oasis requests - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 105vegas, this thread has received 4 replies and been viewed 906 times.
post #1 of 5 (permalink) Old 05-07-2009, 02:17 AM Thread Starter
105vegas's Avatar
oasis requests
1FTSW21P95EC03252
Thanks
105vegas is offline
post #2 of 5 (permalink) Old 05-07-2009, 03:18 PM
4play's Avatar
OASIS RESULT:
1FTSW21P95EC03252
USA
EN
05/07/2009
11:18:04
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/27/2005 BUILD DATE
01/21/2005 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/13/2009
DEALER: Les Stumpf Ford
WARRANTY CLAIM NUMBER: 223921 ODOMETER: 097278M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6584BA GASKET VALVE ROCKER 001 6584AL 42 DOES NOT OPERATE PROPERLY
W302725 001 6005F
4C2Z 12A690AB WIRING ASY EC SENSOR 001 MT12A690
5C3Z 12A690A WIRING ASY EC SENSOR 001
3C3Z 9C064DA FUEL FILTER "O"RING 001
DI WARRANTY, $100.00 DED BOTH SIDES OF GLOW PLUG HARNESS LEAKING, REMOVE FENDER WHEEL WELLS TO REMOVE AND REPLACE HARNESS, REPLACE LEFT SIDE VALVE CO VER GASKET, REPLACE CRANK SENSOR O-RING, TEST DRIVE
02/09/2009
DEALER: Langlade Ford/Mercury, Inc.
WARRANTY CLAIM NUMBER: 083373 ODOMETER: 095305M
LABOR OP
CONDITION CODE
CONDITION DESC
6051 GASKET CYL HEAD 000 081103A 42 DOES NOT OPERATE PROPERLY
6C3Z 6C640A CONNECTION A/C DUCT 001 081103B
4C3Z 9P456AF COOLER - EGR 001 081103G
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001
W302725 001
VC 7B 003
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W405QSD 003
TSB 8-11-03,SELF TEST,PRESSURE TEST COOLING SYSTEM,LOOSES PRESSURE. NO EXTER NAL LEAKS ,HOOKED UP AIR LIFT PUMP AND PULLED VACUUMLEAKS DONW 15 IN IN ABOU T 3 MIN. REMOVED EGR COOLER LEAKING AND REPLACED CHECKED OIL COOLER FOR LEAK S NONE FOUND.TRIED TO START BUT MOTOR IS HYDROLOCKED, REMOVED GLOW PLUGS TO VENT COOLANT. TEST DROVE AND MONITORED EGT AND EOT WAS OK CHANGED OIL AND FI
10/29/2008
WARRANTY CLAIM NUMBER: 081073 ODOMETER: 088444M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 12A342AA PLUG-GLOW 002 6007A28 42 DOES NOT OPERATE PROPERLY
5C3Z 9A332A HOSE ASY (FUEL HIGH 002 6731A
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 002 6584A5TA
3C3Z 6731AA ELEMENT ASY OIL FILT 001 9527AT
XO 15W40QSD 015
3C3Z 6766CA CAP ASY OIL FILLER 001
VC 7B 002
08/11/2008
DEALER: Kocourek Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 000321 ODOMETER: 083470M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 003 9527AT 42 DOES NOT OPERATE PROPERLY
W302725 001 6005F
000 6005F13
000 6005F1
000 6005F2
000 6005F14
000 6005F20
000 6005F11
000 6005F18A
000 6005F21
000 6005F6
000 6005F8
000 6005F22
000 6005F38
000 6005F33
000 6005F45
000 MTACCESS
HAS NEW FILTERS AND ENGINE OIL EEC TESTED, NO CODES. RAN PERFORMANCE DIAG TE STS, POWER BALANCE AND TRACED TO 3 BAD INJECTORS, 3, 4, 6. M-TIME TO REMOVE AFTER MARKET EQUIPMENT TO ACCESS AND REPLACE 3 INJECTORS. REASSEMBLED AND RE TESTED, PASSED
07/24/2008
WARRANTY CLAIM NUMBER: 079944 ODOMETER: 081767M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 072109A 55 PLUGGED/RESTRICTED
SELF TEST PO404 ,P1335 . PERFORMED EGR SYSTEM TEST ON IDS AND FAILED REMOVED EGR VALVE AND WAS FULL OF CARBON REPLACED EGR VALVE, RAN TEST AND ADVISE CUSTOMER TO USE C-TANE BOOSTER PER TSB 07-21-09
4play is offline
post #3 of 5 (permalink) Old 05-07-2009, 09:03 PM Thread Starter
105vegas's Avatar
thanks
105vegas is offline
post #4 of 5 (permalink) Old 05-07-2009, 10:34 PM
4play's Avatar
no problem but i forgot to mention, the 2nd part is unavailable right now. ford said they are conducting maintenance until next monday May 11. if you want you can repost then and i will get the 2nd part.
