oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 105vegas, this thread has received 2 replies and been viewed 488 times.
post #1 of 3 (permalink) Old 05-19-2009, 10:01 PM Thread Starter
105vegas's Avatar
oasis please
im looking at a couple of trucks and would like to know a bit about them
1ftww31p15ec70600
1FTSW21P65EC94061
thanks
105vegas is offline
post #2 of 3 (permalink) Old 05-20-2009, 05:05 AM
4play's Avatar
not find one yet, good luck! heres #1 1ftww31p15ec70600
OASIS RESULT:
1FTWW31P15EC70600
USA
EN
05/20/2009
01:04:01
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/22/2005 BUILD DATE
03/14/2005 SALE MILEAGE
00003
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
02/04/2009
DEALER: Zimmerman Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 015423 ODOMETER: 060157M
LABOR OP
CONDITION CODE
CONDITION DESC
W301390 001 081806B 42 DOES NOT OPERATE PROPERLY
5C3Z 9C968CA FUEL PRESSURE REG 001 081806C
9B246 KIT-FUEL SYSTEM SERV 000 081806F
VERIFIED CONCERNS VEHICLE RAN BUT NOW WONT START PERFORMED DIESLE DIAG NO ST ART P2291 P2290 LOW ICP PSI SEE ATTCHED TSB 08-18-6 PERFORMED DIAG STEPS PUT LINED INT TSB AIT TESTS AND REMOVED VALVE COVERS AND FOUNDORING FOR BLOCK OF F ON RH SIDE BROKEN AND PEICE WENT THROUGH IPR AND STUCK IPR REPLACED ORING ANF IPR REINSTALLED RETESTED RECHECKED OK NOW TETS DROVE MILES OUT 60161
09/17/2008
WARRANTY CLAIM NUMBER: 009300 ODOMETER: 056716M
LABOR OP
CONDITION CODE
CONDITION DESC
6007 ENGINE ASSY 000 42 DOES NOT OPERATE PROPERLY
TOWING INV# 70600 FOR LONG DISTANCE TO TO SHOP FROM IOWA EXIT 164 TO ST CHAR LES ILLINOIS.
08/25/2008
WARRANTY CLAIM NUMBER: 008355 ODOMETER: 056716M
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
INSTALLED DEGAS BOTTLE LABEL
08/25/2008
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 072109A 55 PLUGGED/RESTRICTED
6C3Z 8A080B COOLANT O/FLO BOTTLE 001 6005PA
F6DZ 8100A CAP ASY RADIATOR 001 081103A
VC 7B 003 081103B
3C3Z 9C165AA KIT-FU/FLTR SE 001 081103C
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 081103G
VERIFIED COCNERN AND PERFORMED DIAG AS PER ATTCHED TSB 08-11-3 FOUND EGR COO LER BLOWN AS PER TESTS ALSO P0404 P1335 RAN PRIOR APPROVAL CODE PAAHU REPLAC ED GR COOLER AND REPLACED BOTTLE AND CAP THAT FAILED TESTS VENTED COOLANT FR OM CYLS BY REMOVING GLOW PLUGS ALSO REPLACED EGR VALVE AS PER ATTCHED TSB 07 -21-9 FORD CODES P404 P1335 TEST DROVE OK NOW
1FTWW31P15EC70600 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAR-2005 22-MAR-2005 141432 USA 36 2E04 03XXXX 4C3Z 9B246 A D02 42 35980
AWS Claim Key: 9545972 Trx Code: E84 Labor Hrs: 8
Dlr Cd-Sub Cd: 01824 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: 630-5841800 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:13-FEB-2008 Doc #:09959051
Cust Comments: CRANKS WONT START
Tech Comments: FOUND HIGH PRESSURE FITTING BLOWN PERFORMED TSB 06 17 06
1FTWW31P15EC70600 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAR-2005 22-MAR-2005 141432 USA 42 * * * * * * * 56716
AWS Claim Key: 10313833 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01824 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: 630-5841800 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:25-AUG-2008 Doc #:00835540
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: INSTALLED DEGAS BOTTLE LABEL
1FTWW31P15EC70600 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAR-2005 22-MAR-2005 141432 USA 42 1H03 030008 5C3Z 9F452 AA F99 55 56716
AWS Claim Key: 10313834 Trx Code: S07 Labor Hrs: 12.2
