Oasis request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by myf350, this thread has received 3 replies and been viewed 1059 times.
post #1 of 4 (permalink) Old 05-08-2009, 11:32 AM Thread Starter
myf350's Avatar
Oasis request
My buddies GF is going to look at this truck tomorrow, would like some info before they get there if possible. Thanks
1FTSF21PX5EC49589
SOLD...early 99 F350 CC 4WD SRW, Tymar intake, 4 in. turbo back straight pipe w/ 5 in. tip, DP tuner, 203 t-stat, Timbrens in the rear, front leveled, King Ranch wheels, ISSPro gauges, Weston brush guard, rebuilt my trans using a Torqueshift converter
08 CC LB DRW MT 4WD Ranch Hand bumpers...stock for now
myf350 is offline
post #2 of 4 (permalink) Old 05-08-2009, 02:25 PM
4play's Avatar
this is all i can get for now. the 2nd part or older part of the warranty history is down until monday.
OASIS RESULT:
1FTSF21PX5EC49589
USA
EN
05/08/2009
10:21:14
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 REG CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
ZF M6HD-W 6-SPEED AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/25/2005 BUILD DATE
02/24/2005 SALE MILEAGE
00021
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
10/21/2008
DEALER: Marshall Ford
WARRANTY CLAIM NUMBER: 222667 ODOMETER: 043007M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 003 6005F 42 DOES NOT OPERATE PROPERLY
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 6005F1
000 6005F6
000 6005F45
000 6005F2
000 6005F18A
000 12650D47
000 6005F9
000 6007A28
000 9527AR
000 6005F39
000 6005F1X1
000 12650D30
43007 DIESEL ENGINE PERFORMANCE DIAG KOEO AND KOER TESTS CODE PO269 AND P02 99 PERFORMED PINPOINT TEST P INJECTOR ELECTRICAL TEST PASSED CHECKED FUEL PRESSURE OK AT ABOUT 52 PSI CYLINDER POWER BALANCE SHOWS MISFIRES ON CYLINDE RS 3 5 AND 7 CRANKCASE PRESSURE TEST OK MANUAL CYLINDER COMPRESSION TEST OK AT ABOUT 350 PSI RNR RIGHT VALVE ROCKER COVER NO VISABLE DAMAGE TO ROCKERS
09/30/2008
WARRANTY CLAIM NUMBER: 222018 ODOMETER: 042675M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
W301381 001 6005F1
W302725 001 6005F6
000 8005D
000 12650D47
000 6005F18A
000 6007A28
000 9527AL
000 12650D84
000 6005F1X1
42675 DIESEL ENGINE PERFORMANCE DIAG KOEO AND KOER TESTS NO CODES PRESSURE TEST COOLING SYSTEM NO LEAKS POWER BALANCE SHOWED MISFIRE ON CYLINDER 6 FUE L PRESSURE TEST OK AT ABOUT 51 PSI MANUAL COMPRESSION TEST ALL CYLINDERS EQ UAL RNR LEFT VALVE ROCKER COVER TO INSPECT NO OBVIOUS DAMAGE REPLACED NUMB ER 6 INJECTOR RESET KAM AND POST TEST DRIVE NOTE THAT THERE WERE SEVERAL LO
09/30/2008
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 14B268AA AIR BAG DEACTIVITATI 001 14056D 42 DOES NOT OPERATE PROPERLY
000 MT14B268
42675 SUPLEMENTAL RESTRAINT SYSTEM DIAG CODE B1884 PERFORMED PINPOINT TEST E RNR DASH PANEL TO ACCESS AND REPLACE PASSENGER DEACTIVATION SWITCH
08/14/2008
DEALER: Preston Ford, Inc.
