Oasis Req - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jammin60, this thread has received 1 replies and been viewed 465 times.
post #1 of 2 (permalink) Old 05-11-2009, 03:19 PM Thread Starter
jammin60's Avatar
Oasis Req
Can someone please pull an Oasis for this vin
1FTSW20P75EC63497
jammin60 is offline
post #2 of 2 (permalink) Old 05-11-2009, 03:39 PM
4play's Avatar
OASIS RESULT:
1FTSW20P75EC63497
USA
EN
05/11/2009
11:38:55
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/29/2005 BUILD DATE
03/13/2005 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0707 - USA 2004 NEW 60/100,000 EXTRACARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: HOME OWNERS FIRST CHOICE CONCRETE
OPTIONS:
EXPIRATION DATE: 03/29/2010
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 04992
ESP CONTRACT START DATE: 03/29/2005
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
1FTSW20P75EC63497 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 13-MAR-2005 29-MAR-2005 124223 USA 14 3A03 070100 5C3Z 7D006 AB P59 42 25467
AWS Claim Key: 4595973 Trx Code: E84 Labor Hrs: 12.4
Dlr Cd-Sub Cd: 04863 - * Name: DUVAL FORD Ph: 904-3876541 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2006 Doc #:00454652
Cust Comments: CHECK ADVISE C S WHEN DRIVEN TRANS SHIFTS AROUND 2ND OR 3RD GEAR SEEMS TO CLUNK INTO GEAR
Tech Comments: PERFORM TRANS DIAG, PINPOINT TEST CODE.FOUND EPC PRESS ERATTIC REMOVE TRANS PAN FOUND METAL IN PAN.REMOVE TRANS MOUNT ON BENCH TEAR DOWN FOUND WEAR AT REAR PLANETARY GEAR REPLACE GEAR,OVERHAUL TRANS OVERHAUL VALVE BODY REPLACE EPC SOLENOIDE,FLUSH COOLER AND LINES, FLUSH TORQUE CONVETER,CLEAN AND REUSE PAN GASKET,INSTALL ROAD TEST DRIVE CYCLE OK.
1FTSW20P75EC63497 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 13-MAR-2005 29-MAR-2005 124223 USA 14 * * * * * * * 25467
AWS Claim Key: 4595972 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04863 - * Name: DUVAL FORD Ph: 904-3876541 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2006 Doc #:00454641
Cust Comments: 05B35 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: REPROGRAN PCM
4play is offline
jammin60 (05-11-2009)
