Need an oasis report please! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Defender Bob, this thread has received 3 replies and been viewed 1347 times.
post #1 of 4 (permalink) Old 08-11-2009, 12:54 AM Thread Starter
Defender Bob's Avatar
I have been looking for a black 4x4 6.0 Excursion lately. I have found a few that I like. I would appreciate if I could get the Oasis report for them.
Truck #1: 1FMSU43P65EA49674
Truck #2: 1FMSU43P95EB44908
Truck #3: 1FMSU43PX4EC92578
Defender Bob is offline
post #2 of 4 (permalink) Old 08-11-2009, 05:49 AM
4play's Avatar
Truck #1:
OASIS RESULT:
1FMSU43P65EA49674
USA
EN
08/11/2009
00:48:34
FCXWS447
Copyright 2002-2009 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
5L110N0A
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L FUEL INJECTORS, REFERENCE TSB 09-07-11
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/15/2004 BUILD DATE
08/24/2004 SALE MILEAGE
00461
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FMSU43P65EA49674 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-AUG-2004 15-SEP-2004 121717 USA 1 6X04 010902 * 17682 * M05 07 1688
AWS Claim Key: 81545 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 05892 - * Name: WOODY ANDERSON FORD Ph: 256-5399441 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:23-SEP-2004 Doc #:06348051
Cust Comments: CUSTOMER STATES;DRIVERS OUTSIDE MIRROR NOT OPERATING PROPERLY AND FALLING OUT
Tech Comments: DIAG., REMOVE LEFT OUTER MIRROR GLASS TO INSPECT AND REINSTALL GLASS PROPERLY, ALIGNMENT PINS NOT IN SLOTS
1FMSU43P65EA49674 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-AUG-2004 15-SEP-2004 121717 USA 5 5V01 060301 * 1125 * N27 13 12613
AWS Claim Key: 309086 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 05892 - * Name: WOODY ANDERSON FORD Ph: 256-5399441 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2005 Doc #:07378351
Cust Comments: CUSTOMER STATES;BRAKES VIBRATE WHEN APPLIED
Tech Comments: DIAG VIBRATION,ROADTEST,R&I FRONT BRAKE ROTORS AND MACHINE,REROADTEST OK LFB 37.94MM.LFA 37.51MM RFB 39.94MM.RFA 37.54MM
1FMSU43P65EA49674 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-AUG-2004 15-SEP-2004 121717 USA 8 1H03 030008 5C3Z 9F452 AA D50 42 20282
AWS Claim Key: 738757 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 05892 - * Name: WOODY ANDERSON FORD Ph: 256-5399441 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:18-APR-2005 Doc #:08246153
Cust Comments: CUSTOMER STATES;VEHICLE LOOSES POWER AND SPUTTERS GOING UP HILL
Tech Comments: PERFORM DIAG STEPS 1,2,3,4,5,6,7,8,11 PINPOINT TEST,R&R EGR VALVE STICKING OPEN,FINAL EEC P1111,ROADTEST
1FMSU43P65EA49674 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-AUG-2004 15-SEP-2004 121717 USA 8 7B02 140201 4C3Z 10346 AA A85 42 20282
AWS Claim Key: 738756 Trx Code: E83 Labor Hrs: 3
Dlr Cd-Sub Cd: 05892 - * Name: WOODY ANDERSON FORD Ph: 256-5399441 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:18-APR-2005 Doc #:08246152
Cust Comments: CUSTOMER STATES;TRANSMISSION AND ALTERNATOR LIGHT COMES ON