Dlr Cd-Sub Cd: 01824 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: 630-5841800 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:25-AUG-2008 Doc #:00835551
Cust Comments: C S ENGINE IS BURNING COOLANT
Tech Comments: VERIFIED COCNERN AND PERFORMED DIAG AS PER ATTCHED TSB 08 11 3 FOUND EGR COOLER BLOWN AS PER TESTS ALSO P0404 P1335 RAN PRIOR APPROVAL CODE PAAHU REPLACED GR COOLER AND REPLACED BOTTLE AND CAP THAT FAILED TESTS VENTED COOLANT FROM CYLS BY REMOVING GLOW PLUGS ALSO REPLACED EGR VALVE AS PER ATTCHED TSB 07 21 9 FORD CODES P404 P1335 TEST DROVE OK NOW
1FTWW31P15EC70600 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAR-2005 22-MAR-2005 141432 USA 43 1A03 030101 * 6007 * D02 42 56716
AWS Claim Key: 10399290 Trx Code: E72 Labor Hrs: 0
Dlr Cd-Sub Cd: 01824 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: 630-5841800 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:17-SEP-2008 Doc #:00930051
Cust Comments: CUSTOMER IS REQUESTING REFUND FOR A TOW ON RO # 8355 , 56716ML ,08 27 08
Tech Comments: TOWING INV# 70600 FOR LONG DISTANCE TO TO SHOP FROM IOWA EXIT 164 TO ST CHARLES ILLINOIS.
1FTWW31P15EC70600 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAR-2005 22-MAR-2005 141432 USA 48 2E04 03XXXX * 9B246 * D21 42 60157
AWS Claim Key: 10748449 Trx Code: E72 Labor Hrs: 7.3
Dlr Cd-Sub Cd: 01824 - * Name: ZIMMERMAN FORD LINCOLN MERCURY, INC. Ph: 630-5841800 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:04-FEB-2009 Doc #:01542351
Cust Comments: STATES DIES OUT WHILE DRIVING WARM.
Tech Comments: VERIFIED CONCERNS VEHICLE RAN BUT NOW WONT START PERFORMED DIESLE DIAG NO START P2291 P2290 LOW ICP PSI SEE ATTCHED TSB 08 18 6 PERFORMED DIAG STEPS PUTLINED INT TSB AIT TESTS AND REMOVED VALVE COVERS AND FOUNDORING FOR BLOCK OFF ON RH SIDE BROKEN AND PEICE WENT THROUGH IPR AND STUCK IPR REPLACED ORING ANF IPR REINSTALLED RETESTED RECHECKED OK NOW TETS DROVE MILES OUT 60161
4play is offline
post #3 of 3 (permalink) Old 05-20-2009, 05:07 AM
4play's Avatar
and #2 1FTSW21P65EC94061
OASIS RESULT:
1FTSW21P65EC94061
USA
EN
05/20/2009
01:06:22
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
ARN MESSAGES
WARRANTY START DATE
06/22/2005 BUILD DATE
03/31/2005 SALE MILEAGE
EXTENDED COVERAGES
0701 - USA 2006 NEW 60/100,000 PREMIUMCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: DAVID ELLIOTT
OPTIONS:
EXPIRATION DATE: 06/22/2010
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 05965
ESP CONTRACT START DATE: 06/22/2005
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
1FTSW21P65EC94061 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-MAR-2005 22-JUN-2005 123198 USA 10 * * * * * * * 22294
AWS Claim Key: 4147813 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08719 - * Name: COUNTRY FORD Ph: 318-5743511 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:02277902
Cust Comments: 05B32 DEGAS BOTTLE FILL LEVEL LABEL INSTALL
Tech Comments: 1 COMPLETED
AWS Claim Key: 4147814 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08719 - * Name: COUNTRY FORD Ph: 318-5743511 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:02277901
Cust Comments: RECALL 05B35 ECM RECALIBRATION
1FTSW21P65EC94061 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-MAR-2005 22-JUN-2005 123198 USA 34 6Y20 000001 * MISC * A99 82 100975
AWS Claim Key: 9583787 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 05965 - * Name: WATSON QUALITY FORD Ph: 601-9567000 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2008 Doc #:015752A
Cust Comments: REFUND TO CUSTOMER PER TENA
Tech Comments: REFUND TO CUSTOMER PER TENA
4play is offline
