oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by yadaddy99, this thread has received 1 replies and been viewed 395 times.
post #1 of 2 (permalink) Old 05-17-2009, 05:11 PM Thread Starter
oasis please
1FTWW32P14EC06604 thanks for all your help
yadaddy99 is offline
post #2 of 2 (permalink) Old 05-18-2009, 04:11 PM
4play's Avatar
OASIS RESULT:
1FTWW32P14EC06604
USA
EN
05/18/2009
12:10:15
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
6 SPEED MANUAL AXLE CODE
F2 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/10/2004 BUILD DATE
01/14/2004 SALE MILEAGE
00013
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTWW32P14EC06604 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 14-JAN-2004 10-FEB-2004 121692 USA 0 6Y05 000001 * TDRIVE * A96 82 5
AWS Claim Key: 372261 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2004 Doc #:173010D
Cust Comments: DIESEL PDI ROAD TEST
Tech Comments: 5 PERFORM PDI PER FORD
1FTWW32P14EC06604 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 14-JAN-2004 10-FEB-2004 121692 USA 0 * * * * * * * 5
AWS Claim Key: 372260 Trx Code: TDE Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2004 Doc #:173010C
Cust Comments: LEFT FRONT WHEEL SCRATCHED DURING TRANSIT
Tech Comments: 5 REPLACE LEFT FRONT WHEEL (SCRATCHED IN TRANSIT) DISMOUNT TIRE INSTALL ON NEW RIM, BALANCE INSTALL ON TRUCK
AWS Claim Key: 430040 Trx Code: TDE Labor Hrs: 25
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2004 Doc #:173010B
Cust Comments: THE OIL PAN IS DENTED DURNING TRANSIT
Tech Comments: 5 REPLACE OIL PAN REMOVE THE FOLLOWING ITEMS TRANS, DRIVESHAFT ASSY CLUTCH SLAVE, TRANS CROSSMEMBER, TRANS LINES,STARTER, BLOCK HEATER PLUG, DOWNPIPE, HEADER PANEL, GRILL L 7 R TURN SIGNALS, FRON AC CONDENSER, EVAC AC SYSTEM AIR CHARGE COOLER DRAIN COOLING SYSTEM, REMOVE RADIATOR, FAN, FAN SHROUD ASSY AIR CHARGE TUBES, BELT AC COMPRESSOR PS PUMP RH BATTERY AND TRAY ASSY, ENGINE ELECTRICAL HARNESS
AWS Claim Key: 372259 Trx Code: TDE Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2004 Doc #:173010A
Cust Comments: WIPER BLADES MISSING NOTED DURING TRANSIT
Tech Comments: 5 INSTALL TWO WIPER BLADES
1FTWW32P14EC06604 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 14-JAN-2004 10-FEB-2004 121692 USA 2 2E05 100106 3C3Z 9B249 AB G29 42 7356
AWS Claim Key: 585071 Trx Code: 1 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 00981 - * Name: MAC EASLER FORD, INC. Ph: 828-6934281 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:25-MAR-2004 Doc #:175161C
Cust Comments: CUST STATES WATER IN FUEL LIGHT ON
Tech Comments: 7356 DIAG KOEO,FOUND P2269 DRAIN WATER IN FUEL AND RETEST LIGHT STILL ON REMOVE WATER INFUEL MOD AND CLEAN AND INSTALL NEW SESNOR AND RETEST VERIFY REPAIR
1FTWW32P14EC06604 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 14-JAN-2004 10-FEB-2004 121692 USA 11 1H03 030008 3C3Z 9F452 AC D36 41 35204
AWS Claim Key: 3040714 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 08473 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 423-2823000 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2004 Doc #:05416101
Cust Comments: D36 CUSTOMER STATES PULLING LOAD UP HILLS THE ENG. IS SURGING ALONG
Tech Comments: VERIFIED CONCERN.RAN OASIS NO TSBS OR SSMS.RAN PERFORMANCE DIAG AND FOUND EGR VALVE STICKING.REPLACED EGR VALVE.CLEARED CODES AND RETEST.