Tech Comments: ELECTRONIC TRANSMISSION DIAG,PINPOINT TEST P1111,CHECK CHARGING SYSTEMR&R ALTERNATOR ASSEMBLY SHORTED,LOW VOLTAGE CAUSING TRANSMISSION SHIFTING PROBLEMS,ROADTEST TO LEARN TRANSMISSION STRATAGY,CLEAR CODES,ROADTEST OK
1FMSU43P65EA49674 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-AUG-2004 15-SEP-2004 121717 USA 12 5V07 060704 5C7Z 2005 B L68 42 32407
AWS Claim Key: 1850520 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 05892 - * Name: WOODY ANDERSON FORD Ph: 256-5399441 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2005 Doc #:09512052
Cust Comments: CUSTOMER STATES;POWER STEERING LEAKING
Tech Comments: DIAG POWER STEERING LEAK,STEAM CLEAN ENGINE FOUND HYDRAULIC BRAKE BOOSTER LEAKING AT MASTER CYLINDER,R&R BRAKE BOOSTER,TOP OFF FLUID,ROADTEST,RECHECK OK
1FMSU43P65EA49674 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-AUG-2004 15-SEP-2004 121717 USA 12 5V01 0603XX * 1102 * N27 13 32407
AWS Claim Key: 1850519 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 05892 - * Name: WOODY ANDERSON FORD Ph: 256-5399441 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2005 Doc #:09512051
Tech Comments: DIAG BRAKE VIBRATION,ROADTEST,R&I BOTH FRONT ROTORS AND MACHINE,REROADTEST OK, LFB 37.46 LFA 37.18,RFB 37.50 RFA 37.20
1FMSU43P65EA49674 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-AUG-2004 15-SEP-2004 121717 USA 24 * * * * * * * 59437
AWS Claim Key: 5663821 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05892 - * Name: WOODY ANDERSON FORD Ph: 256-5399441 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:22-AUG-2006 Doc #:02575841
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: 59B01A
1FMSU43P65EA49674 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-AUG-2004 15-SEP-2004 121717 USA 24 1H03 030008 5C3Z 9F452 AA D50 42 59437
AWS Claim Key: 5663823 Trx Code: E72 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 05892 - * Name: WOODY ANDERSON FORD Ph: 256-5399441 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:22-AUG-2006 Doc #:02575851
Cust Comments: CUSTOMER STATES;NO POWER ON ACCELERATION
Tech Comments: ROADTEST TO VERIFY CONCERN,HOOK UP IDS,PERFORM DIAG STEPS 1,2,3,4,5,6,7,8,9,10A,10C,11,12A,12B,13,PINPOINT TEST,R&R EGR VALVE STUCK,REROADTEST FINAL EEC PASS
AWS Claim Key: 5663822 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05892 - * Name: WOODY ANDERSON FORD Ph: 256-5399441 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:22-AUG-2006 Doc #:02575842
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: 05B32
AWS Claim Key: 5663820 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 05892 - * Name: WOODY ANDERSON FORD Ph: 256-5399441 St:AL Ctry Cd: USA Reg Cd: NA Repr Date:22-AUG-2006 Doc #:02575840
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM A
Tech Comments: 05E15G
4play is offline
Defender Bob (08-12-2009)
post #3 of 4 (permalink) Old 08-11-2009, 05:51 AM
4play's Avatar
Truck #2:
OASIS RESULT:
1FMSU43P95EB44908
USA
EN
08/11/2009
00:50:11
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
5L110N0A
WARNING MESSAGES
ARN MESSAGES
WARRANTY START DATE
12/02/2004 BUILD DATE
11/19/2004 SALE MILEAGE
00010
EXTENDED COVERAGES
06/16/2009
DEALER: Gus Machado Ford, Inc.
