2004 Excursion Report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JohnNolen, this thread has received 1 replies and been viewed 786 times.
post #1 of 2 (permalink) Old 05-12-2009, 08:19 PM Thread Starter
JohnNolen's Avatar
1FMSU43P04EC04797
Thanks
04 X Limited stock
SOLD 99 F-250 CrewCab SWB Volant Intake zoodad mod , 4" SilverLine Exhaust, Quadzilla Commander, and DP-Tuners 60t, 80eco, 120agr.
JohnNolen is offline
post #2 of 2 (permalink) Old 05-12-2009, 08:25 PM
4play's Avatar
OASIS RESULT:
1FMSU43P04EC04797
USA
EN
05/12/2009
16:24:33
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL REGION CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/19/2004 BUILD DATE
01/16/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0711 - EXPIRED
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: MICHELE LEWIS
OPTIONS: $100,DED.
EXPIRATION DATE: 02/19/2009
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 04617
ESP CONTRACT START DATE: 02/19/2004
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
1FMSU43P04EC04797 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-JAN-2004 19-FEB-2004 152054 USA 24 * * * * * * * 35474
AWS Claim Key: 8656120 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04572 - * Name: RUSSELL & SMITH FORD, INC. Ph: 713-6634111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2006 Doc #:01561241
Cust Comments: 05S34 FUEL INJECTOR CONTROL MODULE WIRING HARNESS REPAIR
Tech Comments: RECALL FUEL INJECTOR CONTROL MODULE WIRING HARNESS REPAIR
AWS Claim Key: 8656121 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04572 - * Name: RUSSELL & SMITH FORD, INC. Ph: 713-6634111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2006 Doc #:01561242
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM A
Tech Comments: RECALL REPLACE EBP AND CONNECTOR
AWS Claim Key: 8656122 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04572 - * Name: RUSSELL & SMITH FORD, INC. Ph: 713-6634111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2006 Doc #:01561243
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: RECALL CUSTOMER ASSURANCE TEST DRIVE REPLACE
1FMSU43P04EC04797 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-JAN-2004 19-FEB-2004 152054 USA 24 2H01 * * * * * * 35474
AWS Claim Key: 8656119 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04572 - * Name: RUSSELL & SMITH FORD, INC. Ph: 713-6634111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2006 Doc #:01561240
Cust Comments: 05B29 CHARGE AIR COOLER DUCT REPLACEMENT
Tech Comments: RECALL CHARGE AIR COOLER DUCT REPLACE
1FMSU43P04EC04797 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-JAN-2004 19-FEB-2004 152054 USA 26 7G05 120204 3C7Z 18495 AB E23 D8 37434
AWS Claim Key: 8950177 Trx Code: 0711D Labor Hrs: 1.4
Dlr Cd-Sub Cd: 04572 - * Name: RUSSELL & SMITH FORD, INC. Ph: 713-6634111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-MAR-2006 Doc #:01973851
Cust Comments: CUSTOMER SAYS THE ENGINE IS OVERHEATING WHILE DRIVING THERE IS A COOLANT LEAK ON THE PASS SIDE OF ENGINE REPORT PLEASE 100 DED 7750 DED REPEAT
Tech Comments: PRESSURE TEST COOLANT 15 16PSI FOR ABOUT 15MIN VERIFY CONCERN FOUND THE HEATER VALVE LEAKING COOLANT REPLACE VALVE TOP OF COOLANT ROAD TEST OK
1FMSU43P04EC04797 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-JAN-2004 19-FEB-2004 152054 USA 30 5C02 050100 F81Z 4635 AB N24 42 42131
AWS Claim Key: 9852995 Trx Code: 0711D Labor Hrs: 1.4
Dlr Cd-Sub Cd: 04572 - * Name: RUSSELL & SMITH FORD, INC. Ph: 713-6634111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2006 Doc #:02859551
Cust Comments: CUST STS THERE IS EXCESSIVE VIBRATION FROM REAR WHEN TRAVELING OVER 45MPH. HAS ALL NEW TIRES
Tech Comments: REPLACE REAR U JOINT BEARING CAME APART
1FMSU43P04EC04797 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-JAN-2004 19-FEB-2004 152054 USA 36 7W06 011409 1F2Z 14A626 AAA L20 42 47064
AWS Claim Key: 10970348 Trx Code: 0711D Labor Hrs: 0.9
Dlr Cd-Sub Cd: 04572 - * Name: RUSSELL & SMITH FORD, INC. Ph: 713-6634111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2007 Doc #:03986051
Cust Comments: CUSTOMER STATES THE KEYLESS ENTRY PAD IS MALFUNCTIONING
