OASIS Request Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2008fx4diesel, this thread has received 5 replies and been viewed 1144 times.
post #1 of 6 (permalink) Old 04-10-2010, 10:39 PM Thread Starter
2008fx4diesel's Avatar
2008 ford fx4
1FTSX21RX8EB57773
thanks mike
2008fx4diesel is offline
post #2 of 6 (permalink) Old 04-17-2010, 03:40 AM Thread Starter
Please, any help would be greatly appreciated thanks having lots of problems with the truck
post #3 of 6 (permalink) Old 05-03-2010, 04:44 AM Thread Starter
anyone help please
post #4 of 6 (permalink) Old 05-03-2010, 01:50 PM
Ford OEM Parts Supplier
OASIS RESULT:
1FTSX21RX8EB57773
USA
EN
05/03/2010
08:50:09
FCXWS447
Copyright 2002-2010 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
8F716A0A
PAINT COLOR
EBONY WB C/C-W/B RADIO
AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT
9800 LB. GVW
AXLE RATIO
3.73 FINAL DRIVE RATIO WHEEL SIZE
8 X 18" PREM CHROME STEEL WHL FRONT TIRE
LT 275/70R18E A/T OWL
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
Click here for CUDL
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ARN MESSAGES
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/07/2007 BUILD DATE
06/13/2007 SALE MILEAGE
00000 New Vehicle Base Warranty
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
12/31/2009
DEALER: McAlpine Ford Lincoln Sales Lt
WARRANTY CLAIM NUMBER: 298609 ODOMETER: 103124K
LABOR OP
CONDITION CODE
CONDITION DESC
9C3Z 5H221B FLTR ASY ENG EXH PRT 001 6005F 42 DOES NOT OPERATE PROPERLY
7C3Z 5H247B FLTR ASY ENG EXH PRT 001 6005F1
8C3Z 12B591D SNS ASY-ENG EXH TEMP 001 6005F2
000 6005F6
000 6005F11
000 6005F14
000 6005F45
000 5221A
000 12650D68B
000 6005F1X1
DIAG, KOEO, INJ TST EXH RESTRICTION TST, FUEL CONTAMINATION, PIN TST, FOUND EXH FILTER INOP, REPLACE FILTER-EXH TEMP SENSOR WAS SEIZED IN FILTER,
12/31/2009
LABOR OP
CONDITION CODE
CONDITION DESC
RECAL ECC PROCESSOR RECAL 000 091609A 04 SOFTWARE REVISION/FLASH MODULE
PERFORM TSB 09-16-9 - RECLAIBRATE PCM
07/23/2009
DEALER: Shanahan Ford Lincoln Sales
WARRANTY CLAIM NUMBER: 199328 ODOMETER: 082990K
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 8009B RADIATOR & SUPP ASY 001 8005D 42 DOES NOT OPERATE PROPERLY
9C3Z 8101A CAP ASY - PRESSURE R 001 8005A
CVC 7A 002
PRESSURE TEST COOLING SYSTEM LEAK AT TOP CORNER OFRAD & RAD CAP ONLY HOLDING 5PSI REPL. CAP & RAD VACCUM TEST HODS 25IN. VACCUM FOR 15MIN. ROAD TEST OK
fordparts is offline
post #5 of 6 (permalink) Old 05-03-2010, 01:51 PM
Standard Claims List For Model Year 2008
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 10 2G04 000615 * DIAG * D42 82 23006
AWS Claim Key: 648591 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:03-APR-2008 Doc #:184240A
Cust Comments: POOR FUEL ECONOMY. CHECK ENGINE LIGHT IS NOT ON. DIAG ONLY.CUST ALSO STATES THERE IS ALOT OF BLACK SMOKE COMING FROM EXHAUST.