1FTWW32P14EC06604 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 14-JAN-2004 10-FEB-2004 121692 USA 11 2G05 031405 * RECAL * G29 42 35204
AWS Claim Key: 3112861 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 08473 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 423-2823000 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2004 Doc #:05416104
Cust Comments: CUSTOMER STATES THE FUEL LIGHT COMES ON WORSE AFTER FILL UP
Tech Comments: 1 VERIFIED CONCERN.RAN OASIS.REPROGRAMMED PCM PER TSB 04 19 04 TEST DROVE AND RETEST.
1FTWW32P14EC06604 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 14-JAN-2004 10-FEB-2004 121692 USA 19 2H01 * * * * * * 45135
AWS Claim Key: 6508188 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08473 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 423-2823000 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2005 Doc #:06298501
Cust Comments: RECALL ON AIR COOLER DUCT 05B29 SOP
Tech Comments: 1 REPLACED CAC HOSE TO COMPLETE RECALL
1FTWW32P14EC06604 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 14-JAN-2004 10-FEB-2004 121692 USA 19 * * * * * * * 45135
AWS Claim Key: 6508187 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08473 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 423-2823000 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2005 Doc #:06298502
Cust Comments: RECALL ON FUEL INJ. CONTROL WIRING 05S34 SOP
Tech Comments: INSTALLED FICM HARNESS REPAIR KIT AND ICP WIRING TO COMPLETE RECALL
AWS Claim Key: 6574219 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08473 - * Name: RAMEY FORD LINCOLN MERCURY Ph: 423-2823000 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2005 Doc #:06298506
Cust Comments: RECALL 59B01
Tech Comments: COMPLETED RECALL
1FTWW32P14EC06604 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 14-JAN-2004 10-FEB-2004 121692 USA 26 * * * * * * * 47251
AWS Claim Key: 8782389 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 01987 - * Name: FRIENDSHIP FORD Ph: 423-6526200 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2006 Doc #:16129703
Cust Comments: CUSTOMER REQUEST RECALL 05E15
Tech Comments: PER RECALL REPLACED EXHAUST BACK PRESSURE SENSOR & REPROGRAMMED ENGINE MODULES PER RECALL
AWS Claim Key: 8782388 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01987 - * Name: FRIENDSHIP FORD Ph: 423-6526200 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2006 Doc #:16129704
Cust Comments: CUSTOMER REQUEST RECALL 59B01
Tech Comments: MANUFACTURE REQUIREMENT TEST DROVE VEHICLE PER RECALL
1FTWW32P14EC06604 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 14-JAN-2004 10-FEB-2004 121692 USA 29 2H01 030008 4C3Z 6K682 BA D42 42 47489
AWS Claim Key: 9598611 Trx Code: S07 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 01987 - * Name: FRIENDSHIP FORD Ph: 423-6526200 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2006 Doc #:16466001
Cust Comments: CUSTOMER STATES VEHICLE HAS LOW POWER. WHEN LETTING OFF GAS THIER IS A FLUTTERING NOISE.
Tech Comments: VERIFY CONCERN. PERFORMED DIESEL PERFORMANCE BOOST TEST. EBP 53PSI, VGT 15%, MGP 29PSI. PERFORMED PINPOINT TEST VGT TEST FOUND UNISON RING IN TURBO STUCK. REMOVED AND REPLACED TURBO. TEST DROVE TO VERIFY REPAIR. NORMAL OPERATION.
1FTWW32P14EC06604 T/F7 F T/BC T/CD T/B A1 T/VG T/YB 14-JAN-2004 10-FEB-2004 121692 USA 48 1H03 030008 4C3Z 9F452 A D41 55 55549
AWS Claim Key: 12360582 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01995 - * Name: FAIRWAY FORD Ph: 423-5783600 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:28-DEC-2007 Doc #:05935501
Cust Comments: CUSTOMER STATES ENGINE HAS HESIATION AND EXCESSIVE BLACK SMOKE COMING FROM TAILPIPE
Tech Comments: CK OUT AND REPLACED THE EGR VALVE PER TSB 07 21 09
4play is offline