WARRANTY CLAIM NUMBER: 373323 ODOMETER: 078560M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9G282AA PMP & FLTR ASY-FUL 001 9527AL 42 DOES NOT OPERATE PROPERLY
4C3Z 9E527BRM NOZZLE ASY-FUEL INJE 001 9350E
XO 15W40QSD 016
78601 INSPECTE DVEHCIEL RUNS ROUGH BEGAN PERFORMED CE DIAG AND FOUDN FUEL P RESURE BELOW THRESHOLD 38 PSI IDLE AND DROPS TO ZERO ON ACCEL CHECKED FUEL MQUALITY AND FILTERS ALL PASSED REPLACED FUEL PUMP AND RECHECKED FUEL PRES URE UP TO 50 PSI AT IDLE ROAD TESTED PRESURE MAINTAINS AND MAINTAINS MONIT ORED PIDS CYLINDER #8 NOT CONTRIBUTION UNDER LOAD FOLLOWED PCED PIN TETS
06/16/2009
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 090803A 55 PLUGGED/RESTRICTED
4C3Z 6051EB GASKET CYL HEAD 002 090803B
3C3Z 6C683AA FLTER-ENG OIL 001 090803D
3C3Z 6731AA ELEMENT ASY OIL FILT 001 090803E
XO 15W40QSD 015 090803F
VC 7B 002
VC 9 001
3C3Z 6A642CA COOLER CRANKCASE OI 001
5C3Z 9C968CA FUEL PRESSURE REG 001
78601 INSPECTD VEHCIEL HYDROLOCKED REMOVED GLOW PLUGS AND FOUND COOALNT IN ENGINE REMOVED INATKE MANIFOLD AND FOUND EGR COOELR HAS FAILED HYDROLOCKIN G ENGEIN BENCH TESTED COOLER TO VERIE FAILURE AND FAILED REPLACED EGR COOLL ER AND OIL COOLER KIT ALSO SCREEN UNDER OILCOOLER WAS BROKEN REPLACED INSPE CTE IPR SCREEN BROKEN AND DEBRIS IN IPR REPLACED IPR ASSEMBLED VEHCIEL FLUSH
1FMSU43P95EB44908 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 19-NOV-2004 02-DEC-2004 124002 USA 12 3A15 0701XX 4C3Z 7G383 AA P59 42 27631
AWS Claim Key: 2557463 Trx Code: S07 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 04920 - * Name: WORLD FORD/KENDALL Ph: 305-2389211 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:17-NOV-2005 Doc #:09862352
Cust Comments: SHIFTS HARD INTO 2ND GEAR
Tech Comments: CUST STATEST TRANS SHIFTS HARSN EEC TEST NO CODES ROAD TEST AND PID MONITOR TRANS EPC ERRAITC AT TIMES R R PAN AND SOLE.BODY REPLACE EPC SOLE.TOP OFF FLUID ROAD TEST OK
1FMSU43P95EB44908 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 19-NOV-2004 02-DEC-2004 124002 USA 20 1H03 030008 4C3Z 9P456 AC D50 D1 41706
AWS Claim Key: 5472758 Trx Code: S07 Labor Hrs: 22.9
Dlr Cd-Sub Cd: 04893 - * Name: MIDWAY FORD Ph: 305-2663000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2006 Doc #:384733D
Cust Comments: CHECK FOR WHITE SMOKE FROM TAIL PIPE
Tech Comments: 41706 PERFORM PROCEDURE PER TSB 06 3 8,ECT AND EOT PERFORM PROCEDURE PER TSB 06 3 8, PERFORM COOLING SYSTEM PREASURE TEST , DIGNOSIS EGR COOLER LEAKING, REPLACE EGR COOLER, RETST,ROAD TEST ECT TEMP AND EOT AT 40 DEGRES OF EACH OTHER, ALSO COOLING SYSTEM PREASURE RISES WHILE DRIVING, REPLACE HEAD GASKETS,BOTH SIDES REPLACE OIL COOLER RESTRICTED, PERFORM COOLING SYSTEM
1FMSU43P95EB44908 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 19-NOV-2004 02-DEC-2004 124002 USA 20 2E06 030008 4C3Z 9E527 AA D13 42 41706
AWS Claim Key: 5376136 Trx Code: S07 Labor Hrs: 7.6
Dlr Cd-Sub Cd: 04893 - * Name: MIDWAY FORD Ph: 305-2663000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2006 Doc #:384733B
Cust Comments: CHECK FOR ROUGH IDLE
