oasis request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mxracer201, this thread has received 1 replies and been viewed 931 times.
post #1 of 2 (permalink) Old 05-05-2009, 08:51 PM Thread Starter
oasis request
VIN:1FTSW21P35EB18620
Thanks again sorry for so many just tryin to line up a couple to look at for the weekend
mxracer201 is offline
post #2 of 2 (permalink) Old 05-05-2009, 09:00 PM
4play's Avatar
OASIS RESULT:
1FTSW21P35EB18620
USA
EN
05/05/2009
17:00:12
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
5F710N0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL REGION CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/25/2005 BUILD DATE
10/27/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
11/03/2008
DEALER: Lamoureux Ford, Inc.
WARRANTY CLAIM NUMBER: 038867 ODOMETER: 099280M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9C968CA FUEL PRESSURE REG 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F11
000 6005F13
000 6005F14
000 6005F18B
000 6005F2
000 6005F22
000 6005F39
000 6005F45
000 6005F6
000 6005F1X1
000 12650D81
000 9968B
FAST IDLE ENGAGES WHILE IN DRIVE. IDLES ROUGH WHEN STARTED COLD. CUSTOMER HA S TO RE-START TO CLEAN OUT. SEE ATTACHED NOTE IDS TEST-NO CODES. IDS DATA LO GGER-TOO LONG. TEST DRIVES-NO PROBLEM FOUND. LET SIT OVERNIGHT AND TRIED COL D START. COULD NOT VERIFY. EEC TEST P2284-ICP CIRCUIT/PERFORMANCE. PERFORMED PINPOINT TEST. CHECKED OIL-ADDED 1-1/2QTS. MONITORED PID DATA AND ROAD TEST
09/23/2008
DEALER: Harr Motor Company, Inc.
WARRANTY CLAIM NUMBER: 339379 ODOMETER: 097455M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6049DA CYLINDER HEAD 002 081103A 42 DOES NOT OPERATE PROPERLY
3C3Z 6A642AA COOLER CRANKCASE OI 001 081103B
3C3Z 6C683AA FLTER-ENG OIL 001 081103E
6C3Z 8A080B COOLANT O/FLO BOTTLE 001
F6DZ 8100A CAP ASY RADIATOR 001
3C3Z 9433BE GASKET SET-MANIFOLD 001
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 015
VC 7B 003
3C3Z 8575AA THERMOSTAT 001
3C3Z 9229AA GASKET CARB FUEL INL 008
6C3Z 9448A GSKT EXH MNFLD TO CY 002
W300013 004
W300051 004
W302193 002
3C3Z 9229AA GASKET CARB FUEL INL 001
W301386 002
W301390 002
W300006 002
W302725 001
8C3Z 6565B ROD PUSH 001
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 001
W301383 002
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001
6051 GASKET CYL HEAD 000
97455 VERIFIED CONCERN OF CONSUMING COOLANT- COOLANT LEVEL WAS LOW AND NO EX TERNAL LEAKS COULD BE FOUND.PERFORMED TSB 08-11-3 FOR COOLANT LOSS.PERFORME D TEST ON CAP AND WAS LETTING GO AT 11 PSI,THEN TESTED THE DEGAS BOTTLE AND FOUND THAT IT WAS LEAKING FROM TOP,REPLACED DEGAS BOTTLE AND CAP.PERFORME D COOLENT PRESSURE TEST AND FOUND WAS LEAKING DOWN STILL,FAILED RADKIT
09/23/2008
LABOR OP
CONDITION CODE
CONDITION DESC
TAP1 MISC 000 82 FREIGHT/POSTAGE/MAINTENANCE
TAP DAY RENTAL
1FTSW21P35EB18620 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-OCT-2004 25-FEB-2005 111470 USA 4 7T03 050300 5C3Z 2C204 BA H19 42 6900
AWS Claim Key: 1056983 Trx Code: 2 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09100 - * Name: MATHIEU FORD SALES, INC. Ph: 978-2970001 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:31-MAY-2005 Doc #:06916301
Cust Comments: CUST STATES ABS LIGHT IS ON
Tech Comments: INSPECT ABS LIGHT BCE TEST CODE B1233 LEFT FRONT SPEED SENSOR PINPOINT TEST DATA LOGGER SENSOR DEFECTIVE,REMOVED AND REPLACED LEFT FRONT WHEEL SPEED SENSOR.CLEAR CODE AND RETEST OK.
