Oasis Request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by FX4Powerstroke, this thread has received 2 replies and been viewed 918 times.
post #1 of 3 (permalink) Old 05-18-2009, 06:49 PM Thread Starter
Oasis Request
Due to some financial issues I was having in the beginning of the year I sold my 2008 6.4L F-250. Thankfully I'm back up on my feet and I'm having diesel withdrawal so I'm looking at getting back into a diesel and ending my cravings, lol. I'm currently looking at two 6.0L F-250's and wanted to get there medical records (OASIS) to see if they are worth the money. Both are priced at $25k and are under 65k miles. Thanks for the help.
Truck # 1 2005 F-250 Lariat with 59,128 miles
VIN # 1FTSW21P15ED19173
Truck # 2 2006 F-250 XLT with 64,510 miles
VIN # 1FTSW21P96EB36041
2003 GMC Sierra 2500 HD Duramax
2008 F-250 6.4L CC SB - Unfotunately had to sell my baby but I'm looking into getting back into a Diesel. (Sold January 2009)
FX4Powerstroke is offline
post #2 of 3 (permalink) Old 05-18-2009, 07:13 PM
4play's Avatar
#1 1FTSW21P15ED19173
OASIS RESULT:
1FTSW21P15ED19173
USA
EN
05/18/2009
15:10:10
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
5F710D0A
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/06/2005 BUILD DATE
04/21/2005 SALE MILEAGE
00017
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
03/11/2009
DEALER: Santa Margarita Ford
WARRANTY CLAIM NUMBER: 031499 ODOMETER: 056202M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F9
000 6005F10
000 6005F18A
000 12650D84
000 9527AR
126 ROB M)VERIFIED VEHICLE RUNS ROUGH IN AM THEN GETS BETTER EEC TEST RETRI EVED DTC P0275 RECALIBRATED CONTROL MODULES TEST DROVE COLD STARTED VEHICE L VEHICLE STILL RUNS ROUGH PERFORMED FUEL PRESSURE TEST 56 PSI PERFORMED P OWER BALANCE TEST CYLINDER #5 NON CONTRIBUTING PERFORMED RELATIVE COMPRESSI ON TEST PASS REMOVED AND INSEPCTED INJECTOR NO PROBLEMS FOUND PC ED REM
03/11/2009
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640A CONNECTION A/C DUCT 001 6007D 42 DOES NOT OPERATE PROPERLY
6C3Z 6C640B CONNECTION A/C DUCT 001 6083A
6C2Z 6K786AA CLAMP AIR COOLING 002 6646AH
6C3Z 6K786CA CLAMP AIR COOLING 001
6C3Z 6K786EA CLAMP AIR COOLING 001
3C3Z 6701B CRANKSHAFT REAR SEAL 001
OSP 003
TA 31 MOTORCRAFT BATTERY 001
W300013 004
W300051 004
378941S441 006
3C3Z 6D083AA GASKET-RR COVER 001
OP-CODES ABOVE. 610 VERIFY ENGINE OIL LEAKING ON ENGINE AND UNDER CHASSIS, INSTALL ENGINE OIL DYE FLUIDS, PERFORM VEH TEST DRIVE 6 MILES AND USED BLA CK LIGHT TO DIAG FOR ENGINE OIL LEAKING, CAUSE SOURE OF LEAK CAME FROM UPER START MOTOR AND HOT SIDE CAC HOSES LEAKING CORRECTION ENGINE OIL LEAKING RE PAIR TO INCLUDE RR TRANS REMOVED STARTER MOTOR REMOVED REAR ENGINE COVER ***
1FTSW21P15ED19173 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-APR-2005 06-JUL-2005 171057 USA 1 6Q05 011901 5C3Z 17D957 BAPTM B69 34 458
AWS Claim Key: 1760566 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 05414 - * Name: POWER FORD TUSTIN Ph: 714-8323300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-JUL-2005 Doc #:12925901
Cust Comments: CUSTOMER STATES FRONT UPPER BUMPER TRIM APPEARS TO BE DEFORMED. 336 1953 B69 ACES APPROVAL CODE PAAGX
Tech Comments: SUBLET TO CALIFORNIA AUTO COLLISION FOR REPAIR SUBLET VENDOR PAINTED AND REPLACED DEFECTIVE BUMPER TRIM.