Tech Comments: IDS TESTED RETREIVED NO CODES AND USING DATALOGGER IN IDS THRU OPERATION OF KEYLESS ENTRY PAD FOUND BUTTONS INTERMITTANTLY OPERATING AND WITH REMOVAL OF LF DR TRIM PNL REPLACED KEYLESS ENTRY PAD ON DR AND NOW IS OPERATING AS DESIGNED
1FMSU43P04EC04797 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-JAN-2004 19-FEB-2004 152054 USA 46 6Y20 000000 * TAP1 * A99 82 67000
AWS Claim Key: 12370420 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-NOV-2007 Doc #:08119251
Cust Comments: CUSTOMER STATES VEHICLE STALLS
Tech Comments: 5 TAP DAYS OF RENTAL REQUESTED FOR REPAIRS PERFORMED ON 11 16 07 ON ROW80043 ENTERPRISE INV# D583107. CUSTOMER DID NOT INFORM DEALER HE RENTED CAR
1FMSU43P04EC04797 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-JAN-2004 19-FEB-2004 152054 USA 46 2H01 030407 4C3Z 6K682 CBRM L65 42 67000
AWS Claim Key: 12314885 Trx Code: E72 Labor Hrs: 18.8
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-NOV-2007 Doc #:08004351
Cust Comments: CUST STATES VEHICLE STALLED WHILE DRIVING BLOWING OUT SMOKE, AND OIL
Tech Comments: VERIFY CONCERN ENGINE PERFORMED DIAG PPT 1 22 NO CODES. PINPOINT STEPS COOLING SYSTEM PRESSURE TEST FOUND EGR COOLER LEAKING.REPLACE EGR AND OIL COLLERS AND OIL FILTER ADAPTER AND STAND PIPE. STAND PIPE WAS MELTED FROM ENGINE BEING EXTREMELY OVERHEATED.MELTED STAND PIPE CAUSED OIL CONTAMINATION. FOUND PLASTIC IN TURBO DRAIN AND IN TURBO AND VGT SOLENOID DUE TO PLASTIC IN TURBO.RUN COMPRESSION TEST
1FMSU43P04EC04797 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-JAN-2004 19-FEB-2004 152054 USA 48 2G01 03XXXX 4C3Z 12B599 AARM E29 42 65705
AWS Claim Key: 12416649 Trx Code: E72 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-JAN-2008 Doc #:08246151
Cust Comments: CUST STATES VEHICLE DIES WHEN ACCELLERATING FROM A STOP. WHEN THIS HAPPENS, THE GLOW PLUG LIGHT COMES ON AND THE ENGINE LIGHT COMES ON
Tech Comments: ENGINE PERF DIAG PPT 1 22 CODES P2614 AND P2617 PINPOINT STEPS TIME TO DIAGNOSE AND REPLACE FICM AND REPROGRAMM UNABLE TO ROAD TEST OFF PARKING LOT DUE TO BRAKE AND TURN SIGNAL LIHTS INOP CUST DECLINED ANY DIAG OR REPAIRS ON LIGHTS. RETEST OK AT THIS TIME. NO STALLING AT THIS TIME. VERFIED MILES CURRENT MILEAGE CORRECT
1FMSU43P04EC04797 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-JAN-2004 19-FEB-2004 152054 USA 50 2E06 030008 4C3Z 9A543 AARM D02 42 68404
AWS Claim Key: 12554052 Trx Code: E88 Labor Hrs: 8.5
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-MAR-2008 Doc #:08533251
Cust Comments: CUST STATES VEHICLE DIED WHILE DRIVING AND WOULD NOT START
Tech Comments: VERIFY CONCERN HARD NO START DIAG CODE P2290 PINPOINT STEPS MONITOR AND RECORD PIDS FOUND 135 PSI ICP PRESSURE.ACCESS & INSPECT IPR FOUND IPR SCREEN DAMAGED FROM PUMP COMING APART.TIME TO DIAG AND REPL WORN HIGH PRESS PUMP AND IPR. CLEAR CODES & RETEST OK VEH STARTS RERUN EEC TEST CODE P0299 PINPOINT STEPS FOUND VGT SOLENOID STUCK REPL VGT RETEST OK.SIP 11 16 07 AT 1404 MILES CROSS
1FMSU43P04EC04797 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-JAN-2004 19-FEB-2004 152054 USA 51 2E06 030008 4C3Z 9A543 AARM D13 42 68406
AWS Claim Key: 12592792 Trx Code: E88 Labor Hrs: 12.1
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:31-MAR-2008 Doc #:08584151
Cust Comments: CUSTOMER STATES ENGINE RUNNING ROUGH
Tech Comments: VERIFY CONCERN. ENGINE PERF DIAG PPT 1 22.NO CODES. PINPOINT STEPS MONTITOR AND RECORD PIDS FOUND ICP PRESSURE ERRATIC GOING FROM 595 TO 1500 PSI AND FLCUTUATING AT IDLE. ACCESS ISP AND FOUND DEBRIS ON SCREEN ACCESS AND INSPECT OIL COOLER AND SCREEN SUSPECT CASTING SAND IN OIL COOLER FROM FACTORY DAMAGING IPR AND HIGH PRESSURE PUMP. SPW OIL COOLER, HIGHT PRESSURE PUMP AND IPR. CHANGE OIL AND FILTE
4play is offline
JohnNolen (05-13-2009)
My first diesel (used) ... what needs 2 b checked? 2004 psd Excursion olslyfox General Ford Truck and Excursion 6 02-28-2009 09:56 PM
build sheet for a 2004 Excursion... please!! olslyfox Ford Oasis requests 1 02-25-2009 04:56 AM
2004 6.0L Excursion jethrow Ford Oasis requests 0 11-28-2007 02:42 AM
2004 Excursion PSD Eddie Bauer 4x4 skygod Whats Been Sold 0 08-26-2007 02:06 AM
Excursion 6.0L Oasis Report Please beachbumcook Ford Oasis requests 1 02-14-2006 03:22 AM
