oasis request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mxracer201, this thread has received 1 replies and been viewed 545 times.
post #1 of 2 (permalink) Old 05-03-2009, 11:49 PM Thread Starter
oasis request
vin...1ftnw21p23eb50453
thanks again
mxracer201 is offline
post #2 of 2 (permalink) Old 05-04-2009, 03:19 AM
4play's Avatar
OASIS RESULT:
1FTNW21P23EB50453
USA
EN
05/03/2009
23:18:02
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
3F710N0A
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/20/2003 BUILD DATE
12/12/2002 SALE MILEAGE
00108
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 3 2E01 * * * * * * 28050
AWS Claim Key: 4286093 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08820 - * Name: VICTORY FORD, INC. Ph: 781-3443500 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2003 Doc #:181993C
Cust Comments: PERFORM OPEN RECALL 03B05
Tech Comments: TECH 85 PERFORMED OPEN RECALL 03B05 REPLACED IC P SENSOR RECALL COMPLETE AT THIS TIME
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 3 * * * * * * * 28050
AWS Claim Key: 4286094 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08820 - * Name: VICTORY FORD, INC. Ph: 781-3443500 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2003 Doc #:181993F
Cust Comments: PERFORM PROGRAM 57B98 FREE MOTORCRAFT OIL CHANGE
Tech Comments: TECH 85 PERFORMED PROGRAM 57B98 CHANGED OIL AND FILTER PROGRAM COMPLETE AT THIS TIME
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 3 2G05 * * * * * * 28050
AWS Claim Key: 4286092 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08820 - * Name: VICTORY FORD, INC. Ph: 781-3443500 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2003 Doc #:181993A
Cust Comments: PERFORM OPEN RECALL 03B06
Tech Comments: TECH 85 PERFORMED OPEN RECALL 03B06 REFLASH PCM FICM AND TCM RECALL COMPLETE AT THIS TIME
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 11 * * * * * * * 29849
AWS Claim Key: 4093866 Trx Code: 03E03 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01856 - * Name: PRIDE FORD OF NORTH ATTLEBORO, INC. Ph: 508-6991111 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:02-JAN-2004 Doc #:32699002
Cust Comments: CUST STATES THAT VEHILCE HAS A IDLE FLUCTUATION CONCERN WHEN COLD AND IDLE WILL KICK UP AFTER ABOUT
Tech Comments: PERFORMED RECALL 03E03 3U7A 12A650 FUC VXAM7NA
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 18 * * * * * * * 25020
AWS Claim Key: 7404227 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08820 - * Name: VICTORY FORD, INC. Ph: 781-3443500 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:12-AUG-2004 Doc #:196747A
Cust Comments: CUST STATES PERFORM RECALL 04S15
Tech Comments: TECH 31 PERFORMED RECALL 04S15 NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 20 2G05 031405 * RECALEM * D36 42 27047
AWS Claim Key: 7795874 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01856 - * Name: PRIDE FORD OF NORTH ATTLEBORO, INC. Ph: 508-6991111 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2004 Doc #:36051201
Cust Comments: CUST STATES THAT WHEN VEHICLE COMES TO A STOP VEHICLE SEEMS TO SURGE AT A IDLE...
