Oasis Req - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jammin60, this thread has received 2 replies and been viewed 912 times.
post #1 of 3 (permalink) Old 05-14-2009, 01:42 PM Thread Starter
jammin60's Avatar
Oasis Req
these are the last two i promiss i really have apperciated this it has been a valuable tool in looking for a truck. thanks
1FMSU43P54ED76467
1FTSW21P66EC98841
Thanks again!
jammin60 is offline
post #2 of 3 (permalink) Old 05-14-2009, 07:33 PM
4play's Avatar
here is #1
OASIS RESULT:
1FMSU43P54ED76467
USA
EN
05/14/2009
15:32:50
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/02/2004 BUILD DATE
06/02/2004 SALE MILEAGE
00245
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/22/2009
DEALER: Courtesy Ford
WARRANTY CLAIM NUMBER: 344338 ODOMETER: 077406M
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 9278AA SENDER-OIL PRES 001 6007D D1 POROSITY
000 9278A
77406 PERFORM MAJOR ENGINE CLEAN UP FOUND OIL PRESSURE SENDING UNIT LEAKING OIL.REPLACED SENDING UNIT RECKECK FOR OTHER OIL LEAKS..NO OTHER LEAKS FOU ND..
04/22/2009
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
77406 COMPLETED RECALL REPLACED EBP SENSOR.PERFORM PCM TCM FICM REPROGRAM...
04/22/2009
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
ROADTEST NO OTHER ISSUES
1FMSU43P54ED76467 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-JUN-2004 02-AUG-2004 148407 USA 10 3A03 * * * * * * 18754
AWS Claim Key: 5272823 Trx Code: 04B24 Labor Hrs: 11.4
Dlr Cd-Sub Cd: 01167 - * Name: SARASOTA FORD Ph: 941-3663673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:06041140
Cust Comments: 04B24 TRANSMISSION REVERSE PLANET REPLACEMENT
Tech Comments: COMPLETED REVERSE PLANET RECALL.R&I TRANS BENCH MOUNT FOR OVERHAUL,OVERHAULED TRANS OVERHAULED VALVE BODY,FLUSHED COOLER AND LINES,INSTALLED EXTERNAL FILTER ,REPLACED OTA COOLER,REPLACED INLINE FILTER,POST TEST DRIVE. 4X4 EXCURSION. 11.6HRS.
1FMSU43P54ED76467 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-JUN-2004 02-AUG-2004 148407 USA 10 2E05 100106 3C3Z 9B249 AB G29 28 18754
AWS Claim Key: 5254876 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 01167 - * Name: SARASOTA FORD Ph: 941-3663673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:06041151
Cust Comments: WATER IN FUEL LIGHT ON ADVISE.
Tech Comments: DIAG FOUND FUEL MANIFOLD WAS BAD SO CLEAN OUT FUEL PUMP AND INSTALL NEW MANIFOLD
1FMSU43P54ED76467 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-JUN-2004 02-AUG-2004 148407 USA 14 1H03 030008 4C3Z 9F452 A D42 42 25921
AWS Claim Key: 6775913 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 01167 - * Name: SARASOTA FORD Ph: 941-3663673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:08-SEP-2005 Doc #:07247751
Cust Comments: CUST STATES BLACK SMOKE COMMING FROM REAR END, SPUTTERS, LOSS OF POWER
Tech Comments: DIESEL DIAG FUEL PRESSURE ,PRESSURE TEST COOLANT ,CHECK CODE NO CODE ,PIN POINT TEST AND BCE TEST FOUND THAT EGR VAVLE WAS BAD SO REPLACE AND REPROGRAM PCM,TCM,FICM AND ALL IS GOOD NOW
1FMSU43P54ED76467 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-JUN-2004 02-AUG-2004 148407 USA 26 7H08 120403 5C7Z 19980 AB C05 42 43083
AWS Claim Key: 10161134 Trx Code: P05 Labor Hrs: 0
Dlr Cd-Sub Cd: 01167 - * Name: SARASOTA FORD Ph: 941-3663673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-AUG-2006 Doc #:00482252
Cust Comments: AC NOT WORKING
Tech Comments: NOT OPERATING PROPERLY REPLACE COMNTROL HEAD
1FMSU43P54ED76467 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-JUN-2004 02-AUG-2004 148407 USA 58 7K08 030008 F81Z 9278 AA L65 D1 77406
AWS Claim Key: 13144746 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01625 - * Name: COURTESY FORD Ph: 407-3286000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-APR-2009 Doc #:344338A
Cust Comments: CUSTOMER STATES LEAKING OIL(OIL COOLER) CHECK AND ADVISE
Tech Comments: 77406 PERFORM MAJOR ENGINE CLEAN UP FOUND OIL PRESSURE SENDING UNIT LEAKING OIL.REPLACED SENDING UNIT RECKECK FOR OTHER OIL LEAKS..NO OTHER LEAKS FOUND..
1FMSU43P54ED76467 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 02-JUN-2004 02-AUG-2004 148407 USA 58 * * * * * * * 77406
AWS Claim Key: 13144747 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 01625 - * Name: COURTESY FORD Ph: 407-3286000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-APR-2009 Doc #:344338B
Cust Comments: RECALL 05E15
Tech Comments: 77406 COMPLETED RECALL REPLACED EBP SENSOR.PERFORM PCM TCM FICM REPROGRAM...