Tech Comments: ROAD TEST NO DRIVABILITY CONCERNS KOEO,KOER, INJ. TESTS PASS ROAD TST BOOST. PRESS PER SSM 19679 OK TIRE TREAD FRT 12 32 REAR 8 32 VEHICLE OK
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 2G88 000615 * NPF * E41 82 27030
AWS Claim Key: 1484910 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223A
Cust Comments: CUST WAS PULLED OVER BY POLICE VEH. HAS EXCESSIVE SMOKE CANNOT SEE CARS BEHIND YOU CUST STATES USING ALOT OF FUEL AS WELL
Tech Comments: ROAD TEST VEHICLE FOR SMOKE, NOT SMOKINGH AT THIS , FOLLOW TSB 07 8 9 NO CODES, OIL LEVEL CORRECT, NO LEAKS IN INAKE & EXHAUST MANIFOLDS EVIDENT ROADTEST TO UPDATE PCM PRGRAM ROAD TEST OK
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 2E03 03XXXX * 9E527 * E41 42 27030
AWS Claim Key: 1973751 Trx Code: S07 Labor Hrs: 0.6
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223H
Tech Comments: ROAD TEST VEHICLE FOR SMOKE, NOT SMOKINGH AT THIS TIME, FOLLOW TSB 07 8 9 NO CODES, OIL LEVEL CORRECT, NO LEAKS IN INAKE & EXHAUST MANIFOLDS EVIDENT ROAD TEST TO UPDATE PCM PRGRAM ROAD TEST OK FORD SAID TO CLAIM AS TSB, DELETED LINE A AND CLAIMING HERE.
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 6F42 010702 F81Z 2520758 AA R02 07 27030
AWS Claim Key: 1439107 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223G
Cust Comments: CEHCK WEATHER STRIPPING AT BOTTOM OF DOORS , MUD SEEMS TO BE COMING IN SIDE
Tech Comments: INSPECT MUD COMING IN BOTTOM DOORS LOWER WEATHER STRIP NOT SEATING AGAINST BODY & BUCKELED. CLEAN & REPL. BOTH LOWER DOOR WEATHER STRIPS RECHECK NOTTOUCHING BODY IN PLACES ALIGN BOTH FRT DOORS TO TIGHTEN PRESSURE ON LOWER WEATHER STRIP RECHECK SEATS OK
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 6E01 * * * * * * 27030
AWS Claim Key: 1439106 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223F
Cust Comments: CAMP 08C01 SEAT BACK WELDS
Tech Comments: 43502 08C01B 0.3HRS INSPECT SEAT BACK FRAME & INSTALL CLAMP
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 5B03 050306 6C3Z 3B396 AA P82 D4 27030
AWS Claim Key: 1439105 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223D
Cust Comments: CHECK FOR LEFT FRONT CENTERS ARE CORRODED (HUBS)
Tech Comments: INSPECT FRT HUBS CORRODED. REPLACE BOTH FRT HUBS
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 12 6Q06 011902 * 17906 * B69 07 27030
AWS Claim Key: 1439104 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2008 Doc #:186223C
Cust Comments: CHECK FOR REAR TAIL GATE IS HITTING BUMPER AND WEARING PAINT
Tech Comments: REPOSITION & ALIGN REAR BUMPER AS TAIL GATE HITTING BUMPBER WHEN OPEN
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 13 5C02 050100 F81Z 4635 AB N51 69 30567
AWS Claim Key: 1190005 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:18-JUL-2008 Doc #:187663A
Cust Comments: SQUEAKING WHILE DRIVING. REPLACE U JOINT AND BEARINGS
Tech Comments: VERIFY CONCERN. RE&RE REAR DRIVESHAFT REPLACE SIEZED REAR U JOINT. ALL OK NOW
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 14 2G05 031405 * RECAL * E29 04 33765
AWS Claim Key: 1477211 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:28-AUG-2008 Doc #:188951A
Cust Comments: CHECK ENGINE LIGHT IS ON . VEHICLE IS REVING HIGH
Tech Comments: 54341 081302A 0.5HRS MIL LIGHT ON CONT. CODE P2002CHECK OASIS NEW TSB RELEASED JUNE 25 08 PERFORM TSB 08 13 2 REPROGRAM MODULES ROAD TEST OK