WARRANTY CLAIM NUMBER: 050428 ODOMETER: 041578M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 072109A 42 DOES NOT OPERATE PROPERLY
000 14200A
VERIFIED CONCERN, SES LIGHT IS ON. SEVERAL EGR CODES IN MEMORY. PERFORM EG R VALVE TEST, FAILED. REMOVED EGR VALVE FOUND IT PACKED WITH DRY CARBON DEP OSITS. CLEAN OUT PASSAGES & INSTALLED NEW EGR VALVE & REYEST. STILL HAVE P 2285 CODE ON DEMAND. ICP CIRCUIT MALFUNCTION, REMOVED CONNECTOR FROM ICP SE NSOR & FOUND ONE PIN WAS BENT OUT OF POSITION. STRAIGHTEN PINS INSIDE SENSO
4play is offline
myf350 (05-12-2009)
post #3 of 4 (permalink) Old 05-08-2009, 02:38 PM Thread Starter
myf350's Avatar
Thanks, I'll check back Monday.
myf350 is offline
post #4 of 4 (permalink) Old 05-11-2009, 02:05 PM
4play's Avatar
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 0 6Y06 011607 * FWASH * F99 51 4
AWS Claim Key: 505225 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 04379 - * Name: PRESTON FORD, INC. Ph: 440-9514141 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2005 Doc #:029266B
Cust Comments: CHECK FLUIDS
Tech Comments: TOPPED OFF FLUIDS
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 6 5J01 040301 * 18124 * C50 D4 6905
AWS Claim Key: 1981549 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 04379 - * Name: PRESTON FORD, INC. Ph: 440-9514141 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2005 Doc #:032205A
Cust Comments: C S FRT SHOCKS LEAKING ....REPL SEEKING REIMBURSEMENT, SEE ATTACHED RECEIPT
Tech Comments: REFUMND PAID TO CUSTOMER FOR REPARIS ON VEHICLE DUE TO LEAKING SEALS.
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 8 2G05 031405 * RECALEM * D36 04 9358
AWS Claim Key: 2283212 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04379 - * Name: PRESTON FORD, INC. Ph: 440-9514141 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:24-OCT-2005 Doc #:032834C
Cust Comments: C S MISSES & SMOKES ON A COLD START...
Tech Comments: 9358 VEHICLE MISSES AND SMOKES ON COLD START CLEARS UP AS ENGINE WARMS UP. PERFORM TSB 05 11 04. REPROGRAM PCM, TCM & FICM PER TSB.
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 8 2H01 030008 * 6K682 * D50 42 9358
AWS Claim Key: 2326519 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 04379 - * Name: PRESTON FORD, INC. Ph: 440-9514141 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:24-OCT-2005 Doc #:032834B
Cust Comments: C S TURBO NOT BUILDING PRESSURE AND WHISTLES
Tech Comments: 9358 PERFORM DIESEL DIAGNOSTICS (PERFORMANCE) SEE ATTACHED WORK SHEET. HAD 2 CODES IN MEMORY P0272 AND P0299. PERFORMED PINPOINT TESTS FOR BOTH CODES P0272 #2 CYLINDER MISFIRE INJECTOR TESTED GOOD AND CYL CONTRIBUTION WAS GOOD. P0299 IS TURBO PERFORMANCE LOW. FOUND EBP SENSOR TUBE PARTIALLY BLOCKED. CLEANED OUT TUBE.