1FTSW21P35EB18620 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-OCT-2004 25-FEB-2005 111470 USA 12 * * * * * * * 28114
AWS Claim Key: 3401833 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09100 - * Name: MATHIEU FORD SALES, INC. Ph: 978-2970001 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2006 Doc #:07317402
Cust Comments: RECALL 05B32
Tech Comments: INSTALL DEGAS BOTTLE LABEL
AWS Claim Key: 3401832 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 09100 - * Name: MATHIEU FORD SALES, INC. Ph: 978-2970001 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2006 Doc #:07317401
Cust Comments: RECALL 05E15,EBP SENSOR,RECAL
Tech Comments: INSTALL EBP SENSOR REPROGRAM FICM,PCM,TCM
1FTSW21P35EB18620 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-OCT-2004 25-FEB-2005 111470 USA 12 1H03 030008 5C3Z 9F452 AA E29 42 28340
AWS Claim Key: 3555076 Trx Code: S07 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 09100 - * Name: MATHIEU FORD SALES, INC. Ph: 978-2970001 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2006 Doc #:07332301
Cust Comments: CUSTOMER STATES VEHICLE LOST POWER SMOKE FROM EXHAUST NOW MIL LIGHT IS ON
Tech Comments: WDS TEST. PINPOINT CODE P0404, EGR VALVE POSITION CONTROL PERFORMANCE. FOUND EGR VALVE BAD. REMOVE AND REPLACE VALVE. RETEST, OK.
1FTSW21P35EB18620 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-OCT-2004 25-FEB-2005 111470 USA 14 2H01 030008 5C3Z 6K682 CA D36 42 32699
AWS Claim Key: 4340455 Trx Code: S07 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 02735 - * Name: ATHOL FORD AND MERCURY Ph: 978-2493531 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:06-APR-2006 Doc #:059012A
Cust Comments: HAD DIESEL EMISSIONS RECALL DONE NOW VEH HAS NO POWER
Tech Comments: 32699 STICKING TURBO AND WEAK FUEL PUMP 6005F F1 F1X1 F11 F12 F13 F14 F18 F25 9438A AZW 9438 A2 9350E 7.2 I ROAD TESTED VEHICLE HAS LACK OF POWER I PREFORMED DIESEL ENGINE PREFORMANCE DIAG EEC TEST PO299 FROFORM KOEO PASS I PREFORMED BOOST PRESSURE TEST LOW 16 PSI I PREFORMED FUEL CONTAMINATION TEST PASS INLET RESTRICTION TEST PASS FUEL PUMP PRESSURE TEST LOW 50 PSI I
1FTSW21P35EB18620 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-OCT-2004 25-FEB-2005 111470 USA 22 * * * * * * * 52221
AWS Claim Key: 6584838 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02735 - * Name: ATHOL FORD AND MERCURY Ph: 978-2493531 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:07-DEC-2006 Doc #:063553B
Cust Comments: 59B01 TEST DRIVE
Tech Comments: 52221 59B01A .3 CUSTOMER ASSURANCE ROAD TEST
1FTSW21P35EB18620 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-OCT-2004 25-FEB-2005 111470 USA 36 7S02 180102 * 14401 * A99 82 84312
AWS Claim Key: 9429848 Trx Code: P98 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 02735 - * Name: ATHOL FORD AND MERCURY Ph: 978-2493531 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:31-JAN-2008 Doc #:070763A
Cust Comments: TRANNY STILL NOT WORKING RIGHT SEE BRANDON
