES INJECTORS) REMOVED VALVE COVERS AND INTAKE FOUND IPR FULL OF METAL. FOUND OIL PUMP NO GOOD REPLACED WITH A NEW IPR AND PUMP.
1FTSW31P34EA97238 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-OCT-2003 31-JAN-2004 111206 USA 38 1H03 030804 3C3Z 9P456 AE L85 42 88981
AWS Claim Key: 11272863 Trx Code: E72 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03833 - * Name: GILMOUR FORD, INC. Ph: 802-7484444 St:VT Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2007 Doc #:073276B
Cust Comments: CHECK FOR A COOLANT FOUND EGR COOLER LEAKING COOLANT REPLACED WITH A NEW COOLER.
Tech Comments: FOUND EGR COOLER LEAKING COOLANT REPLACED WITH A NEW COOLER.
1FTSW31P34EA97238 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-OCT-2003 31-JAN-2004 111206 USA 40 2H01 030008 3C3Z 6N640 AA E42 D8 90850
AWS Claim Key: 11603688 Trx Code: E72 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09113 - * Name: HARR MOTOR COMPANY, INC. Ph: 508-8525111 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2007 Doc #:318562C
Cust Comments: AFTER VEH STARTED TECH NOTICED HISS NOISE FROM EXHAUST
Tech Comments: 90852 DIAG NISE AT TURBO AREA AS GASKET LEAKING AT RIGHT EXHAUST PIPE TO TURBO ADAPTER ..REMOVE PIPE AND RESEAL ..REPLACE PIPE TO EGR COOLER GASKET AND CLAMP AND REPLACE GASKT TO PIPE TO TURBO ADAPTER ..REASSEMBLE AND RETEST OK
1FTSW31P34EA97238 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-OCT-2003 31-JAN-2004 111206 USA 40 2E03 030402 4C3Z 9E527 AA D02 42 90850
AWS Claim Key: 11603687 Trx Code: E72 Labor Hrs: 5.5
Dlr Cd-Sub Cd: 09113 - * Name: HARR MOTOR COMPANY, INC. Ph: 508-8525111 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2007 Doc #:318562A
Cust Comments: VEH TOWED IN CRANK NO START
Tech Comments: 90852 VERIFIED CUST CONCERN NO START ....GOT RUNNING AND OIS SKIPPING BADLY ..IDS DIAG KOEO P0266 POWERBALANCE SHOWS INJECTORS 1,3,5,7 SKIPPING CHECK FUEL SYSTEM FOR RESTRICTION AND PASSES ...CHECK FOR AIR AND PASSES ..TEST P SI KOEO 10 PSI KOER 10PSI AND FADES FAST REPLACE INJECTORS 1,3,5,7 PASSENGER SIDE AND RE PLACE FUEL PUMP ASSEMBLY ..BLEED SYSTEM AND STA RT AND
1FTSW31P34EA97238 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-OCT-2003 31-JAN-2004 111206 USA 53 2H01 030407 4C3Z 6K682 CBRM E29 42 95740
AWS Claim Key: 12674781 Trx Code: E72 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 09075 - * Name: WAREHAM FORD, INC. Ph: 508-2953643 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:27-MAY-2008 Doc #:150025A
Cust Comments: C S SERVICE ENGINE LITE ON HAS NO POWER MAKES NOISE FROM POSSIBLE TURBO CHECK & ADVISE
Tech Comments: NGS P0299 P0478 P0528 PIDS MGP EP HIGH FANSS IDLE COLD 240 RPM 28 PSI OVERBOOST FOUND THE TURBO OVERBOOSTING AND BURPING THROUGH THE AIR FILTER UNDER A LOAD R AND R TURBOCHARGER , CLEARED CODES AND ROADTEST AND RETESTED NFP
4play is offline
oasis request please strokin8462 Ford Oasis requests 1 11-13-2006 12:46 AM
Oasis Request opie1980 Ford Oasis requests 2 11-11-2006 09:41 PM
Oasis request please efoster_01 Ford Oasis requests 1 11-11-2006 09:21 PM
oasis request opie1980 Ford Oasis requests 0 11-10-2006 04:06 AM
Oasis request Iron Jaw Ford Oasis requests 1 10-20-2006 04:21 PM