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 11 * * * * * * * 14070
AWS Claim Key: 3705834 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04355 - * Name: KEPICH FORD MERCURY Ph: 330-5273673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:17-FEB-2006 Doc #:04451604
Cust Comments: 05B32 DEGAS BOTTLE LABEL RECALL
Tech Comments: PERFORM RECALL
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 11 2H01 030008 5C3Z 6K682 CA D36 42 14070
AWS Claim Key: 3705831 Trx Code: S07 Labor Hrs: 8.6
Dlr Cd-Sub Cd: 04355 - * Name: KEPICH FORD MERCURY Ph: 330-5273673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:17-FEB-2006 Doc #:04451601
Cust Comments: CHECK TURBO MAKES NOISE ON ACCELL,LACKS POWER
Tech Comments: RUNS ROUGH COLD START AND SMOKES BAD PERFORM WDS PERFORMANCE DIAG,REPLACE TURBO AN D #4 INJECTOR,RETEST AND ROADTEST ALL OK 6005F23 .4 6005F21 .3 6005F13 02 6005F20 01 6005F25 1.4 9438A 1.8 9527AL 1.79438AZW .1
AWS Claim Key: 3705832 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04355 - * Name: KEPICH FORD MERCURY Ph: 330-5273673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:17-FEB-2006 Doc #:04451602
Cust Comments: 05B35 RECALL RECALL MODULE
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 11 6N04 010807 5C3Z 9942528 DA B62 81 14070
AWS Claim Key: 3705833 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04355 - * Name: KEPICH FORD MERCURY Ph: 330-5273673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:17-FEB-2006 Doc #:04451603
Cust Comments: CHECK EMBLEMS ON TAILGATE PEELING PAINT
Tech Comments: REPLACE REAR EMBLEM
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 17 6N04 010802 5C3Z 16720 EB B62 81 21275
AWS Claim Key: 5820235 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04355 - * Name: KEPICH FORD MERCURY Ph: 330-5273673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2006 Doc #:04639602
Cust Comments: RT FRT FENDER EMBLEM PEELING
Tech Comments: REPLACE EMBLEM
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 17 1H03 030008 5C3Z 9F452 AA D42 42 21275
AWS Claim Key: 5820234 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 04355 - * Name: KEPICH FORD MERCURY Ph: 330-5273673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2006 Doc #:04639601
Cust Comments: CHECK RUNS ROUGH COLD START BLOWING WHITE SMO
Tech Comments: KE GO TO ACCELL SPITS AND SPUTTERS EVEN IF YO U LET RUN 15 MINUTES PERFORM COMPUTOR TESTS CODE P0404 P1331 REPLACE EGR VALVE AND RETEST ALL OK
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 18 7M01 150102 5C3T 18C869 AH A07 42 21275
AWS Claim Key: 6005075 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:28-AUG-2006 Doc #:29633800
Tech Comments: REQUESTING DEALER'S P/A CODE 04355
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 18 7S20 180103 * 14A107 * H19 42 24658
AWS Claim Key: 6353549 Trx Code: E83 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 04355 - * Name: KEPICH FORD MERCURY Ph: 330-5273673 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2006 Doc #:04663601
Cust Comments: ABS LIGHT ON ITERMITTANT
Tech Comments: TEST ELECTRONICS HAD CODE C1236 C1175 PERFORM PINPOINT TEST REPLACE REAR SENSOR AND INSPEC T TONE RING AND WIRE HARNESS PER TSB 06 7 6
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 25 2E03 030402 4C3Z 9E527 AA D42 42 28211
AWS Claim Key: 7506010 Trx Code: S07 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 04379 - * Name: PRESTON FORD, INC. Ph: 440-9514141 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2007 Doc #:041735B
Cust Comments: RUNS POORLY ESPECIALLY COLD
Tech Comments: VERIFIED CONC. PERF DIAG, HAVE CMDTC FOR #5 CYL CONTRIB. PERF DIAG PER TSB 6 13 3. #5 INJECTOR FAILED. REPLACE #5 AND RETEST. NOW OK
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 25 2E03 030402 4C3Z 9E527 AA D42 42 28347
AWS Claim Key: 7563995 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 04379 - * Name: PRESTON FORD, INC. Ph: 440-9514141 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:12-APR-2007 Doc #:041869A
Cust Comments: VEHICLE IS RUNNING POORLY
Tech Comments: VERIFIED CONCERN. HAVE CYL CONTRIBUTION CODE IN MEMORY FOR CYL #2 PERFORM DIAG PER TSB 6 13 3. #2 INJECTOR FAILED. REPLACE INJECTOR. VERF REPR.
