oasis report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BrokeStroke, this thread has received 4 replies and been viewed 1226 times.
post #1 of 5 (permalink) Old 08-01-2009, 06:22 AM Thread Starter
Smile oasis report
may I get an Oasis report pleeease. Vin # 1FMSU45P44EB97754.Thank You
BrokeStroke is offline
post #2 of 5 (permalink) Old 08-01-2009, 10:04 PM
4play's Avatar
OASIS RESULT:
1FMSU45P44EB97754
USA
EN
08/01/2009
17:03:51
FCXWS446
© Copyright 2002-2009 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L FUEL INJECTORS, REFERENCE 09-07-11
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/06/2004 BUILD DATE
12/23/2003 SALE MILEAGE
00025
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 0 1F03 030304 * 8287 * L87 33 15
AWS Claim Key: 282277 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2004 Doc #:252930B
Cust Comments: WHILE PERFORMING PDI, FOUND COOLANT LEAKING FROM HEATER CORE HOSE
Tech Comments: 15 PRESSURE TESTED COOLING SYSTEM FOUND HEATER CORE HOSE WAS NOT PROPERLY SEATED ON HEATER CORE TOPPED COOLANT OFF AND RETESTED SYSTEM ALSO ROAD TEST NO LEAKS.
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 8 2A01 031202 * 6C646 * D50 33 10944
AWS Claim Key: 1604436 Trx Code: 1 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:12-AUG-2004 Doc #:268825A
Cust Comments: OTHER ENGINE TROUBLES WHEN STARTING VEHICLE WILL SMOKE OCCASIONALLY AND RUNS ROUGH. VEHICLE ALSO HAS DROPPED IN FUEL ECONOMY, CUSTOMER CHECKS WITH GALLONS AND MILES DRIVEN.
Tech Comments: 10944 OBSERVED ROUGH IDLE AND SMOKE ALSO TURBO SOUNDED DIFFERENT PERFORMED 6.0L PERFORMANCE DIAG SHEET 1 GOOD 2 GOOD 3 GOOD 4 PASS 5 P0401 6 PASS 7 GOOD 8 PASS 9 34 PASS 10 55 PASS 11 PASS 12 PASS 13 16 LOW 14 PASS 15 GOOD FOUND THE CAC TUBE AT THE TURBO HAD COME SLIGHTLY OFF CLEANED REPOSITIONED AND TIGHTENED THE HOT SIDE TUBE BOOST PRESSURE IS NOW NORMAL AND THE P0401 WENT
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 11 2G04 000615 * DIAG * D03 42 19593
AWS Claim Key: 2663220 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:22-NOV-2004 Doc #:275671C
Cust Comments: CHECK FOR BLOWING BLUE SMOKE OUT TAILPIPE ...ALSO LOST MPG....HAPPENS WARM OR COLD .REPORT
Tech Comments: 19593 ROAD TESTED VEHICLE. VEHCILE RAN GOOD HOOKED UP WDS. CHECKED SYSTEM FOR CODES NO CODES IN MEMORY, DID KOEO TEST SYSTEM PASSED, DID KOEO BUZZ TEST. SYSTEM PASSED DID KOER TEST. SYSTEM PASSED. VEHCILE DOES NOT BLOW BLUE SMOKE ALL THE TIME WARM OR COLD. DID FUEL ECONOMY TEST WITH WDS IS GETTING AVG OF 14.5 MPG. IS OK. NO SET SPEC FOR DIESEL ENGINE. DID NOT SEE ANY ABNORMAL AMOUT
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 13 1F03 030304 3C3Z 8286 AJ E23 42 24420
AWS Claim Key: 3313473 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:07-JAN-2005 Doc #:278432A
Cust Comments: CHECK FOR COOLANT LEAK ....LEAVES LITTLE PUDDLE OVERNIGHT PASSENGER SIDE FRT AREA .....
Tech Comments: 24420 PRESSURE TESTED COLLING SYSTEM NO LEAKS ADDED DIE TO SYSTEM AND LET VEHICLE RUN TILL WARM SHUT VEHICLE OFF AND LET SIT INSPECTED NO LEAKS CUSTOMER SHOULD DRIVE OVER THE WEEKEND AND BRING BACK INSPECTED WITH BLACK LITE AND FOUND VERY SMALL LEAK COMING FROM LOWER RADIATOR HOSE ALSO DURING INSPECTION FOUND LOWER RADIATOR HOSE HAS BEEN RUBBING ON STEERING GEAR BOX REPLACED HOSE
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 16 3A03 070101 5C3Z 7D006 D N18 42 33697
AWS Claim Key: 4890324 Trx Code: E84 Labor Hrs: 9.7
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:05-APR-2005 Doc #:284560C
Cust Comments: UNUSUAL TRANSMISSION NOISE CUSTOMER REPORTS CLUNK TYPE NOISE COMING FROM UNDER TRUCK NOISE OCCURS WHEN SHIFTING FROM PARK TO DRIVE REVERSE TO DRIVE. CUSTOMER NOTES THE NOISE SOUNDS LI
Tech Comments: 34210 42 ROAD TEST TO VERIFY CONCERN DELAY IN REVERSE AND A CLUNK CHECK OASIS FOUND SSM 18209 2004 REMOVED TRANNY BANCH MOUND IN HOLDING FIXTRUE TORE DOWN REPLACE REVERSE PLANET FLUSH COOLING LINES REPLACE INLINE FILTER INSALLED TRANNY ROAD TEST OK
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 16 2G02 030008 4C2Z 12A690 BA L65 D8 33697
AWS Claim Key: 4890325 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:05-APR-2005 Doc #:284560E
Cust Comments: CHECK FOR OIL LEAK FROM ENGINE AREA...
