Low miles '05 PSD at a used car lot. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Banshee365, this thread has received 2 replies and been viewed 995 times.
post #1 of 3 (permalink) Old 04-24-2010, 07:41 PM Thread Starter
1FTWW31P25ED20582
Thanks!!
2005 King Ranch F-250 PSD 4x4 Auto
6" Pro-comp stage 1 lift
5" exhaust
Air-raid intake and filter
Eagle 17x10's and 37x12.50's Pro-Comp XTreme M/T's
Banshee365 is offline
post #2 of 3 (permalink) Old 04-26-2010, 01:07 PM
Ford OEM Parts Supplier
OASIS RESULT:
1FTWW31P25ED20582
USA
EN
04/26/2010
08:07:29
FCXWS446
Copyright 2002-2010 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
PAINT COLOR
EBONY WB C/C-W/B RADIO
AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT
11,400 LB. GVW
AXLE RATIO
3.73 FINAL DRIVE RATIO WHEEL SIZE
8X18" FORGED POLISHED ALU WHL FRONT TIRE
LT 275/70R18E A/T OWL
ARN MESSAGES
INSTALL 6A642-CA KIT WHEN REPLACING EGR COOLER UNDER 09-08-03
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/17/2005 BUILD DATE
04/20/2005 SALE MILEAGE
New Vehicle Base Warranty
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
03/15/2010
DEALER: Nick Nicholas Ford, Inc.
WARRANTY CLAIM NUMBER: 092030 ODOMETER: 045858M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 003 MT6C640 D8 FAILED GASKET/SEAL
6C3Z 6C640A CONNECTION A/C DUCT 001
OSP 001
VERIFY CONCERN OI LEAK AT ENGINE FOUND LEAK AT HIGH SIDE CAC HOSE OIL LEAK F OUR HOT SIDE CAC HOSE AT TUBEO LEAKING OIL REPLACE HOSE AND CAM SENSOR O RIN G
03/15/2010
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9229B GASKET CARB FUEL INL 001 MT12A342 42 DOES NOT OPERATE PROPERLY
4C3Z 12A342AA PLUG-GLOW 001
DIAG AND PINTEST FOUND GLOW PLUG INOP NUMBER 7 DIAG AND REPROGRAM PCM FICM A ND TCM AND REPLACE NUMBER 7 GLOW PLUG
02/19/2010
DEALER: Ford of Ocala, Inc.
WARRANTY CLAIM NUMBER: 062624 ODOMETER: 045678M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6A642CA COOLER CRANKCASE OI 001 090803A 55 PLUGGED/RESTRICTED
4C3Z 9P456AF COOLER - EGR 001 090803B
9C3Z 8101B CAP ASY - PRESSURE R 001 090803C
3C3Z 6731AA ELEMENT ASY OIL FILT 001 090803E
VC 7B 003 090803F
OSP 002 090803G
VC 9 001
XO 15W40QSD 016
fordparts is offline
post #3 of 3 (permalink) Old 04-26-2010, 01:08 PM
Standard Claims List For Model Year 2005
1FTWW31P25ED20582 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-APR-2005 17-MAY-2005 124427 USA 22 * * * * * * * 23588
AWS Claim Key: 7167676 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04735 - * Name: NICK NICHOLAS FORD-LINCOLN-MERCURY Ph: 352-7957371 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2007 Doc #:09004840
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: RECALL COOLANT DEGAS BOTTLE LABEL INSTALLATION AND COOLANT LEVEL AD
1FTWW31P25ED20582 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-APR-2005 17-MAY-2005 124427 USA 22 1D05 030008 3C3Z 6750 AA D50 01 23588
AWS Claim Key: 7167677 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04735 - * Name: NICK NICHOLAS FORD-LINCOLN-MERCURY Ph: 352-7957371 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2007 Doc #:09004851
Cust Comments: CUSTOMER STATES OIL DIP STICK HANDLE BROKE IN STOCK
Tech Comments: DIP STICK TUBE BROKEN ADDITIONAL MISC. REPAIRS
1FTWW31P25ED20582 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-APR-2005 17-MAY-2005 124427 USA 32 7K11 130101 5C3Z 10849 RD A37 42 35682
AWS Claim Key: 9081219 Trx Code: S07 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 02865 - * Name: FORD OF OCALA INC Ph: 352-7324800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:04-DEC-2007 Doc #:00482751
Cust Comments: CUSTOMER STATES SPEEDO IS INOP AT TIMES AND THEN WORKS FINE SOP IN
Tech Comments: VERIFY CONCERN, PERFORM SCAN TOOL DIAG AND PERFORM QUICK TEST, PASS, PERFORM PID DATA MONITOR PASS, PERFORM ELECTRICAL DIAG, PASS, ALL POWER AND GROUNDS OK, PERFORM PINPOINT TEST FOUND BAD CLUSTER, REMOVE DASH PANEL AND REPLACE BAD CLUSTER, PERFORM MODULE INSTALLATION AND PROGRAMMING WITH IDS, REINSTALL DASH PANEL, RETEST OK
1FTWW31P25ED20582 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-APR-2005 17-MAY-2005 124427 USA 35 2D02 160101 7C3Z 9H465 A P82 42 33782
AWS Claim Key: 9594837 Trx Code: S07 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02865 - * Name: FORD OF OCALA INC Ph: 352-7324800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:04-MAR-2008 Doc #:01173651
Cust Comments: CUSTOMER STATES THE FOUR WHEEL DRIVE WILL NOT ENGAGE
Tech Comments: 4X4 DIAG SYSTEM PASS NO CODES. ROAD TEST FOR INOP 4X4. TEST FOR POWER AT VACCUME SWITCH OK. REPLACED ELEC VACCUME MOTOR DUE TO INTERNAL SHORT. EXTRA TIME TO REPAIR VACCUME LINE. ROAD TEST AND GOT NORMAL 4X4 OPERATION.
