Oasis Request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by quailconservation, this thread has received 3 replies and been viewed 488 times.
post #1 of 4 (permalink) Old 05-07-2009, 12:01 PM Thread Starter
Oasis Request
VIN: 1FTSW21P85EC03646
Thanks!
quailconservation is offline
post #2 of 4 (permalink) Old 05-07-2009, 03:20 PM
4play's Avatar
OASIS RESULT:
1FTSW21P85EC03646
USA
EN
05/07/2009
11:19:27
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/01/2005 BUILD DATE
01/18/2005 SALE MILEAGE
00026
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
4play is offline
post #3 of 4 (permalink) Old 05-07-2009, 10:32 PM
4play's Avatar
the 2nd part is unavailable right now. ford said they are conducting maintenance until next monday May 11. if you want you can repost then and i will get the 2nd part.
4play is offline
post #4 of 4 (permalink) Old 05-11-2009, 02:06 PM
4play's Avatar
1FTSW21P85EC03646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JAN-2005 01-FEB-2005 124553 USA 5 1D01 030203 3C3Z 6734 AA L65 D8 8774
AWS Claim Key: 1215883 Trx Code: 1 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 04910 - * Name: COOK-WHITEHEAD FORD, INC. Ph: 850-7840400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2005 Doc #:22866401
Cust Comments: CUSTOMER STATES ENGINE IS LEAKING OIL
Tech Comments: OIL PLUG GASKET LEAKING CHECK OIL LEAK,ADD DYE AND CHECK WITH BLACK LIGHT,REPLACE OIL PLUG GASKET,RECHECK
1FTSW21P85EC03646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JAN-2005 01-FEB-2005 124553 USA 6 1D01 03XXXX 3C3Z 6700 BA L65 D8 9757
AWS Claim Key: 1340639 Trx Code: 1 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 04910 - * Name: COOK-WHITEHEAD FORD, INC. Ph: 850-7840400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:13-JUL-2005 Doc #:22957001
Cust Comments: CUSTOMER STATES THAT HAS OIL LEAK , PLEASE CHECK AND ADVISE
Tech Comments: D8 FAILED SEAL OIL LEAK DIAG, R&R FRONT CRANKSHAFT SEAL
AWS Claim Key: 1353086 Trx Code: E93 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 04910 - * Name: COOK-WHITEHEAD FORD, INC. Ph: 850-7840400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:13-JUL-2005 Doc #:22957002
Cust Comments: THE FRONT CRANK SEAL WAS DEFECTIVE THAT WAS INSTALLED ON JOB # 1
Tech Comments: D4 FLAW IN MATERIAL REPLACE FRONT CRANKSHAFT SEAL, NOTICED DEFECT AFTER INSTALATION. SERVICE PART
1FTSW21P85EC03646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JAN-2005 01-FEB-2005 124553 USA 13 * * * * * * * 23055
AWS Claim Key: 3589283 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04910 - * Name: COOK-WHITEHEAD FORD, INC. Ph: 850-7840400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2006 Doc #:24267802
Cust Comments: CUSTOMER STATES PERFORM RECALL 59B01 SEE VOLUNTARY EMISSION RECALL 05E15 FOR DETAILS
Tech Comments: 1 PERFORM CUSTOSMER SATISFACTION TEST DRIVE
AWS Claim Key: 3589284 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04910 - * Name: COOK-WHITEHEAD FORD, INC. Ph: 850-7840400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2006 Doc #:24267801
Cust Comments: CUSTOMER STATES PERFORM RECALL 05E15
Tech Comments: 1 REPLACE EBP SENSOR & REPROGRAM PCM PER RECALL
AWS Claim Key: 3589282 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04910 - * Name: COOK-WHITEHEAD FORD, INC. Ph: 850-7840400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2006 Doc #:24267803
Cust Comments: CUSTOMER STATES PERFORM OPEN RECALL 05B32
Tech Comments: PERFORMED RECALL
1FTSW21P85EC03646 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-JAN-2005 01-FEB-2005 124553 USA 19 6N04 010802 5C3Z 16720 VA B66 14 33403
AWS Claim Key: 5514754 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04910 - * Name: COOK-WHITEHEAD FORD, INC. Ph: 850-7840400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:08-AUG-2006 Doc #:25371701
Cust Comments: CUSTOMER STATES EMBLEMS PEELING
Tech Comments: 14 UNEVEN SURFACE REMOVED OLD F250 EMBLEMS, AND ADHIESIVE, AND INSTALLED NEW F250 EMBLEMS
4play is offline
OASIS Request 02Powerstroke Ford Oasis requests 2 08-20-2007 03:18 AM
OASIS Request Dismissed Ford Oasis requests 1 07-28-2007 03:15 AM
OASIS request Mustang50 Ford Oasis requests 1 07-19-2007 02:30 AM
oasis request Steve Ford Oasis requests 2 07-31-2006 01:16 AM
Oasis Request Shriner Ford Oasis requests 1 07-31-2006 01:12 AM