Tech Comments: 34210 CC D8 ROAD TESTED INSTALLED OIL DYE TO ENGINE BLACK LIGHTED ENGINE AREA FOR OIL LEAKS FOUND GLOW PLUG BUSS BARS HARNESS LEAING ON BOTH SIDES. R R BOTH PASS SIDE AND DRIVERDS SIDE BUSS BAR HARNESS, WITHY NEW ONES, CLEANED OFF AREA. ROAD TESTED NOW OK CHECKED FOR LEAKS FOUND OIL LEAKING FROM THE GLOW PLUG BUSS BARS ON BOTH SIDES ORDERED HARNESSES WILL BE HERE TOMARROW
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 17 1G03 030507 3C7Z 8620 AC E19 42 35624
AWS Claim Key: 5085513 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:02-MAY-2005 Doc #:286367D
Cust Comments: CHECK FOR BELT SQUEALING IN AM ....REPORT
Tech Comments: 35624 HEARD THE BELT SQUEEKING VHEN THE ENGINE WAS STARTED COLD REPALCED THE SERP BELT PER TSB04 14 12 NO MORE SQUEEKS
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 19 * * * * * * * 43988
AWS Claim Key: 6135854 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2005 Doc #:292065I
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 19 2H02 030008 5C3Z 6F089 A D50 42 43988
AWS Claim Key: 6135851 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2005 Doc #:292065A
Cust Comments: CHECK FOR ENGINE SEEMS TO HAVE A BOOST OF POWER AT 1500 RPMS ....ALMOST FEELS LIKE HESITATES ...SEE NICK ON THIS
Tech Comments: 43988 CC 42 ROAD TESTED VAREFIED CONCERN. DID DIESEL DIAG SHEET. DID ENGINE CHASSI INSPECTION. TESTED OK, NEXT DID CHECKED FUEL SAMPLE TESTED OK, NEXT CHECKED OIL LEVEL AND CONDTION LOOKED OK. DID KOEO TEST SYSTEM PASSED, CHECKED FOR CONTIONOUS CODES, NO CODES IN MEMORY, DID KOEO BUZZ TEST, CHECKED INTAKE RESTRICTION. TEST OK FOUND SSM 18700 FOR TUBO OIL SUPPLY LINE AND VGT.
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 19 2H01 * * * * * * 43988
AWS Claim Key: 6135852 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2005 Doc #:292065G
Cust Comments: CUSTOMER SATISFACTION PROGRAM 05B29:CERTAIN 2004 MODEL YEAR F250 350 450 550 AND EXCURSION VEHICLES EQUIPPED WITH 6.0L DIESEL CHARGE AIR COOLER DUCT REPLACEMENT
Tech Comments: 43988 DID RECALL 05B29, REPLACED CAC TUBE PER RECALL
AWS Claim Key: 6135853 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2005 Doc #:292065H
Cust Comments: SAFTEY RECALL 05S34:CERTAIN 2004 MODEL YEAR F250 350 450 550, EXCURSION, AND E350 450 VEHICLES EQUIPPED WITH 6.0L DIESEL FUEL INJECTOR CONTROL MODULE WIRING HARNESS REPAIR
Tech Comments: 43988 PERFORMED RECALL 05S34 AND REPLAECED ICP CONNECTOR
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 23 5G03 050301 5C3Z 3050 A H21 30 55434
AWS Claim Key: 7640270 Trx Code: P05 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2005 Doc #:01293406
Cust Comments: REPLACE UPPER AND LOWER BALL JOINTS AND VAC SEALS P05 REPAIR
Tech Comments: CC30 BALL JOINTS WORN LOOSE REPLACE ALL FOUR BALL JOINTS, BOTH VACUUM AND AXLE DUST SEALS.
