Ford Oasis Request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stangbang91, this thread has received 1 replies and been viewed 1294 times.
post #1 of 2 (permalink) Old 05-01-2009, 05:30 AM Thread Starter
Ford Oasis Request
VIN is as follows 1FTNW21P03EC36912 Thanks for your time.
stangbang91 is offline
post #2 of 2 (permalink) Old 05-01-2009, 06:32 AM
4play's Avatar
OASIS RESULT:
1FTNW21P03EC36912
USA
EN
05/01/2009
02:31:21
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL REGION CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/08/2003 BUILD DATE
02/23/2003 SALE MILEAGE
00327
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 4 2G01 * * * * * * 8456
AWS Claim Key: 2326317 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07175 - * Name: DIERS, INC. Ph: 402-7211471 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2003 Doc #:171168C
Cust Comments: RECALL 03L12
Tech Comments: INSTALL LABEL
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 4 * * * * * * * 8456
AWS Claim Key: 2326318 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07175 - * Name: DIERS, INC. Ph: 402-7211471 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2003 Doc #:171168D
Cust Comments: CHANGE ENGINE OIL AND FILTER ONLY PER CUSTOMERS REQUEST
Tech Comments: CHANGE ENGINE OIL & FILTER PER 57B98
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 4 2G05 * * * * * * 8456
AWS Claim Key: 2326319 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07175 - * Name: DIERS, INC. Ph: 402-7211471 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2003 Doc #:171168A
Cust Comments: RECALL 03B06
Tech Comments: PERFORMED RECALL
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 12 5V01 160201 F81Z 9H465 BA C19 42 24023
AWS Claim Key: 5638542 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 09919 - * Name: GENE STEFFY FORD, LLC Ph: 402-5643218 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:22-APR-2004 Doc #:30263601
Cust Comments: CUSTOMER STATES A/C BLOWS ON DEFROST POSITION ONLY.
Tech Comments: CHECK FOR VACUUM AT RESERVOIR, VACUUM PRESENT, CHECK FOR VACUUM GOING TO HEATER CONTROL, NO VACUUM, DISCONNECT 4WD SOLENOID, A/C WORKS, REPLACED VACUUM SOLENOID FOR 4WD, VERIFY CORRECT A/C OPERATION.
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 12 7P01 110501 4C3Z 13K359 AAA L26 42 24079
AWS Claim Key: 5659461 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09919 - * Name: GENE STEFFY FORD, LLC Ph: 402-5643218 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2004 Doc #:30268901
Cust Comments: CUSTOMER STATES BRAKE LIGHTS ON BOX NOT WORKING, ONLY HIGH MOUNT BRAKE LIGHT WORKS.
Tech Comments: TESTED AND REPLACED MULTI FUNCTION SWITCH. VERIFY REPAIR.
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 18 * * * * * * * 35180
AWS Claim Key: 7916267 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09919 - * Name: GENE STEFFY FORD, LLC Ph: 402-5643218 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:05-OCT-2004 Doc #:30578201
Cust Comments: RECALL 04S15.
Tech Comments: PERFORMED RECALL 04S15.
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 22 2E06 030008 3C3Z 9E527 AE D13 42 47585
AWS Claim Key: 9762413 Trx Code: S07 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 09919 - * Name: GENE STEFFY FORD, LLC Ph: 402-5643218 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2005 Doc #:30817601
Cust Comments: VEHICLE RUNS ROUGH, HAS POOR FUEL MILEAGE, STALLED INTERMITTENTLY WHEN COLD.
Tech Comments: PERFORMED EEC SYSTEM TEST, PERFORMED CYLINDER BALANCE, KOER TESTS, INJECTOR BUZZ TEST, R AND R #1 INJECTOR, RETESTED CYLINDER BALANCE, PASSES. REPROGRAMMED PCM TO FUEL MILEAGE CONCERN. ROAD TEST AND VERIFY REPAIR.