Tech Comments: 84312 CHAFFED WIRE ON LEFT SPRING TOWER CIRCUIT 1876 YE WH 7000F,F2,7191A,AZG, 14200A,A1 TOTAL 3.3 CONFIRM THE TRANS CONCERN, PERFORM ELECTRONIC TRANS DIAG KOEO P0657,P0743,P0753,P0763,P0773, P0973,P0979,P0985,P0742,P0748,P0758,P0768,P0962 P0976,P0982 FOLLOW PINPOINT TEST A IN SHOP MANUAL POWER TO TRANS SOLENOIDS INTERUPPT DROP TRANS PAN FOR TESTING* PWR TO CIRCUIT1876 IS OK UNTIL THE
1FTSW21P35EB18620 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-OCT-2004 25-FEB-2005 111470 USA 36 6Y20 000001 * MISC * A99 82 83277
AWS Claim Key: 9382119 Trx Code: P98 Labor Hrs: 0
Dlr Cd-Sub Cd: 02735 - * Name: ATHOL FORD AND MERCURY Ph: 978-2493531 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:04-FEB-2008 Doc #:070799A
Cust Comments: AWA ASSISTANCE P98 FOR TRANSMISSION WORK
Tech Comments: AFTER WARRANTY ASSISTANCE FOR TRANSMISSION WORK P98 ASSISTANCE
1FTSW21P35EB18620 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-OCT-2004 25-FEB-2005 111470 USA 44 1A02 030102 * 6051 * L87 42 97455
AWS Claim Key: 10457889 Trx Code: E72 Labor Hrs: 22.9
Dlr Cd-Sub Cd: 09113 - * Name: HARR MOTOR COMPANY, INC. Ph: 508-8525111 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:23-SEP-2008 Doc #:339379A
Cust Comments: CUSTOMER STATES VEHICLE SEEMS TO BE CONSUMING COOLANT
Tech Comments: 97455 VERIFIED CONCERN OF CONSUMING COOLANT COOLANT LEVEL WAS LOW AND NO EXTERNAL LEAKS COULD BE FOUND.PERFORMED TSB 08 11 3 FOR COOLANT LOSS.PERFORMED TEST ON CAP AND WAS LETTING GO AT 11 PSI,THEN TESTED THE DEGAS BOTTLE AND FOUND THAT IT WAS LEAKING FROM TOP,REPLACED DEGAS BOTTLE AND CAP.PERFORMED COOLENT PRESSURE TEST AND FOUND WAS LEAKING DOWN STILL,FAILED RADKIT
1FTSW21P35EB18620 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-OCT-2004 25-FEB-2005 111470 USA 44 6Y20 000000 * TAP1 * A99 82 97455
AWS Claim Key: 10457890 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 09113 - * Name: HARR MOTOR COMPANY, INC. Ph: 508-8525111 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:23-SEP-2008 Doc #:339379C
Cust Comments: TAP DAY RENTAL 8 DAYS 208.00
Tech Comments: TAP DAY RENTAL
1FTSW21P35EB18620 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-OCT-2004 25-FEB-2005 111470 USA 45 2E03 0304XX 5C3Z 9C968 CA E29 42 99280
AWS Claim Key: 10550957 Trx Code: E72 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 08892 - * Name: LAMOUREUX FORD, INC. Ph: 508-8851000 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:03-NOV-2008 Doc #:038867A
Cust Comments: CHECK ENGINE LIGHT COMES ON FAST IDLE ENGAGES WHILE IN DRIVE. IDLES ROUGH WHEN STARTED COLD.
Tech Comments: FAST IDLE ENGAGES WHILE IN DRIVE. IDLES ROUGH WHEN STARTED COLD. CUSTOMER HAS TO RE START TO CLEAN OUT. SEE ATTACHED NOTE IDS TEST NO CODES. IDS DATA LOGGER TOO LONG. TEST DRIVES NO PROBLEM FOUND. LET SIT OVERNIGHT AND TRIED COLD START. COULD NOT VERIFY. EEC TEST P2284 ICP CIRCUIT/PERFORMANCE. PERFORMED PINPOINT TEST. CHECKED OIL ADDED 1 1/2QTS. MONITORED PID DATA AND ROAD TESTED. CLEARED CODES A
4play is offline
Oasis Request wolfman Ford Oasis requests 1 10-13-2007 11:39 AM
OASIS Request Please p38guy Ford Oasis requests 1 09-26-2007 09:27 PM
OASIS Request, please... tallfarmboy Ford Oasis requests 1 11-23-2006 03:21 AM
OASIS Request tallfarmboy Ford Oasis requests 1 11-23-2006 03:20 AM
Oasis Request Please BAT Ford Oasis requests 1 11-15-2006 12:55 AM
