Oasis report please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4swampin, this thread has received 2 replies and been viewed 1534 times.
post #1 of 3 (permalink) Old 08-11-2009, 12:55 AM Thread Starter
4swampin's Avatar
Send a message via Yahoo to 4swampin
Oasis report please
My buddy is looking at this truck was wondering if you could get an oasis report on it.
Vin #1FTWW31P15EB74420
Thanks a bunch
Mark
Mark
*2010 Ford F-150
Its not pretty, but its good enough for the girls we know
4swampin is offline
post #2 of 3 (permalink) Old 08-11-2009, 05:55 AM
4play's Avatar
OASIS RESULT:
1FTWW31P15EB74420
USA
EN
08/11/2009
00:54:26
FCXWS446
Copyright 2002-2009 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L FUEL INJECTORS, REFERENCE 09-07-11
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/23/2005 BUILD DATE
12/17/2004 SALE MILEAGE
00004
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
12/22/2008
DEALER: Freedom Ford Mercury, Inc.
WARRANTY CLAIM NUMBER: 026433 ODOMETER: 092363M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9C968CA FUEL PRESSURE REG 001 081806B 42 DOES NOT OPERATE PROPERLY
000 081806C
NO START HARD START DIAG CODE P2291 P2290 FOUND IPR BAD REPLACED
1FTWW31P15EB74420 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-DEC-2004 23-FEB-2005 156570 USA 11 2E06 030008 4C3Z 9E527 AA D02 42 19716
AWS Claim Key: 3753889 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 08323 - * Name: FREEDOM FORD MERCURY, INC. Ph: 435-5287217 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:20-DEC-2005 Doc #:00821801
Cust Comments: COMPLAINT WAS TRUCK WILL NOT START.
Tech Comments: FOLLOWED ALL DIAGNOSTICS AND FOUND INJECTOR BAD, REPLACED WITH NEW TO CORRECT PROBLEM. THE INJECTOR THAT WAS BAD WAS CYLENDER #1 THERE WAS NO DTC'S ON KOEO. HAD TO FILL OIL SYSTEM WITH SHOP AIR TO FIND LEAK.
1FTWW31P15EB74420 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-DEC-2004 23-FEB-2005 156570 USA 16 * * * * * * * 28109
AWS Claim Key: 4736237 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2006 Doc #:057180C
Cust Comments: RECALL 59B01
Tech Comments: 28109 RECALL 59B01 ROAD TEST AS PER RECALL 59B01
AWS Claim Key: 4736236 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2006 Doc #:057180B
Cust Comments: RECALL 05E15
Tech Comments: 28109 RECALL 05E15 REFLASH PCM FICM TCM AS PER RECALL 05E15
1FTWW31P15EB74420 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-DEC-2004 23-FEB-2005 156570 USA 18 2H01 030407 5C3Z 6K682 DA D41 42 33235
AWS Claim Key: 5440514 Trx Code: S07 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:059605A
Cust Comments: LACK OF POWER ON ACCELERATION
Tech Comments: 33235 FAILED TURBO VGT VANES & EBP SENSOR. 42. PERFORM ROAD TEST TO VERIFY LOSS OF POWER ON AC CELERATION.PERFORM TESTS ON LINES #1 THRU #11 O N PERFORMANCE SHEET FOR DTCS PO299 & PO341 IN C ONTINIOUS MEMEORY.PERFORM PINPOINT TEST FOR DTC PO341,WAS UNABLE TO VERIFY CMP SENSOR FAULT AT THIS TIME.PERFORM DATA LOGGER PIDS MONITOR FOR EBP SENSOR TO VERIFY FAULT FOR DTC PO299,FOUND
1FTWW31P15EB74420 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-DEC-2004 23-FEB-2005 156570 USA 20 1A01 030102 6C3Z 6049 C D41 42 40436
AWS Claim Key: 6057493 Trx Code: E72 Labor Hrs: 17.4
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:03-OCT-2006 Doc #:061927A
Cust Comments: INSPECT FOR VEHICLE RUNNING ROUGH AND IS LEAKING COOLANT
Tech Comments: 40436 WARPED CYL HEADS & LEAKING GASKETS. D8. PERFORM COOLING SYSTEM PRESSURE TEST TO VERIFY NO EXTERNAL COOLANT LEAKS.PERFORM COOLING SYSTE M BLOCK CHECK TO VERIFY CYLINDER HEAD GASKET AR E LEAKING.RECLAIM R134 REFRIGERANT.REMOVE ENGIN E TO DISAASEMLE & INSPECT FOR WARPED CYLINDER H EADS AT .004 IN. ON BOTH RIGHT AND LEFT CYLINDER HEADS.REPLACE BOTH CYLINDER HEADS & GASKET,EGR
1FTWW31P15EB74420 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-DEC-2004 23-FEB-2005 156570 USA 21 2E03 0304XX 5C3Z 9C968 CA D02 28 40456
AWS Claim Key: 6114500 Trx Code: S07 Labor Hrs: 8.1
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2006 Doc #:062436A
Cust Comments: INSPECT FOR VEHICLE WILL NOT START.
