OAISIS please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nummit, this thread has received 1 replies and been viewed 684 times.
post #1 of 2 (permalink) Old 05-14-2009, 02:05 PM Thread Starter
OAISIS please
1FTNW21P74ED53551
Thank you
nummit is offline
post #2 of 2 (permalink) Old 05-14-2009, 07:36 PM
4play's Avatar
OASIS RESULT:
1FTNW21P74ED53551
USA
EN
05/14/2009
15:35:59
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/02/2004 BUILD DATE
05/08/2004 SALE MILEAGE
00024
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0711 - USA 2004 NEW 60/75,000 PREMIUMCARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: JETTY WRIGHT
OPTIONS:
EXPIRATION DATE: 10/02/2009
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 02635
ESP CONTRACT START DATE: 10/02/2004
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
1FTNW21P74ED53551 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-OCT-2004 152015 USA 0 5K06 * * * * * * 9
AWS Claim Key: 1939471 Trx Code: 04C07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02635 - * Name: DOUG STANLEY FORD Ph: 972-2238050 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2004 Doc #:205867A
Cust Comments: GOODYEAR ATS TIRE INSPECTION AND OR REPLACEMENT
Tech Comments: 9 PERFORM TIRE INSPECTION. W 0.2 VERFIED THAT ALL 5 TIRES ARE LOAD RANGE E .
1FTNW21P74ED53551 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-OCT-2004 152015 USA 8 1H03 030008 4C3Z 9F452 A E29 41 21090
AWS Claim Key: 5094816 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 02635 - * Name: DOUG STANLEY FORD Ph: 972-2238050 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2005 Doc #:223246A
Cust Comments: CK ENGINE LIGHT ON
Tech Comments: 21090 VERIFI CONCERN AND RUN DIA SHEET 1 THRU 5 AND FOUND CODES 2285 AND 0404 DO THE PINPOINT TEST STARING AT Q2 AND FOUND THE WIRING AND THE PCM CKED FINE .THE ICP EVEN PASSED REPLACED THE EGR VALVE AND REFLASHED THE PCM FICM AND THE TCM TO THE LATEST CAL. THEN ORDER AN ICP SENSOR MAY HAVE A BAD SPOT IN IT. UNIT NEVER DIED GIVE IT BACK TO THE CUSTOMER UNITL THE NEW SENSOR COMES
1FTNW21P74ED53551 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-OCT-2004 152015 USA 9 3A03 * * * * * * 26053
AWS Claim Key: 5535347 Trx Code: 04B24 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 02635 - * Name: DOUG STANLEY FORD Ph: 972-2238050 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-JUN-2005 Doc #:226017B
Cust Comments: RECALL 04B24 TORQSHIFT TRANS LOW REVERSE GEAR SET PINION SHAFT
Tech Comments: 26055 RECALL INSTALL LOW REVERSE GEAR SET PER RECALL,04B24N 6.4 HRS
1FTNW21P74ED53551 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-OCT-2004 152015 USA 9 2E06 030008 4C3Z 9F838 AB D41 42 26053
AWS Claim Key: 5535346 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02635 - * Name: DOUG STANLEY FORD Ph: 972-2238050 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-JUN-2005 Doc #:226017A
Cust Comments: ENGINE RUNNING ROUGH (INSTALL SOP)
Tech Comments: 26053 VERIFY CONCERN INSTALL A NEW ICP AND THEN RUN THE KOER TEST P1000 RUNS FINE
1FTNW21P74ED53551 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-OCT-2004 152015 USA 15 7N02 011105 4C3Z 1523394 AA G07 42 46797
AWS Claim Key: 8069748 Trx Code: 0711D Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02635 - * Name: DOUG STANLEY FORD Ph: 972-2238050 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-DEC-2005 Doc #:240963A
Cust Comments: C S REAR WINDOW WILL NOT ALWAYS CLOSE
Tech Comments: 46797 SUBLET TO RENFRO INSTALL SLIDING BACK GLASS WINDOW MOTOR BURNED OUT MOTOR,BCE.TEST,PIN POINT TEST.
1FTNW21P74ED53551 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-OCT-2004 152015 USA 15 * * * * * * * 46797
AWS Claim Key: 8069752 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02635 - * Name: DOUG STANLEY FORD Ph: 972-2238050 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-DEC-2005 Doc #:240963E
Cust Comments: ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 FOR DETAILS 59B01
Tech Comments: 46799 TEST DRIVE THE UNIT FEELS FINE
AWS Claim Key: 8069751 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02635 - * Name: DOUG STANLEY FORD Ph: 972-2238050 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-DEC-2005 Doc #:240963D
Cust Comments: EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM AND ENGINE CONTR OL MODULE RECALIBRATIONS 05E15
Tech Comments: 46799 PERFORM RECALL 05E15 AND REFLASH THE PCM AND TC M
AWS Claim Key: 8069750 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02635 - * Name: DOUG STANLEY FORD Ph: 972-2238050 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-DEC-2005 Doc #:240963C
Cust Comments: RECALL 05S34 04 F250 350 450 550; EXCURSION; & E350 450 WITH 6.0L DIESEL FUEL INJECTOR CONTROL MODULE WIRING HARNESS REPAIR
Tech Comments: 46797 PERFORM RECALL 05S34
1FTNW21P74ED53551 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2004 02-OCT-2004 152015 USA 15 5G04 040100 1C3Z 5K483 BB N50 42 46797
AWS Claim Key: 8069749 Trx Code: 0711D Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02635 - * Name: DOUG STANLEY FORD Ph: 972-2238050 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-DEC-2005 Doc #:240963B
Cust Comments: C S HEARS A POPPING FRONT END WAS TOLD MAY HAVE BAD BRUSHING
Tech Comments: 46799 VERFIED POPPING NOISE IN FRONT END. W PERFORM VISUAL INSPECTION OF SUSPENSION COMPONENTS.FOUND RIGHT SIDE SWAY BAR END LINK BROKEN OUT OF BUSHING LEFT FRONT END LINK BUSHINGT TWISTED REMOVED AND REPLACED WITH 2 NEW SWAY BAR END LINKS AND VERFIED REPAIRS.
4play is offline
nummit (05-14-2009)
Oaisis please. duck02 Ford Oasis requests 2 11-05-2007 04:20 AM
Oaisis Please dropped_dually Ford Oasis requests 1 09-27-2007 09:18 PM
OAISIS Please skipped_link Ford Oasis requests 1 07-19-2007 02:59 AM
Oaisis please nummit Ford Oasis requests 2 05-29-2006 03:45 PM
Can I get an Oaisis Mud King Ford Oasis requests 1 03-03-2006 12:51 AM