Tech Comments: 41706 PERFORM DIESEL ENGINE PERFORMANCE DIAGNOSTICS WORKSHEET, IDS HOOK UP EEC TEST P0266 P2269 P0404 PU0101, FUEL PRESSURE TEST 53 PSI, POWER BALANCE #2 CYLINDER MISSFIRE, PERFORM ENHANCED INJETOR TEST #2 CYLINDER, DATA LOGGER TO MONITO R EGR EBP ICP IPR RPM VGT MGP MAP BARO, RELATIV E COMPRESSION TEST PASS, EGR TEST FAIL, VGT TES T PASS, PINPOINT TEST, REPLACE #2 INJECTOR TO
1FMSU43P95EB44908 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 19-NOV-2004 02-DEC-2004 124002 USA 20 * * * * * * * 41706
AWS Claim Key: 5376137 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04893 - * Name: MIDWAY FORD Ph: 305-2663000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2006 Doc #:384733E
Cust Comments: RECALL #05E15
Tech Comments: 41706 RECALL 05E15M REPLACE EBP SENSOR AND RECALIBRATE PCM...409
AWS Claim Key: 5376138 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04893 - * Name: MIDWAY FORD Ph: 305-2663000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:07-JUL-2006 Doc #:384733F
Cust Comments: RECALL #59B01
Tech Comments: 41706 RECALL 59B01A PERFORM CUSTOMER ASSURANCE TEST DRIVE...409
1FMSU43P95EB44908 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 19-NOV-2004 02-DEC-2004 124002 USA 56 2E03 030402 4C3Z 9E527 BRM D42 42 78560
AWS Claim Key: 11033501 Trx Code: S07 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 04931 - * Name: GUS MACHADO FORD, INC. Ph: 305-8223211 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-JUN-2009 Doc #:373323B
Cust Comments: CUSTOMER STATES VEHICLE HASS LOSS OF POWER
Tech Comments: 78601 INSPECTE DVEHCIEL RUNS ROUGH BEGAN PERFORMED CE DIAG AND FOUDN FUEL PRESURE BELOW THRESHOLD 38 PSI IDLE AND DROPS TO ZERO ON ACCEL CHECKED FUEL MQUALITY AND FILTERS ALL PASSED REPLACED FUEL PUMP AND RECHECKED FUEL PRESURE UP TO 50 PSI AT IDLE ROAD TESTED PRESURE MAINTAINS AND MAINTAINS MONITORED PIDS CYLINDER #8 NOT CONTRIBUTION UNDER LOAD FOLLOWED PCED PIN TETS
1FMSU43P95EB44908 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 19-NOV-2004 02-DEC-2004 124002 USA 56 1B03 030204 3C3Z 6A642 CA E23 55 78560
AWS Claim Key: 11038108 Trx Code: E72 Labor Hrs: 26.5
Dlr Cd-Sub Cd: 04931 - * Name: GUS MACHADO FORD, INC. Ph: 305-8223211 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-JUN-2009 Doc #:373323C
Cust Comments: CUSTOMER STATES VEHICLE IS OVERHEATING
Tech Comments: 78601 INSPECTD VEHCIEL HYDROLOCKED REMOVED GLOW PLUGS AND FOUND COOALNT IN ENGINE REMOVED INATKE MANIFOLD AND FOUND EGR COOELR HAS FAILED HYDROLOCKING ENGEIN BENCH TESTED COOLER TO VERIE FAILURE AND FAILED REPLACED EGR COOLLER AND OIL COOLER KIT ALSO SCREEN UNDER OILCOOLER WAS BROKEN REPLACED INSPECTE IPR SCREEN BROKEN AND DEBRIS IN IPR REPLACED IPR ASSEMBLED VEHCIEL FLUSHED
4play is offline
post #4 of 4 (permalink) Old 08-11-2009, 05:53 AM
4play's Avatar
Truck #3:
OASIS RESULT:
1FMSU43PX4EC92578
USA
EN
08/11/2009
00:52:17
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
ARN MESSAGES
BEFORE REPLACING 6.0L FUEL INJECTORS, REFERENCE 09-07-11
WARRANTY START DATE
03/25/2004 BUILD DATE
03/17/2004 SALE MILEAGE
EXTENDED COVERAGES
1FMSU43PX4EC92578 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 17-MAR-2004 25-MAR-2004 147004 USA 6 2E05 100106 3C3Z 9B249 AB G29 42 8964