AWS Claim Key: 13144748 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01625 - * Name: COURTESY FORD Ph: 407-3286000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-APR-2009 Doc #:344338C
Cust Comments: RECALL 59B01
Tech Comments: ROADTEST NO OTHER ISSUES
4play is offline
jammin60 (05-14-2009)
post #3 of 3 (permalink) Old 05-14-2009, 07:35 PM
4play's Avatar
here is #2
OASIS RESULT:
1FTSW21P66EC98841
USA
EN
05/14/2009
15:34:01
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
WARRANTY START DATE
08/31/2006 BUILD DATE
02/14/2006 SALE MILEAGE
EXTENDED COVERAGES
0994 - USA 2006 NEW 60/60,000 POWERTRAIN WARRANTY
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: VALUED CUSTOMER
OPTIONS:
EXPIRATION DATE: 08/31/2011
DISTANCE: 60,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 40919
ESP CONTRACT START DATE: 08/31/2006
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
04/09/2009
DEALER: Matthews-Currie Ford Company
WARRANTY CLAIM NUMBER: 034253 ODOMETER: 081919M
LABOR OP
CONDITION CODE
CONDITION DESC
9B246 KIT-FUEL SYSTEM SERV 000 081806C 42 DOES NOT OPERATE PROPERLY
5C3Z 9A332A HOSE ASY (FUEL HIGH 001 081806F
VERIFY LONG CRANK DIAG CODE P2291 PER 08 18 6 AIR PRESS TEST HEARD AIR LEAKI NG FROM FRONT OF ENG PERF UNDER VLV CVR LEAK TEST FND R/S OIL SUPPLY TUBE O- RING LEAKS REPL SUPPLY TUBE RETEST PASS
04/09/2009
LABOR OP
CONDITION CODE
CONDITION DESC
6C2Z 6K786AA CLAMP AIR COOLING 002 6007D 42 DOES NOT OPERATE PROPERLY
6C3Z 6C640A CONNECTION A/C DUCT 001 6646AH
PERFORM OIL LEAK DIAG FND HOT SIDE CAC ELBOW LEAKS AT TURBO REPL CAC ELBOW R ETEST PASS
1FTSW21P66EC98841 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-FEB-2006 31-AUG-2006 124543 USA 2 6N04 010802 5C3Z 16720 VA F06 05 3924
AWS Claim Key: 1968127 Trx Code: 1 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-OCT-2006 Doc #:00937351
Cust Comments: INSTALL SOP 3 BADGES PEELING PAINT
Tech Comments: EMBLEMS PEELING VERIFY CONCERN CLEAN AREA REPLACED THREE EMBLEMS RETEST PASS
1FTSW21P66EC98841 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-FEB-2006 31-AUG-2006 124543 USA 2 7D02 1703XX F37Z 13550 AA L26 42 3924
AWS Claim Key: 1968128 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-OCT-2006 Doc #:00937352
Cust Comments: LICENCE PLATE LT MISSING
Tech Comments: LIC PLT LIGHT INOP VERIFY CONCERN REPLACED LAMP ASSY RETEST PASS
1FTSW21P66EC98841 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-FEB-2006 31-AUG-2006 124543 USA 2 6X01 010907 6U5Z 17700 EA M06 42 5172
AWS Claim Key: 2131734 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2006 Doc #:01014851
Cust Comments: OWNER STATES THAT THE REAR VIEW MIRROR FELL OFF
Tech Comments: VERIFY CONCERN REPLACED INT REAR VIEW MIRROR RETEST PASS
1FTSW21P66EC98841 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-FEB-2006 31-AUG-2006 124543 USA 5 2H01 030407 5C3Z 6K682 DA N11 41 14196
AWS Claim Key: 2740574 Trx Code: S07 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2007 Doc #:01465651
Cust Comments: CUSTOMER STATES METAL ON METAL SOUND COMING FROM TURBO
Tech Comments: PERF DISEL DAIG VERIFY CONERN REMV AIR INTAKE TO TURBO FOUND COMPRESSOR WHEEL MAKING CONTACT WITH TURBO HOUSING REPL TURBO RETEST PASS
1FTSW21P66EC98841 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-FEB-2006 31-AUG-2006 124543 USA 32 2H01 031202 6C3Z 6C640 A L65 42 81919
AWS Claim Key: 8096298 Trx Code: E72 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2009 Doc #:03425304
Cust Comments: OWNER STATES THAT THERE IS AN OIL LEAK DR SIDE DRIPPING
Tech Comments: PERFORM OIL LEAK DIAG FND HOT SIDE CAC ELBOW LEAKS AT TURBO REPL CAC ELBOW RETEST PASS
1FTSW21P66EC98841 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 14-FEB-2006 31-AUG-2006 124543 USA 32 2E04 03XXXX * 9B246 * D03 42 81919
AWS Claim Key: 8096297 Trx Code: E72 Labor Hrs: 6
Dlr Cd-Sub Cd: 03591 - * Name: MATTHEWS-CURRIE FORD COMPANY Ph: 941-4886787 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2009 Doc #:03425303
Cust Comments: OWNER STATES THAT THE VEHICLE HAS LONGER THEN NORMAL CRANKING WHEN COLD
Tech Comments: VERIFY LONG CRANK DIAG CODE P2291 PER 08 18 6 AIR PRESS TEST HEARD AIR LEAKING FROM FRONT OF ENG PERF UNDER VLV CVR LEAK TEST FND R/S OIL SUPPLY TUBE O RING LEAKS REPL SUPPLY TUBE RETEST PASS
4play is offline