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 20 1F01 * * * * * * 41231
AWS Claim Key: 3006236 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:25-FEB-2009 Doc #:194549F
Cust Comments: CAMP 08B06 COOLANT TEE
Tech Comments: INSTALL A VENTURI TEE KIT INTO THE DEGAS BOTTLE AND RADIATOR VENT HOSES
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 20 2G01 * * * * * * 41231
AWS Claim Key: 3006235 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:25-FEB-2009 Doc #:194549E
Cust Comments: 08B07 REPROGRAM PCM & IC MODULES CERTAIN 08 F SUPER DUTY
Tech Comments: REPROGRAM THE PCM, TCM AND IC USING IDS RELEASE 58.4 PATCH 8 OR LATER
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 20 1B02 030008 3C3Z 6731 AA D42 D8 41231
AWS Claim Key: 3064244 Trx Code: E72 Labor Hrs: 20.1
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:25-FEB-2009 Doc #:194549A
Cust Comments: SERVICE ENG LIGHT ON ENG STARTED SPUTTERING EXHAUST WAS EXTREMELY HOT NO POWER BLACK SMOKE FROM EXHAUST ENG REVS HIGH 1700 RPM
Tech Comments: NO POWER ENGINE OIL OVER FULL AND CONTAMINATED WITH FUEL NO DTCS INSYSTEM. MT TO CHANGE OIL & FILTERINSTALL DYE AND TEST WITH BLACK LIGHT AT HIGH PRESSURE OIL RAILS FUEL INJECTORS AND BOSS FITTINGS, FUEL LINES AND UNDER PUMP COVER. DYE ALL OVER THE PUMP AND SMELLS LIKE FUEL IN PUMP VALEY, REPLACED HIGH PRESSURE PUMP AND PREFORMED A HIGHT PRESSURE TEST PASSED. MT TO REMOVE CAGE NUTS BEHIND HEADLIGH
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 25 1F01 030301 8C3Z 8009 B L87 42 51567
AWS Claim Key: 4641159 Trx Code: Z20 Labor Hrs: 2.7
Dlr Cd-Sub Cd: B1097 - * Name: SHANAHAN FORD LINCOLN SALES Ph: 905-8535000 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:23-JUL-2009 Doc #:199328A
Cust Comments: FLUID LEAK AT RAD AREA
Tech Comments: PRESSURE TEST COOLING SYSTEM LEAK AT TOP CORNER OFRAD & RAD CAP ONLY HOLDING 5PSI REPL. CAP & RAD VACCUM TEST HODS 25IN. VACCUM FOR 15MIN. ROAD TEST OK
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 31 4C01 090201 9C3Z 5H221 B E29 42 64078
AWS Claim Key: 5132615 Trx Code: S07 Labor Hrs: 2.6
Dlr Cd-Sub Cd: B1392 - * Name: MCALPINE FORD LINCOLN SALES LTD. Ph: 905-8410800 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:31-DEC-2009 Doc #:29860901
Cust Comments: CK ENGINE LIGHT ON ITS BEEN ON FOR A WEEK
Tech Comments: DIAG, KOEO, INJ TST EXH RESTRICTION TST, FUEL CONTAMINATION, PIN TST, FOUND EXH FILTER INOP, REPLACE FILTER EXH TEMP SENSOR WAS SEIZED IN FILTER,
1FTSX21RX8EB57773 T/F7 F T/BD T/BD T/E A1 T/BE T/QL 13-JUN-2007 07-JUL-2007 4B1097 CAN 31 2G05 031405 * RECAL * D42 04 64078
AWS Claim Key: 5132616 Trx Code: E72 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B1392 - * Name: MCALPINE FORD LINCOLN SALES LTD. Ph: 905-8410800 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:31-DEC-2009 Doc #:29860902
Cust Comments: CK VEHICLE IS LACKING POWER DE HAS NOT KICKED IN FOR A MONTH A HALF NOW
Tech Comments: PERFORM TSB 09 16 9 RECLAIBRATE PCM
post #6 of 6 (permalink) Old 05-04-2010, 12:35 AM Thread Starter
thanks alot
Oasis request ava Ford Oasis requests 2 06-22-2007 12:57 PM
OASIS Request Please cruiser2001 Ford Oasis requests 1 06-07-2007 04:40 AM
Oasis Request dblue351 Ford Oasis requests 1 06-07-2007 04:30 AM
OASIS request please. w406097 Ford Oasis requests 1 06-07-2007 04:30 AM
Request for OASIS Ubetcha Ford Oasis requests 1 06-07-2007 04:27 AM