AWS Claim Key: 1867307 Trx Code: 2 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 01998 - * Name: MT. ORAB FORD-MERCURY, INC. Ph: 513-7214464 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-AUG-2004 Doc #:0178443
Cust Comments: WATER IN FUEL LIGHT ON
Tech Comments: DRAINED NO WATER PRESANT. CLEARED, WONT CLEAR. PERFORMED PIN POINT TEST....F1... TESTED FOUND SHORTED. R&R WATER IN FUEL SEPORATOR ASSEMBLY. MTIME DUE TO NO SLTS
1FMSU43PX4EC92578 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 17-MAR-2004 25-MAR-2004 147004 USA 6 7H11 120305 YC3Z 19867 DA C05 D8 8964
AWS Claim Key: 1867305 Trx Code: 2 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 01998 - * Name: MT. ORAB FORD-MERCURY, INC. Ph: 513-7214464 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-AUG-2004 Doc #:0178441
Cust Comments: AC NOT COOL
Tech Comments: TESTED FOUND HOLE IN LINE, CAUSED BY LINE RUBBING ON VALVE COVER. SUCTION LINE FROM COMPRESSOR.TO REAR EVAPORATOR. REMOVED INNER FENDER. REMOVED BRACKETS FROM FRONT TO BACK. SUCKED DOWN SYSTEM, FILLED.
1FMSU43PX4EC92578 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 17-MAR-2004 25-MAR-2004 147004 USA 6 1G04 030509 3C2Z 6B209 AA N12 42 8964
AWS Claim Key: 1867306 Trx Code: 2 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01998 - * Name: MT. ORAB FORD-MERCURY, INC. Ph: 513-7214464 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-AUG-2004 Doc #:0178442
Cust Comments: SERPITEN BELT NOISE ???
Tech Comments: FOUND TENSIONER NOISY, AND BELT FRAYED. R&R FAN, AND SHROUD. R&R BELT, AN DTENSIONER. REASSEMBLED,A ND RETESTED OK
1FMSU43PX4EC92578 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 17-MAR-2004 25-MAR-2004 147004 USA 14 1H03 030008 4C3Z 9F452 A D42 42 22596
AWS Claim Key: 5256096 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01998 - * Name: MT. ORAB FORD-MERCURY, INC. Ph: 513-7214464 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:17-MAY-2005 Doc #:0210891
Cust Comments: HESITATES LOSES PWR. ON ACCELERATION
Tech Comments: TEST DROVE MONITORED PIDS. EGR STICKING. CODE P0401. R&R EGR.
1FMSU43PX4EC92578 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 17-MAR-2004 25-MAR-2004 147004 USA 17 * * * * * * * 27495
AWS Claim Key: 6563867 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 01998 - * Name: MT. ORAB FORD-MERCURY, INC. Ph: 513-7214464 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:08-AUG-2005 Doc #:0220601
Cust Comments: RECALL05S34 WIRE HARNESS
Tech Comments: INSTALLED KIT PER THIS RECALL
AWS Claim Key: 6540865 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01998 - * Name: MT. ORAB FORD-MERCURY, INC. Ph: 513-7214464 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:08-AUG-2005 Doc #:0220603
Cust Comments: 59B01 TEST DRIVE
Tech Comments: TEST DROVE PER RECALL
1FMSU43PX4EC92578 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 17-MAR-2004 25-MAR-2004 147004 USA 17 2H01 * * * * * * 27495
AWS Claim Key: 6540864 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01998 - * Name: MT. ORAB FORD-MERCURY, INC. Ph: 513-7214464 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:08-AUG-2005 Doc #:0220602