Tech Comments: PERFORMED SELF TEST WITH WDS AND SYSTEM PASSED.FOUND LATER CALIBRATION FOR PCM FOR SURGEING REPROGRAMMED PCM WITH LATER CALIBRATION 3U7A 12A650 FUD FILE NAME VXAM7NW
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 22 7J05 130201 * 9E731 * L65 D8 31935
AWS Claim Key: 8791909 Trx Code: S07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01856 - * Name: PRIDE FORD OF NORTH ATTLEBORO, INC. Ph: 508-6991111 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:08-DEC-2004 Doc #:36897302
Cust Comments: CUST STATES FINDING OIL IN DRIVEWAY
Tech Comments: UNDERBODY INSPECTION AND OIL LEAK DIAGNOSIS SHOWED OIL LEAKING FROM VEHICLE SPEED SENSOR. REMOVED SPEED SENSOR REPLACED O RINGS ON SPEED SENSOR
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 23 2G05 031405 * RECALEM * D03 42 33129
AWS Claim Key: 9028799 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01856 - * Name: PRIDE FORD OF NORTH ATTLEBORO, INC. Ph: 508-6991111 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2004 Doc #:37104402
Cust Comments: CUST STATES THAT VEH HAS A HARD TIME COLD STARTING AND WHEN STARTING UP BLUE BLACK COLOR SMOKE AND RUNS ROUGH
Tech Comments: PERFORMED SELF TEST WITH WDS AND RETRIEVED NO CODES,RAN OASIS AND FOUND SSM 17437 FOLLOWED SSM AND REPROGRAMMED 3U7A 12A650 FUE RECOMMEND CUSTOMER TO FOLLOW SSM 18147 AND VERIFY FUEL
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 39 * * * * * * * 52111
AWS Claim Key: 13624479 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08820 - * Name: VICTORY FORD, INC. Ph: 781-3443500 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2006 Doc #:215058B
Cust Comments: CUST STATES PERFORM RECALL 59B01
Tech Comments: TECH 85 PERFORMED PROGRAM 59B01, ROAD TEST
AWS Claim Key: 13624478 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08820 - * Name: VICTORY FORD, INC. Ph: 781-3443500 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2006 Doc #:215058A
Cust Comments: CUST STATES PERFORM RECALL 06E17
Tech Comments: TECH 53 PERFORMED RECALL 06E17 CONTROL MODULE R ECALIBRATION
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 46 2E02 030408 3C3Z 9N693 HA L65 D8 63618
AWS Claim Key: 14620043 Trx Code: E72 Labor Hrs: 1
Dlr Cd-Sub Cd: 08820 - * Name: VICTORY FORD, INC. Ph: 781-3443500 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:13-NOV-2006 Doc #:220652A
Cust Comments: CUST STATES LEAK FROM VEHICLE
Tech Comments: VERIFY CONCERN, TECH 9 ADDED OIL DYE TO SYSTEM, PERFORMED DYE TEST FOUND CAMSHAFT SENSOR ORING S LEAKING, R & R CAMSHAFT SENSORS, REPLACED BOT H ORINGS, RECHECK
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 47 2E05 100106 6C3Z 9B249 A G29 49 65610
AWS Claim Key: 14751130 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07650 - * Name: BAYSTATE FORD, INC. Ph: 781-3443500 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:13-DEC-2006 Doc #:500119A
Cust Comments: CUST STATES WATER IN FUEL LIGHT ON
Tech Comments: VERIFY CONCERN, TECH 85 RAN TESTS WITH IDS, KOE O PASS CONT P2269 TSB 6 22 12 ATTEMPT TO REMOVE DRAIN PLUG, FROZEN, REMOVE MANIFOLD WIF SENSOR TERMINALS CORRODED SEDIMENT IN HOUSING CLEAN O UT INSTALL NEW MANIFOLD COVER HOUSING, INSTALL UPDATED HARNESS REPROGRAM MODULES, RECHECK
1FTNW21P23EB50453 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 12-DEC-2002 20-FEB-2003 111061 USA 55 1H03 030008 4C3Z 9F452 A D50 55 75450
AWS Claim Key: 15434006 Trx Code: E72 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 07650 - * Name: BAYSTATE FORD, INC. Ph: 781-3443500 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:07-AUG-2007 Doc #:505840C
Cust Comments: CUSTOMER STATES BLOWING BLACK SMOKE 3RD AND 5TH GEAR WHEN ACCELERATING AND ENGINE WARMED UP
Tech Comments: 75450 FAULTY EGR VALVE TECH ROAD TESTED AND VERIFIED CUSTOMER CONCERN FOR BLACK SMOKE,PERFORMED SELF TEST AND CODE P0401. PER TSB 06 19 06 TECH PERFORMED TEST ON EGR AND TEST FAILED. CLEANED EGR AND RETESTED AND STILL FAILED,REMOVED AND REPLACED EGR THEN CLEARED CODES AND RETESTED OK,COMPLETED REPAIR
4play is offline
Yet Another Oasis Request fords4life Ford Oasis requests 1 08-16-2007 04:37 AM
Oasis Request Please jayman69 Ford Oasis requests 3 08-03-2007 01:40 PM
oasis request please 99stroke Ford Oasis requests 2 12-28-2006 12:23 AM
Oasis Request Please Bluemonster Ford Oasis requests 1 07-14-2006 09:06 AM
Oasis Request jrh1 Ford Oasis requests 1 07-06-2006 11:17 AM