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 28 1H03 030008 * 9F452 * D42 41 60530
AWS Claim Key: 11810395 Trx Code: S07 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 07175 - * Name: DIERS, INC. Ph: 402-7211471 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2005 Doc #:203191A
Cust Comments: CHECK FOR VEHICLE SMOKES REAL BAD OUT OF TAILPIPE ESP BAD WHEN STEP ON ACCEL TO PASS WILL SMOKE BAD ENOUGH THAT CANT SEE BEHIND U DOES NOT SEEM TO HAVE POWER ALSO
Tech Comments: RUN PERFORMANCE DIAGNOSIS PER DIESEL DIAG SHEET. REPLACE STUCK EGR VALVE. REPROGRAM PCM,TCM & FICM PER SSM 17437. RETEST & ROAD TEST. OK.
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 30 2E06 030008 3C3Z 9F838 EA E29 42 63398
AWS Claim Key: 12246054 Trx Code: E72 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 07175 - * Name: DIERS, INC. Ph: 402-7211471 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2005 Doc #:205412A
Cust Comments: CHECK ENGINE LIGHT IS ON AND VEHICLE SEEMS TO SURGE REAL BAD
Tech Comments: RUN PERFORMANCE DIAGNOSIS PER DIESEL DIAG SHEET. REPLACE ICP SENSOR. RETEST AND ROAD TEST. OK.
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 37 * * * * * * * 78084
AWS Claim Key: 13831575 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07175 - * Name: DIERS, INC. Ph: 402-7211471 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:20-MAY-2006 Doc #:214523A
Cust Comments: RECALL 06E17
Tech Comments: RECALIBRATE CONTROL MODULES PER 06E17
AWS Claim Key: 13831576 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07175 - * Name: DIERS, INC. Ph: 402-7211471 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:20-MAY-2006 Doc #:214523D
Cust Comments: 59B01 CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: CUSTOMER ASSURANCE TEST DRIVE
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 43 1H03 030008 * 9F452 * D42 55 85330
AWS Claim Key: 14558143 Trx Code: E72 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 07175 - * Name: DIERS, INC. Ph: 402-7211471 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2006 Doc #:220905A
Cust Comments: CHECK FOR INTERMITTANT RAW FUEL SMELL
Tech Comments: RUN PERFORMANCE DIAGNOSIS PER DIESEL DIAG SHEET, R&I EGR VALVE AND CLEAN, STILL STICKING, REPLACE EGR VALVE PER TSB 06 19 06
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 51 2H02 030008 * 6F089 * D42 42 96040
AWS Claim Key: 15325267 Trx Code: E72 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 07175 - * Name: DIERS, INC. Ph: 402-7211471 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:21-JUN-2007 Doc #:229891A
Cust Comments: CUSTOMER SAID THAT VEHICLE DOES NOT HAVE HARDLY ANY POWER, WHEN TRYING TO PASS ANOTHER VEHICLE HAS NO POWER
Tech Comments: DIAGNOSE AND CLEAN TURBO CHARGER PER TSB 06 23 02
1FTNW21P03EC36912 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2003 08-MAY-2003 153506 USA 51 2H01 030008 3C3Z 6K854 DA D42 42 96114
AWS Claim Key: 15454615 Trx Code: E72 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 07175 - * Name: DIERS, INC. Ph: 402-7211471 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2007 Doc #:230221A
Cust Comments: CHECK FOR VEHICLE HAS LITTLE TO NO POWER WOULD NOT GO ABOVE 20 MPH
Tech Comments: DIESEL PERFORMANCE DIAGNOSIS KOEO, KOER, DATALOGGER DCL DISPLAY, FUEL PRESSURE TEST. PERFORM VGT LEARN PROCEDURE. SMOKE TEST INTAKE AND EXHAUST SYSTEM FOR LEAKS. EXHAUST INLET TO TURBO LEAKING. R&I TURBOCHARGER. REPLACE LEFT AND RIGHT INLET PIPES TO TURBO. REASSEMBLE. POST ROAD TEST. OK.
4play is offline
stangbang91 (05-01-2009)
Ford Oasis Request groceryman Ford Oasis requests 0 01-07-2009 04:24 PM
Oasis request liftruck Ford Oasis requests 1 09-28-2007 08:34 PM
Ford Excursion OASIS request imported_getsum Ford Oasis requests 1 08-03-2007 01:33 PM
Oasis request ava Ford Oasis requests 2 06-22-2007 11:57 AM
Oasis Request 91rangerturbo Ford Oasis requests 5 06-21-2007 01:11 PM