1FTSW21P15ED19173 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-APR-2005 06-JUL-2005 171057 USA 16 * * * * * * * 15330
AWS Claim Key: 6215457 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00712 - * Name: CAPISTRANO FORD Ph: 949-2407000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2006 Doc #:37733202
Cust Comments: PERFORM 05B32 DE GAS BOTTLE FILL LEVEL LABEL RECALL
Tech Comments: PERFORMED RECALL 05B32 DE GAS BOTTLE FILL LEVEL ADDED LABEL AND ADJUSTED THE COOLANT LEVEL PER RECALL 05B32
AWS Claim Key: 6215458 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00712 - * Name: CAPISTRANO FORD Ph: 949-2407000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2006 Doc #:37733201
Cust Comments: PERFORM 05E16 ENGINE CONTROL MODULE RECALIBRATION RECALL
Tech Comments: PERFORMED RECALL 05E16 ENGINE CONTROL MODULE RECALIBRATION UPDATED THE PCM TO 5U7A 12A650 CVD
1FTSW21P15ED19173 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-APR-2005 06-JUL-2005 171057 USA 17 6N04 010802 5C3Z 16720 VA B66 42 15355
AWS Claim Key: 6538957 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 05414 - * Name: POWER FORD TUSTIN Ph: 714-8323300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-OCT-2006 Doc #:161628A
Cust Comments: CLIENT STATES RT AND LEFT FRONT AND REAR TAIL GATE F250 ELBLEMS PEELING CK AND ADVISE B66 2659 336 LARIAT SUPER DURTY
Tech Comments: 15355 CC 81 CP 16720 42528 NAME PLATES (MT 16720 1.5) REPLACE BOTH FRONT FENDER NAME PLATES AND REAR TAILGATE NAME PLATES,REMOVE OLD ADHESIVE AND CL EAN OFF AFFECTED AREA TO INSTALL NEW PLATES (PAINT PEELING OFF) AUTH CODE P14GR
1FTSW21P15ED19173 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-APR-2005 06-JUL-2005 171057 USA 29 1F06 030304 * 8A080 * N11 42 31577
AWS Claim Key: 8954697 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 05414 - * Name: POWER FORD TUSTIN Ph: 714-8323300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-NOV-2007 Doc #:181839B
Cust Comments: N11 DIAG UNUSUAL ENGINE NOISE AT IDLE CUSTOMER STATES THERE IS A WHINING NOISE WHILE TURNING BACKING UP. 336 1953 N11
Tech Comments: 31577 CP 3A719 8080A .6, M TIME .5 FOUND LEAK COMING FROM POWER STEERING PRESSURE HOSE TO JUMPER LINE. REMOVE COOLANT RECOVERY BOTTLE TO ACCESS AND TIGHTEN (LOOSE) FITTINGS ON PRESSURE HOSE TO JUMPER LINE. USED M TIME CLEAN THREADS PUT TEFLON AND TIGHTEN FITTINGS AND BLEED AIR OUT OF POWER STEER. SYSTEM.