Cust Comments: RECALL 5B29
1FMSU43PX4EC92578 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 17-MAR-2004 25-MAR-2004 147004 USA 19 * * * * * * * 29062
AWS Claim Key: 7043816 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 01998 - * Name: MT. ORAB FORD-MERCURY, INC. Ph: 513-7214464 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2005 Doc #:0226171
Cust Comments: RECALL 05E15
Tech Comments: INSTALLED PART,AN REPROGRAMMED PER RECALL
1FMSU43PX4EC92578 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 17-MAR-2004 25-MAR-2004 147004 USA 20 5R01 110401 F2DZ 3Z719 A P67 42 30117
AWS Claim Key: 7499696 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2005 Doc #:327885E
Cust Comments: CUSTOMER STATES THE VEH WILL NOT COME OUT OF GEAR SOMETIMES ( SHIFTER )
Tech Comments: 30138 CK TRANS WAR HOOK UP WDS MONITOR TRANS TEST EEC. PASS FOUND AT TIMES WILL NOT COME OUT OF PARK R.R TRIM LOWERED STEERING COLUM REPLACED SHIFT INNERLOCK SOLENOID CAUSE OF FAILURE BAD SOLENOID CONTACT NO.516 392 840
1FMSU43PX4EC92578 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 17-MAR-2004 25-MAR-2004 147004 USA 20 1H03 030804 4C3Z 9P456 AC L85 D8 30117
AWS Claim Key: 7499695 Trx Code: S07 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2005 Doc #:327885A
Cust Comments: CUSTOMER STATES THE VEH WILL NOT HOLD COOLANT.
Tech Comments: 30137 CK FOR ENGINE WONT HOLD COOLANT INSPECT,PRESSURE TESTED COOLING SYS.NO EXTERNAL LEAKS.REMOVED EGR VALVE,FOUND COOLANT IN EGR PASSAGES.REMOVED TURBO CHARGER,FAN AND SHROUD AND INTAKE MANIFOLD TO REPLACE EGR COOLER. REASSEMBLED.CLEANED COOLANT AND CARBON FROM INTAKE PASSAGES.INSTALLED A NEW EGR VALVE. CLEARED CODES.PERFORMED PERFORMANCE DIAGNOSTICS TO ENSURE PROPPER
1FMSU43PX4EC92578 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 17-MAR-2004 25-MAR-2004 147004 USA 23 3A03 * * * * * * 33700
AWS Claim Key: 8317509 Trx Code: 04B24 Labor Hrs: 6.2
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2006 Doc #:332652D
Cust Comments: TRANSMISSION REPAIRS ON REVERSE PLANET REPLACEMENT
Tech Comments: 33717 RECALL 04B24G PERFORM RECALL 04B24G. REPLACE REVERSE PLANET ASSY ALONG WITH OTHER PARTS IN KIT. KIT #5C3Z 7D006 D
1FMSU43PX4EC92578 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 17-MAR-2004 25-MAR-2004 147004 USA 23 5G03 050301 5C3Z 3050 A N50 42 33700
AWS Claim Key: 8317508 Trx Code: E84 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2006 Doc #:332652A
Cust Comments: POPPING NOISES ON SLOW SPEED TURNS AND CUSTOMER STATES HAD HIS VEHICLE AT AFTERMARKET SHOP HAVING BRAKES REPLACED AND MECHANIC TOLD HIM THE BALL JOINTS WERE BAD LOOSE
Tech Comments: 33700 REPLACED UPPER AND LOWER BALL JOINTS ON THE PASS SIDE TEST DROVE VEH
4play is offline
Defender Bob (08-11-2009)
Oasis Report Please strokin350 Ford Oasis requests 1 01-28-2009 03:55 PM
OASIS Report thesmokinstroke02 Ford Oasis requests 3 01-28-2009 02:35 PM
Need A Oasis Report Please! MUD BUGGY Ford Oasis requests 1 01-05-2008 03:15 AM
OASIS report please silvervic99stang Ford Oasis requests 1 03-21-2007 04:33 PM
oasis report dg250 Ford Oasis requests 5 08-24-2006 11:49 AM