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 23 * * * * * * * 55434
AWS Claim Key: 7640269 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2005 Doc #:01293411
Cust Comments: 05E15 RECALL EXHAUST SENSOR REPLACEMENT
Tech Comments: 1 PERFORMED RECALL 05E15 AND REPROGRAMED PCM,TCM,FICM TO LATEST CALIBRATION
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 24 1H03 030008 4C3Z 9F452 A D42 42 57712
AWS Claim Key: 7917828 Trx Code: E72 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2005 Doc #:01462301
Cust Comments: CHECK FOR COOLANT LEAKING PASSENGER SIDE MIDDLE OF ENGINE .. NOTE HAPPENS WORSE WHEN USING REAR HEATER .....SEE HIST
Tech Comments: ROAD TESTED VEHICLE.PRESSURE TESTED COOLING SYSTEM,INSPEC TED FOR COOLANT LEAK WITH BLACK LIGHT,HAD DYE IN SYSTEM FOUND EGR COOLER LEAKING COOLANT INTO VALLEY AND DRIPPING DOWN BACK SIDE OF EN
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 29 1A03 030008 5C3Z 6009 AARM L87 D8 71205
AWS Claim Key: 9604359 Trx Code: E72 Labor Hrs: 21.2
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2006 Doc #:02292803
Cust Comments: CHECK FOR LOW ON COOLANT ...REPORT IF LEAKS
Tech Comments: ROAD TEST VERIFY COOLANT LOW IN DEGAS BOTTLE ADD DYE IN COOLING SYS INSPECT FOR COOLANT LEAKS FOUND NO VISABLE LEAKS PRESSURE TEST COOLING SYS NO PRESSURE LOSS TOP OFF COOLANT LEVEL ROAD TEST VEHICLE IN 3 GEAR AGAINST THE THROTTLE GOVENER COOLANT DEGASSED OUT THE DEGAS BOTTLE FOUND HEAD GSKT FAILURE REMOVE BOTH CYL HEADS OFF OF ENGINE CLEAN SURFACES CK HEAD GSKT FOUND DRIVER SIDE BLOWN OUT AT COOL
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 39 2H01 031202 6C3Z 6C640 B L65 D8 95430
AWS Claim Key: 11287350 Trx Code: E72 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:05-MAR-2007 Doc #:04064302
Cust Comments: CHECK FOR OIL LEAK ....REPORT
Tech Comments: VERIFIED VEHICLE HAS LEAK INSTALLED OIL DYE AND CLEANED ENGINE AND LET CUSTOMER DRIVE VEHICLE. HAD CUSTOMER DRIVE VEHICLE AND HE BROUGHT IT BACK. HAD TO VERIFY WERE LEAK WAS COMING FROM WITH A BLACK LIGHT. OIL WAS COMING FROM HOT SIDE TURBO CHARGER CONNECTIONS LOWER AND UPPER AND UPPER WAS LEAK ING OIL DOWN VALLEY OF ENGINE BLOCK AND DOWN THE BACK OF ENG
1FMSU45P44EB97754 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 06-JAN-2004 158607 USA 44 1B03 030204 3C3Z 6A642 AA D42 55 107276
AWS Claim Key: 11962501 Trx Code: P01 Labor Hrs: 5.8
Dlr Cd-Sub Cd: 09254 - * Name: STILLWATER FORD, LINCOLN-MERCURY Ph: 651-4302400 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:02-AUG-2007 Doc #:04895201
Cust Comments: CHECK FOR TRUCK DIED AND HAD NO POWER BLOWS BLACK SMOKE FROM TAILPIPE CHECK GAUGE LIGHT CAME ON ...REPORT LOW ON COOLANT
Tech Comments: EEC TEST CODES P0401, P0404 & P1335 EGR FAILS EGR RESPONSE TEST REMOVED EGR VALVE FOUND EGR VALVE AND INTAKE PLUGGED EGR COOLER LEAKING AND COOLANT & OIL TEMP 35 DEG. DIFF NEEDS EGR VALVE & COOLER , OIL COOLER & INTAKE REPLACED ALL NEEDED PARTS AND GASKETS FILLED WITH COOLANT AND CLEARED CODES TEST DROVE VEH NOW OK
4play is offline
post #3 of 5 (permalink) Old 08-01-2009, 10:49 PM Thread Starter
Question recall reports?
Thank you for the report,your Oasis report showed three recalls. Should those recalls show up on a carfax?
post #4 of 5 (permalink) Old 08-02-2009, 06:08 AM Thread Starter
Thank you for the report,should the recalls found on the oasis report,show up on a carfax?
post #5 of 5 (permalink) Old 08-02-2009, 07:50 AM
4play's Avatar
i would have no idea how far or deep car fax reports go, but i am pretty sure they dont get any warranty repair info.
4play is offline
BrokeStroke (08-03-2009)
OASIS Report Please patriot2500 Ford Oasis requests 1 09-03-2007 11:55 PM
Oasis report badblack dually Ford Oasis requests 2 08-16-2007 11:59 AM
Looking for Help on an Oasis Report RichG Ford Oasis requests 1 08-16-2007 05:51 AM
Oasis report please Daveinpdx Ford Oasis requests 1 08-16-2007 05:50 AM
Oasis report please Andy AZ Ford Oasis requests 1 10-07-2006 12:10 AM