1FTSW21P15ED19173 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-APR-2005 06-JUL-2005 171057 USA 31 6Y20 000000 * TAP1 * A99 82 34686
AWS Claim Key: 9319961 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 05414 - * Name: POWER FORD TUSTIN Ph: 714-8323300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:14-JAN-2008 Doc #:185022A
Cust Comments: FRAC LOANER RO 184977
Tech Comments: 34686 LOANER RO 184977 2 DAYS
1FTSW21P15ED19173 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-APR-2005 06-JUL-2005 171057 USA 45 2E03 030402 4C3Z 9E527 BRM E29 42 56202
AWS Claim Key: 10830136 Trx Code: S07 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 08699 - * Name: SANTA MARGARITA FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-MAR-2009 Doc #:031499A
Cust Comments: INSPECT AND DIAGNOSE CAUSE OF ENGIEN LIGHT ON AND OFF, ENGIEN RUNS ROUGH COLD. ADVISE
Tech Comments: 126 ROB M)VERIFIED VEHICLE RUNS ROUGH IN AM THEN GETS BETTER EEC TEST RETRIEVED DTC P0275 RECALIBRATED CONTROL MODULES TEST DROVE COLD STARTED VEHICEL VEHICLE STILL RUNS ROUGH PERFORMED FUEL PRESSURE TEST 56 PSI PERFORMED POWER BALANCE TEST CYLINDER #5 NON CONTRIBUTING PERFORMED RELATIVE COMPRESSION TEST PASS REMOVED AND INSEPCTED INJECTOR NO PROBLEMS FOUND PC ED REM
1FTSW21P15ED19173 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-APR-2005 06-JUL-2005 171057 USA 45 1D05 031004 3C3Z 6D083 AA L65 42 56202
AWS Claim Key: 10830137 Trx Code: E72 Labor Hrs: 6.1
Dlr Cd-Sub Cd: 08699 - * Name: SANTA MARGARITA FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-MAR-2009 Doc #:031499B
Cust Comments: INSPECT AND DIAGNOSE CAUSE OF ENGIEN LEAKS OIL TOP AND BOTTOM. ADVISE
Tech Comments: OP CODES ABOVE. 610 VERIFY ENGINE OIL LEAKING ON ENGINE AND UNDER CHASSIS, INSTALL ENGINE OIL DYE FLUIDS, PERFORM VEH TEST DRIVE 6 MILES AND USED BLACK LIGHT TO DIAG FOR ENGINE OIL LEAKING, CAUSE SOURE OF LEAK CAME FROM UPER START MOTOR AND HOT SIDE CAC HOSES LEAKING CORRECTION ENGINE OIL LEAKING REPAIR TO INCLUDE RR TRANS REMOVED STARTER MOTOR REMOVED REAR ENGINE COVER ASSY CLEAN ALL PARTS
4play is offline
FX4Powerstroke (05-18-2009)
post #3 of 3 (permalink) Old 05-18-2009, 07:14 PM
4play's Avatar
#2 1FTSW21P96EB36041
OASIS RESULT:
1FTSW21P96EB36041
USA
EN
05/18/2009
15:13:59
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
6F710D0A
WARNING MESSAGES
VEHICLE MAY QUALIFY FOR ADDITIONAL POWERTRAIN SERVICE PART WARRANTY
Click here to view Powertrain Service Part Warranty Form
ARN MESSAGES
WARRANTY START DATE
12/30/2005 BUILD DATE
10/04/2005 SALE MILEAGE
00143
EXTENDED COVERAGES
07/31/2008
DEALER: Kieffe & Sons Ford
WARRANTY CLAIM NUMBER: 066011 ODOMETER: 058028M
LABOR OP
CONDITION CODE
CONDITION DESC
XT 6QSP 003 7000F 42 DOES NOT OPERATE PROPERLY
5C3Z 7000KRM TRANSMISSION ASY-AUT 001 7000F45
87034S94 001 7095C
000 7000A
000 7000AXQ
000 7000AZJ
000 7000A11
000 7000A43