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 29 1H03 030008 5C3Z 9F452 AA E29 55 27358
AWS Claim Key: 8277821 Trx Code: S07 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 04379 - * Name: PRESTON FORD, INC. Ph: 440-9514141 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2007 Doc #:043751A
Cust Comments: RUNNING ROUGH, CHECK ENGINE LIGHT
Tech Comments: VERIFIED CONCERN, SCANNED FOR CODES. HAVE CODES FOR EGR. REMOVED EGRAND CLEANED PER TSB 6 19 6. INSTALLED AND RUN POSITION TEST, VALVE FAILED, REMOVEAND INSTALL NEW VALVE. VEHICLE NOW OPPERATES NORMALLY. MILEAGE FOR RO 41869 WAS ENTERED INCORRECTLY SHOULD HAVE BEEN 23347 NOT 28347.
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 29 5V09 120307 6C3Z 2A451 A C20 28 27606
AWS Claim Key: 8321531 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04379 - * Name: PRESTON FORD, INC. Ph: 440-9514141 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:02-AUG-2007 Doc #:043858B
Cust Comments: AC ONLY BLOWS OUT DEFROSTER
Tech Comments: VERIFIED CONCERN, AIR ONLY DISCHARGES FROM DEFROSTER DUCTS REGARDLESS OF MODE SELECTED. CHECK FOR VACUUM AT CONTROL HEAD. NO VACUUM. CHECK PUMP OPERATION. PUM IS INOP. HAVE POWER TO VACUUM PUMP. NO CONTINUITY THRU PUMP. REPLACE PUMP. NOW HAVE PROPER OPERATION OF ALL VACUUM.
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 35 1A02 030102 * 6051 * L87 42 34028
AWS Claim Key: 9348566 Trx Code: E84 Labor Hrs: 20.2
Dlr Cd-Sub Cd: 04379 - * Name: PRESTON FORD, INC. Ph: 440-9514141 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2008 Doc #:046827A
Cust Comments: LOOSING COOLANT, ANTIFREEZE LEAKING FROM BOTTLE
Tech Comments: VERIFIED COOLANT LOSS. PERFORM DIAG PER TSB 7 21 05. HAVE NO CODES PRESSURE TEST COOLING SYSTEM. PRESSURE DROPS. CHECK OPERATION OF CAP (GOOD). REMOVED EGR AND PRESSURE TESTED EGR COOLER. HAVE COOLANT IN COOLER. REMOVE INTAKE AND REPLACE COOLER. REASSEMBLED AND RETESTED PER TSB. DURING ROAD TEST COOLANT PRESSURE EXCEEDED HOLDING PRESSURE AND OVERFLOWED THE DEGAS BOTTLE. TORE DOWN AND REPLAC
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 37 2E07 030008 3C3Z 9T517 AD D42 42 37455
AWS Claim Key: 9654952 Trx Code: E72 Labor Hrs: 4
Dlr Cd-Sub Cd: 04379 - * Name: PRESTON FORD, INC. Ph: 440-9514141 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-MAR-2008 Doc #:047819A
Cust Comments: VEHICLE SPUTTERING UNTIL WARMED UP/NO POWER
Tech Comments: VERIFIED CONCERN, PERFORM DIESEL PERF DIAG, PERFORM FUEL SYSTEM TEST, PRESSURES LOW /CHECK FOR RESTRICTION NONE. INSTALL FUEL PRESSURE REGULATOR, PRESSURE IS NOW RUNNING AT 50PSI. HAVE TWO CODES STILL, FOUND OPEN IN VISTRONIC FAN CLUTCH ASSY. REMOVE FAN SHROUDS AND INSTALL NEW FAN CLUTCH. CLEAR CODES AND RESET KAM. VEHICLE IS NOW WORKING AS DESIGNED.
