Please oasis check - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by redbaronmx319, this thread has received 2 replies and been viewed 581 times.
post #1 of 3 (permalink) Old 05-07-2009, 09:49 PM Thread Starter
Please oasis check
vin 1FTNX21P74EA67888
THANKS ALOT!!!!
redbaronmx319 is offline
post #2 of 3 (permalink) Old 05-07-2009, 10:32 PM
4play's Avatar
OASIS RESULT:
1FTNX21P74EA67888
USA
EN
05/07/2009
18:29:22
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/23/2003 BUILD DATE
09/21/2003 SALE MILEAGE
00010
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
the 2nd part is unavailable right now. ford said they are conducting maintenance until next monday May 11. if you want you can repost then and i will get the 2nd part.
4play is offline
post #3 of 3 (permalink) Old 05-11-2009, 02:02 PM
4play's Avatar
1FTNX21P74EA67888 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 21-SEP-2003 23-SEP-2003 141075 USA 2 7W06 000301 3L2Z 14A626 AA L20 46 469
AWS Claim Key: 228555 Trx Code: 1 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01892 - * Name: WEBB FORD INC Ph: 773-7211994 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:19-NOV-2003 Doc #:09446253
Cust Comments: CHECK VEHICLE WHEN RAINING KEYLESS ENTRY IS INOP. AT TIMES
Tech Comments: SHORTED KEYPAD KEYLESS ENTRY SYSTEM DIAGNOSIS
1FTNX21P74EA67888 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 21-SEP-2003 23-SEP-2003 141075 USA 4 2G01 030008 3C3Z 12B599 AARM D13 46 11257
AWS Claim Key: 297839 Trx Code: S07 Labor Hrs: 5
Dlr Cd-Sub Cd: 01892 - * Name: WEBB FORD INC Ph: 773-7211994 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:14-JAN-2004 Doc #:09664751
Cust Comments: CUST. STATES CHECK IDLE CONCERN
Tech Comments: EXTENSIVE TIME TO TRACE INTERMITTENT SHORT CIRCUIT IN INJECTION DRIVER MODULE.EXPOSE AND TEST INJECTOR WIRE HARNESS BETWEEN INJECTOR CONNECTOR AND INJECTOR DRIVER MODULE.REPROGRAM P.C.M.,T.C.M. WITH LATEST UPDATES
1FTNX21P74EA67888 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 21-SEP-2003 23-SEP-2003 141075 USA 31 * * * * * * * 76451
AWS Claim Key: 8876490 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01557 - * Name: TERRY'S FLM OF PEOTONE INC Ph: 708-2589200 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2006 Doc #:12425205
Cust Comments: RECALL 06E17
Tech Comments: REPROGRAMMED PCM PER RECALL 06E17
AWS Claim Key: 8876491 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01557 - * Name: TERRY'S FLM OF PEOTONE INC Ph: 708-2589200 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2006 Doc #:12425204
Cust Comments: RECALL 59B01
Tech Comments: COMPLETED RECALL 59B01
4play is offline
Oasis Check Please?!? indyF-350psd Ford Oasis requests 4 04-30-2008 12:11 PM
OASIS Check RockStar Ford Oasis requests 1 12-02-2007 06:59 PM
Oasis check pwrdby4d Ford Oasis requests 2 07-20-2007 03:42 PM
OASIS check please Diesel Hungry Ford Oasis requests 1 07-19-2007 03:15 AM
someone check out this oasis report yamaman 1994-2003 7.3L Power Stroke 4 02-07-2006 04:08 PM