4play is offline
post #5 of 5 (permalink) Old 05-11-2009, 02:03 PM
4play's Avatar
1FTSW21P95EC03252 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JAN-2005 27-APR-2005 141102 USA 2 2G05 031405 * RECALEM * D50 04 4392
AWS Claim Key: 997031 Trx Code: S07 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 06109 - * Name: BELL MOTORS, INC. Ph: 608-6354383 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:31-MAY-2005 Doc #:06054902
Cust Comments: VEHICLE SMOKES WHITE WHEN 1ST STARTED IN THE MORNING. DOES N NOT SMOKE AGAIN UNTIL NEXT MORNING.
Tech Comments: CHECKED AND RECALIBRATED PCM AS PER LATEST AVAILABLE UPDATE.
1FTSW21P95EC03252 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JAN-2005 27-APR-2005 141102 USA 15 * * * * * * * 33707
AWS Claim Key: 5193727 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01661 - * Name: LANGLADE FORD/MERCURY, INC. Ph: 715-6272200 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:10-JUL-2006 Doc #:07058203
Cust Comments: RECALL 05B35
Tech Comments: 1 REPROGRAMED CONTROL MODULES
AWS Claim Key: 5193728 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01661 - * Name: LANGLADE FORD/MERCURY, INC. Ph: 715-6272200 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:10-JUL-2006 Doc #:07058202
Cust Comments: RECALL 05B32
Tech Comments: 1 INSTALLED LABEL AND REMOVED FLUID
1FTSW21P95EC03252 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JAN-2005 27-APR-2005 141102 USA 15 7N02 010505 4L2Z 14529 AAA G07 28 33707
AWS Claim Key: 5193729 Trx Code: E83 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01661 - * Name: LANGLADE FORD/MERCURY, INC. Ph: 715-6272200 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:10-JUL-2006 Doc #:07058201
Cust Comments: C S THAT THE RIGHT FRONT WINDOW IS INOP
Tech Comments: BCE DIAG SELF TEST NO CODES PERFORMED PPT FROM EVTM AND FOUND DRIVERS WINDOW SWITCH OPEN R&R DRIVERS WINDOW SWITCH AND LOCK SWITCH OK NOW
1FTSW21P95EC03252 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JAN-2005 27-APR-2005 141102 USA 24 1A02 030102 * 6051 * D42 42 51465
AWS Claim Key: 7504449 Trx Code: E72 Labor Hrs: 10.4
Dlr Cd-Sub Cd: 01661 - * Name: LANGLADE FORD/MERCURY, INC. Ph: 715-6272200 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2007 Doc #:07388201
Cust Comments: C S THAT THERE IS WHITE SMOKE COMING FROM THE TAIL PIPE UPON START UP PLEASE ADVISE ALSO THERE IS OIL IN THE TAIL PIPE
Tech Comments: PERFORMED COMP TEST OK FOUND COOLENT IN THE OIL REMOVED EGR VALVE AND PRESSURE TESTED THE COOLING SYSTEM AND FOUND THE EGR COOLER LEAKING PER TSB 06 21 2 R&R EGR COOLER RETESTED OK
1FTSW21P95EC03252 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JAN-2005 27-APR-2005 141102 USA 24 1H03 030008 5C3Z 9F452 AA D42 42 52495
AWS Claim Key: 7642121 Trx Code: S07 Labor Hrs: 3
Dlr Cd-Sub Cd: 01661 - * Name: LANGLADE FORD/MERCURY, INC. Ph: 715-6272200 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2007 Doc #:07411201
Cust Comments: C S THAT THE TRUCK LOOSES POWER AND SMOKES ALOT AT TIMES ALSO THE OIL LEVEL IS HIGH PLEASE ADVISE
Tech Comments: PERFORMED DIAG SHEET R&R EGR VALVE AND FICM, REPROGRAMED MODULES AND RETESTED
1FTSW21P95EC03252 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JAN-2005 27-APR-2005 141102 USA 28 1H03 030008 5C3Z 9F452 AA A85 41 59507
AWS Claim Key: 8275357 Trx Code: E91 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 01661 - * Name: LANGLADE FORD/MERCURY, INC. Ph: 715-6272200 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:16-JUL-2007 Doc #:07533501
Cust Comments: C S SITTING AT STOP SIGN RPM GOES RACING INJECTOR ?