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 42 1H03 030008 5C3Z 9F452 AA D42 42 41578
AWS Claim Key: 10261772 Trx Code: S07 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 04379 - * Name: PRESTON FORD, INC. Ph: 440-9514141 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:14-AUG-2008 Doc #:050428A
Cust Comments: VEHICLE LACKS POWER
Tech Comments: VERIFIED CONCERN, SES LIGHT IS ON. SEVERAL EGR CODES IN MEMORY. PERFORM EGR VALVE TEST, FAILED. REMOVED EGR VALVE FOUND IT PACKED WITH DRY CARBON DEPOSITS. CLEAN OUT PASSAGES & INSTALLED NEW EGR VALVE & REYEST. STILL HAVE P2285 CODE ON DEMAND. ICP CIRCUIT MALFUNCTION, REMOVED CONNECTOR FROM ICP SENSOR & FOUND ONE PIN WAS BENT OUT OF POSITION. STRAIGHTEN PINS INSIDE SENSOR REASSEMBLE & RETES
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 43 6R07 012005 F81Z 14B268 AA S38 42 42675
AWS Claim Key: 10455328 Trx Code: E81 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2008 Doc #:222018C
Cust Comments: CHECK AND ADVISE AIR BAG LIGHT IS ON.
Tech Comments: 42675 SUPLEMENTAL RESTRAINT SYSTEM DIAG CODE B1884 PERFORMED PINPOINT TEST E RNR DASH PANEL TO ACCESS AND REPLACE PASSENGER DEACTIVATION SWITCH
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 43 2E03 030402 4C3Z 9E527 BRM D13 42 42675
AWS Claim Key: 10455327 Trx Code: S07 Labor Hrs: 5.3
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2008 Doc #:222018A
Cust Comments: CUST STATES IN THE AM ENGINE IS RUNNING ROUGH AFTER START UP. LOTS OF WHIE SMOKE FROM TAIL PIPE. HIGH EXHAUST TEMP NOTICED.
Tech Comments: 42675 DIESEL ENGINE PERFORMANCE DIAG KOEO AND KOER TESTS NO CODES PRESSURE TEST COOLING SYSTEM NO LEAKS POWER BALANCE SHOWED MISFIRE ON CYLINDER 6 FUEL PRESSURE TEST OK AT ABOUT 51 PSI MANUAL COMPRESSION TEST ALL CYLINDERS EQUAL RNR LEFT VALVE ROCKER COVER TO INSPECT NO OBVIOUS DAMAGE REPLACED NUMBER 6 INJECTOR RESET KAM AND POST TEST DRIVE NOTE THAT THERE WERE SEVERAL LOOSE MISS
1FTSF21PX5EC49589 T/F7 F T/BB T/BD T/E A1 T/VG T/YB 24-FEB-2005 25-MAR-2005 144033 USA 44 2E03 030402 4C3Z 9E527 BRM D13 42 43007
AWS Claim Key: 10542302 Trx Code: S07 Labor Hrs: 6.1
Dlr Cd-Sub Cd: 02204 - * Name: MARSHALL FORD Ph: 440-4491000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:21-OCT-2008 Doc #:222667A
Cust Comments: CUST STATES SPECIALLY IN THE HARD TO START RUNS VERY POOR. NO POWER TO ACCEL. CUST LETS VEHICLE WARM UP FOR 30 MINS. WHITE SMOKE FROM TAIL PIPE.SPUTTERS WHEN WARM.
Tech Comments: 43007 DIESEL ENGINE PERFORMANCE DIAG KOEO AND KOER TESTS CODE PO269 AND P0299 PERFORMED PINPOINT TEST P INJECTOR ELECTRICAL TEST PASSED CHECKED FUEL PRESSURE OK AT ABOUT 52 PSI CYLINDER POWER BALANCE SHOWS MISFIRES ON CYLINDERS 3 5 AND 7 CRANKCASE PRESSURE TEST OK MANUAL CYLINDER COMPRESSION TEST OK AT ABOUT 350 PSI RNR RIGHT VALVE ROCKER COVER NO VISABLE DAMAGE TO ROCKERS
4play is offline
myf350 (05-12-2009)
oasis request please! barry1me Ford Oasis requests 2 03-24-2009 12:11 PM
Oasis Request Please shawnrans Ford Oasis requests 1 03-28-2007 03:04 AM
OASIS Request trpisok Ford Oasis requests 1 03-26-2007 01:05 AM
Another OASIS request ade_beer Ford Oasis requests 2 03-22-2007 10:58 PM
OASIS Request please Ohio Eddie Ford Oasis requests 2 06-13-2006 03:36 AM
