request please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by yadaddy99, this thread has received 1 replies and been viewed 635 times.
post #1 of 2 (permalink) Old 05-05-2009, 03:12 AM Thread Starter
request please
1FTWW33P65EA73967 I would really apperciate you looking this up for me.
thank you
yadaddy99 is offline
post #2 of 2 (permalink) Old 05-05-2009, 08:59 PM
4play's Avatar
OASIS RESULT:
1FTWW33P65EA73967
USA
EN
05/05/2009
16:58:43
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4N ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/16/2004 BUILD DATE
09/24/2004 SALE MILEAGE
00042
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/21/2009
DEALER: Crossville Ford-Lincoln-Mercur
WARRANTY CLAIM NUMBER: 037380 ODOMETER: 061035M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 12B599AARM IDM MOD ASY-FUELINJ 001 6005E 42 DOES NOT OPERATE PROPERLY
000 6005E2
000 6005E45
000 12650D67
DIAGNOSE NO START AT TIMES TEST AND REPLACE FICM
1FTWW33P65EA73967 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-SEP-2004 16-OCT-2004 123348 USA 16 * * * * * * * 28218
AWS Claim Key: 3376101 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 05645 - * Name: HERITAGE FORD-LINCOLN-MERCURY, INC. Ph: 931-5263325 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:01-FEB-2006 Doc #:06070801
Cust Comments: RECALL 05E15
Tech Comments: PERFORMED RECALL 05E15M
AWS Claim Key: 3376100 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05645 - * Name: HERITAGE FORD-LINCOLN-MERCURY, INC. Ph: 931-5263325 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:01-FEB-2006 Doc #:06070802
Cust Comments: RECALL 59B01
Tech Comments: PERFORMED RECALL 59B01A
1FTWW33P65EA73967 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-SEP-2004 16-OCT-2004 123348 USA 25 * * * * * * * 38561
AWS Claim Key: 6236674 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05645 - * Name: HERITAGE FORD-LINCOLN-MERCURY, INC. Ph: 931-5263325 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2006 Doc #:06932902
Cust Comments: RECALL 05B32
Tech Comments: PREFORMED RECALL 05B32B
1FTWW33P65EA73967 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-SEP-2004 16-OCT-2004 123348 USA 25 1A02 030102 * 6051 * L87 D8 38561
AWS Claim Key: 6236675 Trx Code: E72 Labor Hrs: 14.8
Dlr Cd-Sub Cd: 05645 - * Name: HERITAGE FORD-LINCOLN-MERCURY, INC. Ph: 931-5263325 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2006 Doc #:06932901
Cust Comments: CUST STATES COOLANT LEAKING PUTTING PRESSURE IN RADIATOR
Tech Comments: ROAD TEST TO VERIFY CONCERN. PRESSURE TEST SYSTEM, MONITOR PIDS, TEST THERMOSTAT AND WATER PUMP CIRCULATION. FOUND HEADGASKETS LEAKING COMBUSTION PRESSURE INTO COOLING SYS. REPLACE BOTH HEADGASKETS, REPL EGR COOLER, CHANGE OIL AND FILTER. REFILL COOLING SYSTEM AND RE TEST.
1FTWW33P65EA73967 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-SEP-2004 16-OCT-2004 123348 USA 28 2E03 030008 * 9E527 * D50 42 41449
AWS Claim Key: 6875773 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 05645 - * Name: HERITAGE FORD-LINCOLN-MERCURY, INC. Ph: 931-5263325 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2007 Doc #:07178901
Cust Comments: CUST STATES HARD TO START, IDLES ROUGH COLD
Tech Comments: REPROGRAM FICM PER TSB 06 22 3
1FTWW33P65EA73967 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-SEP-2004 16-OCT-2004 123348 USA 42 6Y20 000000 * TAP5 * A99 82 57682
AWS Claim Key: 9616608 Trx Code: TAP5 Labor Hrs: 0
Dlr Cd-Sub Cd: 05645 - * Name: HERITAGE FORD-LINCOLN-MERCURY, INC. Ph: 931-5263325 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:28-FEB-2008 Doc #:14734401
Tech Comments: ONE DAY TAP VEHICLE PROVIDED
1FTWW33P65EA73967 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-SEP-2004 16-OCT-2004 123348 USA 52 2G01 03XXXX 4C3Z 12B599 AARM D02 42 61035
AWS Claim Key: 10718763 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 05650 - * Name: CROSSVILLE FORD-LINCOLN-MERCURY, INC. Ph: 931-4845135 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2009 Doc #:037380A
Cust Comments: CHECK NO START AT TIMES
Tech Comments: DIAGNOSE NO START AT TIMES TEST AND REPLACE FICM
4play is offline
04 6.0 request please Ofc. Garcia Ford Oasis requests 1 02-23-2009 04:57 AM
pic request blackpsd 5.9L Cummins (1998.5-2002) 3 02-28-2008 11:41 PM
Request Please Inthesticks Ford Oasis requests 1 01-30-2008 12:32 AM
request. Rcannon Ford Oasis requests 1 10-23-2007 01:31 AM
Request If Possible UpstateDieselGuy Ford Oasis requests 2 04-11-2007 03:23 AM