Tech Comments: EGR STICKING AT TIMES WHEN CUST GOT HERE PROBLEM WAS GONE DIAG WITH ENGINE PERF SHEET ALL STEPS TESTED PASSED RTEST WITH CUST STARTED TO ACT UP DIAG BY SYMPTOM WHEN EGR DISCONNECTED CLEARED UP SERVICE REPLACE EGR VALVE
1FTSW21P95EC03252 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JAN-2005 27-APR-2005 141102 USA 40 1H03 030008 5C3Z 9F452 AA D13 55 81767
AWS Claim Key: 10161891 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01661 - * Name: LANGLADE FORD/MERCURY, INC. Ph: 715-6272200 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:24-JUL-2008 Doc #:07994401
Cust Comments: C S STARTING IN MORNING IDLES FINE, SHAKES AND HAS NO POWER
Tech Comments: SELF TEST PO404 ,P1335 . PERFORMED EGR SYSTEM TEST ON IDS AND FAILED REMOVED EGR VALVE AND WAS FULL OF CARBON REPLACED EGR VALVE, RAN TEST AND ADVISE CUSTOMER TO USE C TANE BOOSTER PER TSB 07 21 09
1FTSW21P95EC03252 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JAN-2005 27-APR-2005 141102 USA 41 2E03 030402 4C3Z 9E527 BRM D42 42 83470
AWS Claim Key: 10394559 Trx Code: S07 Labor Hrs: 10.9
Dlr Cd-Sub Cd: 02883 - * Name: KOCOUREK FORD LINCOLN MERCURY Ph: 715-2983673 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2008 Doc #:00032101
Cust Comments: NO POWER ON ACCELORATION, NO MIL LIGHT ON
Tech Comments: HAS NEW FILTERS AND ENGINE OIL EEC TESTED, NO CODES. RAN PERFORMANCE DIAG TESTS, POWER BALANCE AND TRACED TO 3 BAD INJECTORS, 3, 4, 6. M TIME TO REMOVE AFTER MARKET EQUIPMENT TO ACCESS AND REPLACE 3 INJECTORS. REASSEMBLED AND RETESTED, PASSED
1FTSW21P95EC03252 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JAN-2005 27-APR-2005 141102 USA 43 2E03 030402 4C3Z 9E527 BRM D03 42 88444
AWS Claim Key: 10595179 Trx Code: E91 Labor Hrs: 9
Dlr Cd-Sub Cd: 01661 - * Name: LANGLADE FORD/MERCURY, INC. Ph: 715-6272200 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2008 Doc #:08107301
Cust Comments: PERFORM COMPUTER SYSTEMS DIAGNOSTICS FOR CONCERN(S) LISTED HARD START,MISSING TALK TO TECH
Tech Comments: NO CRANK DIAG, TESTED BATTERIES OK .FOUND ENGINE HYDRO LOCKED R&RGLOW PLUGS , FOUND CYLS 3&4 FILLED WITH FUEL. REMOVED ING,S AND FOUND THEM TO BE LOOSE. COPPER O RING MISSING.REMO VED PUSH RODS TO MAKE SURE NOT BENT. ALL OK REPLACED #3  INJS . PERFORMED COMP. TEST. ALL GOOD. CHANGE OIL AND TEST DROVE OK ORINGS MISSING DUE TO INJ BEING LOOSE
1FTSW21P95EC03252 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JAN-2005 27-APR-2005 141102 USA 47 1A02 030102 * 6051 * L65 42 95305
AWS Claim Key: 10795551 Trx Code: E72 Labor Hrs: 10.2
Dlr Cd-Sub Cd: 01661 - * Name: LANGLADE FORD/MERCURY, INC. Ph: 715-6272200 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2009 Doc #:08337301
Cust Comments: CUST STATES HAD OIL DYE ADDED TO OIL BACK FOR RECHECK ALSO SMOKES BLACK,USING OIL AND ANTI FREEZE
Tech Comments: TSB 8 11 03,SELF TEST,PRESSURE TEST COOLING SYSTEM,LOOSES PRESSURE. NO EXTERNAL LEAKS ,HOOKED UP AIR LIFT PUMP AND PULLED VACUUMLEAKS DONW 15 IN IN ABOUT 3 MIN. REMOVED EGR COOLER LEAKING AND REPLACED CHECKED OIL COOLER FOR LEAKS NONE FOUND.TRIED TO START BUT MOTOR IS HYDROLOCKED, REMOVED GLOW PLUGS TO VENT COOLANT. TEST DROVE AND MONITORED EGT AND EOT WAS OK CHANGED OIL AND FILTER.
1FTSW21P95EC03252 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-JAN-2005 27-APR-2005 141102 USA 49 2G02 030008 4C2Z 12A690 AB L65 42 97278
AWS Claim Key: 10887308 Trx Code: E72 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 06249 - * Name: LES STUMPF FORD Ph: 920-7315211 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2009 Doc #:22392101
Cust Comments: OWNER STATES VEHICLE LEAKING OIL OUT OF BOTH HEADGASKETS
Tech Comments: DI WARRANTY, $100.00 DED BOTH SIDES OF GLOW PLUG HARNESS LEAKING, REMOVE FENDER WHEEL WELLS TO REMOVE AND REPLACE HARNESS, REPLACE LEFT SIDE VALVE COVER GASKET, REPLACE CRANK SENSOR O RING, TEST DRIVE
4play is offline
Oasis requests sanjay Ford Oasis requests 2 03-10-2009 04:28 PM
OASIS requests trac Ford Oasis requests 4 02-05-2007 03:31 PM
OASIS requests Scooters99PSD Ford Oasis requests 2 09-09-2006 11:07 AM
OASIS Requests NMU98 Site Information 8 02-02-2006 11:28 PM
