OASIS Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BombDocDiesel, this thread has received 1 replies and been viewed 785 times.
post #1 of 2 (permalink) Old 05-20-2009, 03:12 PM Thread Starter
TDG Mafia Goon
BombDocDiesel's Avatar
OASIS Report Please
1FTSW21P25EC59632 A friend's used truck having issues. I'm trying to see if the previous owner had them as well.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #2 of 2 (permalink) Old 05-21-2009, 08:46 PM
4play's Avatar
OASIS RESULT:
1FTSW21P25EC59632
USA
EN
05/21/2009
16:46:03
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
37 ENGINE CALIBRATION
5F710C0A
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/15/2005 BUILD DATE
03/01/2005 SALE MILEAGE
00008
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/28/2009
DEALER: Southwest Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 013169 ODOMETER: 060867M
LABOR OP
CONDITION CODE
CONDITION DESC
6K682 TURBO CHG-EXH DRIVE 000 081613F 42 DOES NOT OPERATE PROPERLY
W302676 001
W302677 001
6C3Z 9T515A KIT-TUBE TRBCH OIL R 001
5C3Z 9G489AARM KIT TRBCH CTR HSG RO 001
5C3Z 6F089BA ACTUATOR ASSY 001
1 KOEO, KOER, EGR FLOW TEST, TURBO BOOST TEST, RETRIEVED P0299 OVER-UNDER BOOST. PERFORMED PINPOINT TEST KA6 REMOVE TURBO AND INSPECT. PERFORMED TSB 0 8-16-13. REMOVED TURBO, INSPECT VANES, REPLACED CHRA AND INSTALLED TURBO. 08 1613F 4.0
09/30/2008
DEALER: Greenville Ford Lincoln-Mercur
WARRANTY CLAIM NUMBER: 027938 ODOMETER: 058120M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 072109A 55 PLUGGED/RESTRICTED
EGR VLV FAILED RPL EGR VLV PER TSB 072109
1FTSW21P25EC59632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 15-MAR-2005 171423 USA 1 2G01 03XXXX 4C3Z 12B599 AARM D02 42 1752
AWS Claim Key: 704080 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 20329 - * Name: DON SANDERSON FORD LINCOLN MERCURY Ph: *-* St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2005 Doc #:25667101
Cust Comments: CUST STS VEHICLE WAS TOWED IN, VEHICLE LOST POWER AND NOW WILL NOPT START
Tech Comments: PERFORMED DIESLE ENG HARD START DIAG SHEET.MONITORED FICM SYNCH PID.FICM NOT IN SYNCH. REMOVED DEGAS BOTTLE TO ACCESS FICM.REPLACED FICM. REPROGRAMED FICM.ROAD TEST ENG RUNS NORMAL RERAN QUICK TEST KOEO PASS KOER PASS
1FTSW21P25EC59632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 15-MAR-2005 171423 USA 14 * * * * * * * 27088
AWS Claim Key: 4610422 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05591 - * Name: EL CENTRO MOTORS Ph: 760-3528030 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-MAY-2006 Doc #:05743540
Cust Comments: 05E16 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: REPROGRAM PCM,TCM,FICM AS PER RECALL
AWS Claim Key: 4610423 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05591 - * Name: EL CENTRO MOTORS Ph: 760-3528030 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-MAY-2006 Doc #:05743541
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: INSTALL DEGASS BOTTLE LABEL AND ADJUST COOLANT LEVEL AS PER RECALL
1FTSW21P25EC59632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 15-MAR-2005 171423 USA 44 1H03 030008 5C3Z 9F452 AA E29 55 58120
AWS Claim Key: 10441812 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 02484 - * Name: GREENVILLE FORD LINCOLN-MERCURY Ph: 903-4557222 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2008 Doc #:02793851
Cust Comments: C S CHECK ENG LIGHT IS ON AT DASH.
Tech Comments: EGR VLV FAILED RPL EGR VLV PER TSB 072109
1FTSW21P25EC59632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 15-MAR-2005 171423 USA 51 2H01 03XXXX * 6K682 * E29 42 60867
AWS Claim Key: 10924003 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 03354 - * Name: SOUTHWEST FORD LINCOLN MERCURY Ph: 903-4557222 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-APR-2009 Doc #:01316901
Cust Comments: (E29) CHECK ENG LIGHT ON AT DASH
Tech Comments: 1 KOEO, KOER, EGR FLOW TEST, TURBO BOOST TEST, RETRIEVED P0299 OVER UNDERBOOST. PERFORMED PINPOINT TEST KA6 REMOVE TURBO AND INSPECT. PERFORMED TSB 08 16 13. REMOVED TURBO, INSPECT VANES, REPLACED CHRA AND INSTALLED TURBO. 081613F 4.0
4play is offline
BombDocDiesel (05-21-2009)
Please help with Oasis report vshortt Ford Oasis requests 3 03-02-2008 04:54 PM
Oasis Report 1QKBRD Ford Oasis requests 2 08-11-2006 03:26 AM
Oasis report please imelmo Ford Oasis requests 1 08-08-2006 02:09 AM
Oasis Report Snowaholic Ford Oasis requests 1 08-07-2006 07:03 PM
Oasis report tporter Ford Oasis requests 1 07-25-2006 09:23 PM
