Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sticker500, this thread has received 1 replies and been viewed 639 times.
post #1 of 2 (permalink) Old 05-10-2009, 10:11 PM Thread Starter
Oasis Please
Could someone run this OASIS please. My brother is interested in this truck
1FTWW31P95EB35039
Thanks!
sticker500 is offline
post #2 of 2 (permalink) Old 05-11-2009, 02:10 PM
4play's Avatar
OASIS RESULT:
1FTWW31P95EB35039
USA
EN
05/11/2009
10:09:32
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/29/2005 BUILD DATE
11/08/2004 SALE MILEAGE
17000
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTWW31P95EB35039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-NOV-2004 29-NOV-2005 152118 USA 1 6C05 010506 5C3Z 3627406 AAB B43 34 17636
AWS Claim Key: 2976640 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03058 - * Name: ESCAMILLA FORD, INC. Ph: 361-5273224 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2005 Doc #:06122703
Cust Comments: CUSTOMER STATES WOOD GRAIN ON BOTH REAR DOOR PANELS IS DISTORTED
Tech Comments: VERIFIED CONCERN REPLACED BOTH REAR DOOR PANELS
1FTWW31P95EB35039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-NOV-2004 29-NOV-2005 152118 USA 1 6C01 010501 5C3Z 2613000 JAA T12 07 17636
AWS Claim Key: 2976642 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 03058 - * Name: ESCAMILLA FORD, INC. Ph: 361-5273224 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2005 Doc #:06122701
Cust Comments: CUSTOMER STATES DRIVERS SIDE REAR CARPET COMING APART.
Tech Comments: VERIFIED CONCERN REMOVED FT END REAR SEATS REPLACED CARPET RECHECKED GOOD
1FTWW31P95EB35039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-NOV-2004 29-NOV-2005 152118 USA 1 6N04 010802 5C3Z 16720 NA B66 81 17636
AWS Claim Key: 2976639 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 03058 - * Name: ESCAMILLA FORD, INC. Ph: 361-5273224 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2005 Doc #:06122704
Cust Comments: CUSTOMER STATES BLACK PAINT IS COMING OFF OF F350 EMBLEMS ON DRIVERS AND PASSENGER FENDERS.
Tech Comments: VERIFIED CONCERN REMOVED BOTH EMBLEMS CLEANED FENDER AND INSTALLED NEW EMBLEMS
1FTWW31P95EB35039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-NOV-2004 29-NOV-2005 152118 USA 1 7G09 011201 5C3Z 19893 DAA C19 42 17636
AWS Claim Key: 2976641 Trx Code: E83 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03058 - * Name: ESCAMILLA FORD, INC. Ph: 361-5273224 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2005 Doc #:06122702
Cust Comments: CUSTOMER STATES LEFT OUTER AC REGISTER WILL NOT OPEN UP. NO AIR FLOW.
Tech Comments: VERIFIED CONCERN REMOVED DASH PANEL REPLACED REGISTER RECHECKED GOOD
1FTWW31P95EB35039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-NOV-2004 29-NOV-2005 152118 USA 6 * * * * * * * 31396
AWS Claim Key: 4751854 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08466 - * Name: PORT LAVACA FORD Ph: 361-5521155 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-2006 Doc #:173019C
Cust Comments: RECALL 05B32, DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL
Tech Comments: DONE AS PER RECALL
1FTWW31P95EB35039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-NOV-2004 29-NOV-2005 152118 USA 6 1H03 030008 5C3Z 9F452 AA D36 42 31396
AWS Claim Key: 4751855 Trx Code: S07 Labor Hrs: 7.9
Dlr Cd-Sub Cd: 08466 - * Name: PORT LAVACA FORD Ph: 361-5521155 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-2006 Doc #:173019D
Cust Comments: SURGING AT IDLE
Tech Comments: RAN DIESEL DIAG ON UNIT, VGT SOLENOID, INJECTOR INTERUPT, COMPRESSION TEST, FUEL AND OIL PRESSURE AND AERATION TEST, ALL PASS. RAN EGR ACTIVATION TEST, FOUND EGR STICKING. R&R EGR VALVE AND RETEST, ALL OK.
AWS Claim Key: 4751853 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08466 - * Name: PORT LAVACA FORD Ph: 361-5521155 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-2006 Doc #:173019B
Cust Comments: RECALL 59B01 ONE TIME CUSTOMER TEST DRIVE
AWS Claim Key: 4751852 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08466 - * Name: PORT LAVACA FORD Ph: 361-5521155 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-2006 Doc #:173019A
Cust Comments: RECALL 05E15, EXHAUST PRESSURE SENSOR REPLACEMENT
1FTWW31P95EB35039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-NOV-2004 29-NOV-2005 152118 USA 7 7H08 12XXXX 6C3Z 19980 AA C02 42 31556
AWS Claim Key: 4880622 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08466 - * Name: PORT LAVACA FORD Ph: 361-5521155 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:31-MAY-2006 Doc #:173462A
Cust Comments: REPAIR A/C PROBLEM
Tech Comments: VERIFIED CONCERN, RAN A/C PRESSURE ON SYSTEM, ALL PASS. FOUND CONTROL HEAD SHORTED, R&R CONTROL HEAD AND RETEST, ALL OK.
1FTWW31P95EB35039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-NOV-2004 29-NOV-2005 152118 USA 7 2H01 030008 5C3Z 6K854 CA E41 42 31556
AWS Claim Key: 4880623 Trx Code: E84 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 08466 - * Name: PORT LAVACA FORD Ph: 361-5521155 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:31-MAY-2006 Doc #:173462B
Cust Comments: REPAIR EXHAUST SMELL
Tech Comments: VERIFIED CONCERN, FOUND Y PIPE LEAKING BEHIND TURBO. REMOVED TURBO ASSEMBLY TO ACCESS PIPE, REPLACED PIPE AND PUT BACK TOGETHER AND RETEST, ALL OK
4play is offline
sticker500 (05-14-2009)