1FTWW31P25ED20582 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-APR-2005 17-MAY-2005 124427 USA 37 2D02 160101 7C3Z 9H465 A P82 42 35454
AWS Claim Key: 9822615 Trx Code: E91 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 02865 - * Name: FORD OF OCALA INC Ph: 352-7324800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:12-MAY-2008 Doc #:01739251
Cust Comments: CUSTOMER STATES THE FOUR WHEEL DRIVE DOES NOT ENAGE DISENGAGE PROPERLY. SEE HISTORY. TECH 171 3 5 08 33,789 MILES RO 11736
Tech Comments: INSPECTED 4X4 CERCEN FOUND INOP PERFOMED VAC TEST FT WHEEL HUBS PASS REMOVED LINE AT IWE SOL PERFOMED VAC TEST TO WHEELS PASS PERFOMED PIN POINT TEST WIREING PASS CK OUT IWE SOL FOUND INOP VAC SIDE LEAKING OUT VENT REMOVED AN REPLACED IWE SOL RETESTED SYSTEM ALL WORKING AT THIS PERSENT TIME
1FTWW31P25ED20582 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-APR-2005 17-MAY-2005 124427 USA 37 5I01 110204 3C3Z 3A674 AARM N58 42 35992
AWS Claim Key: 9873997 Trx Code: P05 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 02865 - * Name: FORD OF OCALA INC Ph: 352-7324800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2008 Doc #:01804851
Cust Comments: CUSTOMER STATES POWER STEERING GROAN PRESENT AWA CUST PARTICIPATE 20%
Tech Comments: TEST DROVE PUMP NOISE CHECK FLUID LEVEL OK REMOVE OIL PUMP AND REPLACE WITH REMAN POWER STEERING PUMP FILL WITH NEW FLUID RETESTED VEH HARD TO TURN ORERED NEW PUMP
1FTWW31P25ED20582 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-APR-2005 17-MAY-2005 124427 USA 37 5I01 110204 3C3Z 3A674 AARM L68 42 35992
AWS Claim Key: 9887284 Trx Code: P08 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 02865 - * Name: FORD OF OCALA INC Ph: 352-7324800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2008 Doc #:01804852
Cust Comments: ADD ON POWER STEERING HARD TO TURN
Tech Comments: TEST DROVE CHECK PERSURE FROM PUMP LOW REMOVE SUP.BELT AND LINES FROM PUMP REMOVE PULLEY FROM OLD PUMP AND PRESS ON NEW PUMP INSTALL ON VEH FILL WITH NEW FLUID AND RETESTED ALL OK AT THIS TIME
1FTWW31P25ED20582 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-APR-2005 17-MAY-2005 124427 USA 58 1B03 030204 3C3Z 6A642 CA D50 55 45678
AWS Claim Key: 11394376 Trx Code: E72 Labor Hrs: 12.5
Dlr Cd-Sub Cd: 02865 - * Name: FORD OF OCALA INC Ph: 352-7324800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:19-FEB-2010 Doc #:06262451
Cust Comments: CUSTOMER STATES WHITE SMOKE FROM EXHAUST CK DIESEL WARR 100 DED
Tech Comments: PERF BOOST PSI TEST CK EBPSEAL ROAD TEST VEH TURBO FLUTTERING RECONDITION TURBO REASSEMBLE AND RETEST NO FURTHER CONCERNS AT THIS TIME
1FTWW31P25ED20582 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-APR-2005 17-MAY-2005 124427 USA 59 2I04 030008 4C3Z 12A342 AA D50 42 45858
AWS Claim Key: 11422137 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 01200 - * Name: NICK NICHOLAS FORD, INC. Ph: 352-7261231 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-MAR-2010 Doc #:09203053
Cust Comments: CUSTOMER STATES RUNS ROUGH COLD (SETS OVERNIGHT) BUT RUNS GREAT AT NORMAL OPERATING TEMP.
Tech Comments: DIAG AND PINTEST FOUND GLOW PLUG INOP NUMBER 7 DIAG AND REPROGRAM PCM FICM AND TCM AND REPLACE NUMBER 7 GLOW PLUG
1FTWW31P25ED20582 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-APR-2005 17-MAY-2005 124427 USA 59 2A01 031202 6C3Z 6C640 A L69 D8 45858
AWS Claim Key: 11422136 Trx Code: E72 Labor Hrs: 2
Dlr Cd-Sub Cd: 01200 - * Name: NICK NICHOLAS FORD, INC. Ph: 352-7261231 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-MAR-2010 Doc #:09203052
Cust Comments: CUSTOMER STATES ENGINE OIL LEAK
Tech Comments: VERIFY CONCERN OI LEAK AT ENGINE FOUND LEAK AT HIGH SIDE CAC HOSE OIL LEAK FOUR HOT SIDE CAC HOSE AT TUBEO LEAKING OIL REPLACE HOSE AND CAM SENSOR O RING
The Following User Says Thank You to fordparts For this addition to TDG:
Banshee365 (04-26-2010)
Getting 96 OBS with ONLY 121,000 Miles DppPower 1994-2003 7.3L Power Stroke 10 04-14-2009 12:44 PM
After 100,000 miles then what Diesel Guy 1994-2003 7.3L Power Stroke 7 12-26-2007 10:04 PM
How Many Miles You Got!!! Trex250 1994-2003 7.3L Power Stroke 79 11-21-2007 08:40 AM
how many miles is too many? mikeym 1994-2003 7.3L Power Stroke 15 03-19-2006 02:49 AM
How many miles with SCT? Wildcat 2003-2007 6.0L Power Stroke 7 03-02-2006 03:41 PM