Tech Comments: 40436 OIL LEAK AT HIGH PRESSURE PUMP & IPR VALVE. 42. INSPECT FORENGINE WILLCRANK & NOT START. PERFORM OIL PRESSURE TEST TO VERIFY OIL PRESSURE AT 50 PSI,OK.PERFORM TESTS ON LINE #1 THRU #11 ON NO STARTSHEET FOR DTC P2291 IN CONTINIOUS MEMORY PERFORM PIDS MONITOR TEST FOR ICP PRESSURE AT 0 PSI. REMOVE BOTH VALVE COVERS TO PERFORM HIGH PRESSURE LEAKAGE TEST ON INJECTOR DRIVE SYSTEM,FOUND LEAKAGE IS
1FTWW31P15EB74420 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-DEC-2004 23-FEB-2005 156570 USA 21 2E03 030402 4C3Z 9E527 AA D41 42 43056
AWS Claim Key: 6357740 Trx Code: S07 Labor Hrs: 7
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:13-NOV-2006 Doc #:90062401
Cust Comments: INSPECT FOR VEHICLE RUNNING ROUGH WHEN 1ST STARTED
Tech Comments: PERFORM COLD ENGINE START UP POWER BALANCE FOR MISS,FOUND EN GINE IS MISSING ON #1,#5,#6,#7 & #8 CYLINDERS WHEN STARTED & WILL CONTINUE TO MISS FOR MINIUTES.INSPECT FOR WATER,FUEL & AIR,OK.PERFORM KOEO DTCS.R&R RIGHT & LEFT VALVE COVERS TO REPLACE ABOVE LISTED F AILED INJECTORS.REPLACE COOLING FAN CLUTCH.PERFORM ROAD TEST TO VERIFY REPAIRS,OK.ALLOW VEHICLE TO COLD SOAK TO VERIFY CO LD ENGINE DID
1FTWW31P15EB74420 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-DEC-2004 23-FEB-2005 156570 USA 21 * * * * * * * 43056
AWS Claim Key: 6343467 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:13-NOV-2006 Doc #:90062402
Cust Comments: RECALL 05B32
Tech Comments: INSPECT FOR RECALL 05B32. INSTALL COOLANT LEVEL LABEL AS PER RECALL.
1FTWW31P15EB74420 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-DEC-2004 23-FEB-2005 156570 USA 22 2E03 030402 4C3Z 9E527 AA D41 42 43436
AWS Claim Key: 6455541 Trx Code: S07 Labor Hrs: 6.5
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2006 Doc #:90079001
Cust Comments: INSPECT FOR VEHICLE RUNNING ROUGH WHEN STARTED COLD
Tech Comments: PERFORM COLD ENGINE START UP ENHANCED POWER BALANCE TO VERIF Y MISSING ON #2,#3,& #$ CYLINDERS.INSPECT FOR OIL LEVEL AIR FILTER & FUEL QUALITY,OK.PERFORM KOEO ON DEMAND,CONTINIOUS M EMEORY & INJECTOR EL R&R RIGHT & LEFT VALVE COVERS TO REPLACE #2,#3, & #4 INJECTO RS.CHECK FOR LATEST PCM UP DATES,NO UP DATES ADVAILABLE AT T HIS TIME.PERFORM ROAD TEST TO VERIFY REPAIRS,OK.
1FTWW31P15EB74420 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-DEC-2004 23-FEB-2005 156570 USA 42 2G01 03XXXX 4C3Z 12B599 AARM D42 42 83159
AWS Claim Key: 10047780 Trx Code: S07 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:09-JUL-2008 Doc #:92207701
Cust Comments: INSPECT FOR VEHICLE IS RUNNING ROUGH (POSSIBLE INJECTOR)
Tech Comments: PERFORM ROAD TEST TO VERIFY ENGINE MISS WHEN HOT.PERFORM KOE O TESTS FOR DTCS PO261 TRU PO282 & PO611 IN CONTINIOUS MEMEO RY.PERFORM PINPOINT TEST FOR DTCS,TEST INDICATES FAILED FICM REPLACE FICM & REPROGRAM.PERFORM ROAD TEST TO VERIFY REPAIRS OK.
1FTWW31P15EB74420 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-DEC-2004 23-FEB-2005 156570 USA 42 2E03 030402 4C3Z 9E527 BRM D42 42 83742
AWS Claim Key: 10114788 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:15-JUL-2008 Doc #:92229501
Cust Comments: INSPECT FOR VEHICLE IS HARD TO START IN MORNING AND IS RUNNING ROUGH
Tech Comments: PERFORM KOEO TESTS FOR NO DTCS.PERFORM COLD ENGINE START UP POWER BALANCE TO VERIFY ENGINE MISS ON #5,#7,& #8 CYLINDERS. FOUND NO OTHER FAULTS. R&R RIGHT & LEFT VALVE COVERS TO REPLACE #5,#7,& #8 INJECTOR S.PERFORM ROAD TEST TO VERIFY REPAIRS,OK.ALLOW VEHICLE TO CO LD SOAK OVER NIGHT & RETEST COLD START UP POWER BALANCE TO V ERIFY NO ENGINE MISS.
1FTWW31P15EB74420 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-DEC-2004 23-FEB-2005 156570 USA 47 2E03 0304XX 5C3Z 9C968 CA D21 42 92363
AWS Claim Key: 10661294 Trx Code: E72 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 08323 - * Name: FREEDOM FORD MERCURY, INC. Ph: 435-5287217 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:22-DEC-2008 Doc #:02643301
Cust Comments: C/S DIED WHILE DRIVING
Tech Comments: NO START HARD START DIAG CODE P2291 P2290 FOUND IPR BAD REPLACED
4play is offline
post #3 of 3 (permalink) Old 08-12-2009, 12:37 AM Thread Starter
4swampin's Avatar
Thank you so much
Mark
*2010 Ford F-150
4swampin is offline
Oasis Report Please jibarns Ford Oasis requests 1 02-28-2008 12:43 AM
oasis report please trkyhunter Ford Oasis requests 2 02-22-2008 03:33 PM
Oasis Report Please BozoTheClown Ford Oasis requests 2 02-22-2008 03:27 AM
Oasis report?? Garvey Ford Oasis requests 6 02-15-2008 02:15 AM
OASIS report please. 05PSD Ford Oasis requests 1 01-08-2007 02:46 AM