AUTO TRANS DIAG P0700 720 722 741 751 766 1744 1783 2700 2703 FLUID BLACK AN D BURNT SMELLING BARELY ANY MOVEMENT IN DRIVE OR REVERSE AT HIGH RPM REMOVE TRANS TEAR DOWN AND DISASSEMBLE FOUND LO R AND R TRANS R AND R INLINE ELEMEN T R AND I BUMPER R AND R COOLER ASSEMBLY FLUSH TRANS LINES INDIVIDUALLY RESE T KAM ROAD TEST AND RETEST
07/17/2008
DEALER: Crandall Ford-Mercury
WARRANTY CLAIM NUMBER: 101313 ODOMETER: 056621M
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65750 MOTORCRAFT BATTERY 000 10654C 42 DOES NOT OPERATE PROPERLY
000 10654C1
NOTED CONCERN. PERFORM CHARGING SYSTEM TEST. REPLACED ONE BATTERY
1FTSW21P96EB36041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-OCT-2005 30-DEC-2005 171439 USA 21 2E06 100101 6C3Z 9275 BA E29 42 39605
AWS Claim Key: 4575300 Trx Code: 0701D Labor Hrs: 2.3
Dlr Cd-Sub Cd: 11220 - * Name: JIM BURKE LINCOLN-MERCURY Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-SEP-2007 Doc #:056483A
Cust Comments: CUST STS TRANS LIGHT ON
Tech Comments: 39605 MIL ON EEC TEST KOEO PASS CONT P0460 KOER PASS PERFORM PINPOINT CHECK GAUGE OPERATION GAUGE OK SHOWS EMPTY ALL THE TIME REPLACE FUEL SENDER INSIDE TANK AT 3 4 TANK NOW CLEAR CODE AND RETEST OK NO TRANS LIGHT OR TRANS CODE PRESENT ROAD TESTS OK COND CODE 42
1FTSW21P96EB36041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-OCT-2005 30-DEC-2005 171439 USA 32 7A01 140101 BXT 65 750 C25 42 56621
AWS Claim Key: 6677169 Trx Code: SPW Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08328 - * Name: CRANDALL FORD-MERCURY Ph: 435-6473673 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:17-JUL-2008 Doc #:101313B
Cust Comments: CUSTOMER STATES VEHICLE WILL NOT START
Tech Comments: NOTED CONCERN. PERFORM CHARGING SYSTEM TEST. REPLACED ONE BATTERY
1FTSW21P96EB36041 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-OCT-2005 30-DEC-2005 171439 USA 32 3A11 070100 5C3Z 7000 KRM P66 42 58028
AWS Claim Key: 6973923 Trx Code: 0701D Labor Hrs: 9.9
Dlr Cd-Sub Cd: 05503 - * Name: KIEFFE & SONS FORD Ph: 661-8242477 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2008 Doc #:06601103
Cust Comments: CUSTOMER STATES THAT TRANS HAD A VERY HARSH ENGAGEMENT INTO FIRST GEAR FELT SLIPPING IN THIRD AND THE TOW HAUL LIGHT IS FLASHING
Tech Comments: AUTO TRANS DIAG P0700 720 722 741 751 766 1744 1783 2700 2703 FLUID BLACK AND BURNT SMELLING BARELY ANY MOVEMENT IN DRIVE OR REVERSE AT HIGH RPM REMOVE TRANS TEAR DOWN AND DISASSEMBLE FOUND LO R AND R TRANS R AND R INLINE ELEMENT R AND I BUMPER R AND R COOLER ASSEMBLY FLUSH TRANS LINES INDIVIDUALLY RESET KAM ROAD TEST AND RETEST
4play is offline
Oasis request please! barry1me Ford Oasis requests 1 10-23-2007 01:29 AM
OASIS Request Please p38guy Ford Oasis requests 1 09-26-2007 09:27 PM
Oasis Request Please kawa Ford Oasis requests 1 09-24-2007 02:05 AM
OASIS Request, please... tallfarmboy Ford Oasis requests 1 11-23-2006 03:21 AM
OASIS Request tallfarmboy Ford Oasis requests 1 11-23-2006 03:20 AM
