One more for a '05 Lariat. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Banshee365, this thread has received 2 replies and been viewed 543 times.
post #1 of 3 (permalink) Old 04-26-2010, 07:21 PM Thread Starter
1ftsw21p65ea69123
You rock fordparts!
2005 King Ranch F-250 PSD 4x4 Auto
6" Pro-comp stage 1 lift
5" exhaust
Air-raid intake and filter
Eagle 17x10's and 37x12.50's Pro-Comp XTreme M/T's
Banshee365 is offline
post #2 of 3 (permalink) Old 04-26-2010, 09:20 PM
Ford OEM Parts Supplier
OASIS RESULT:
1FTSW21P65EA69123
USA
EN
04/26/2010
16:20:37
FCXWS447
Copyright 2002-2010 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
PAINT COLOR
OXFORD WHITE WB C/C-W/B RADIO
AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT
10,000 LB. GVW
AXLE RATIO
3.73 FINAL DRIVE RATIO WHEEL SIZE
7.5 X 17 FORGED POL ALUM WHL FRONT TIRE
LT265/70/R17E A/T BSW
ARN MESSAGES
INSTALL 6A642-CA KIT WHEN REPLACING EGR COOLER UNDER 09-08-03
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/08/2004 BUILD DATE
09/18/2004 SALE MILEAGE
00015 New Vehicle Base Warranty
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P65EA69123
fordparts is offline
The Following User Says Thank You to fordparts For this addition to TDG:
Banshee365 (04-26-2010)
post #3 of 3 (permalink) Old 04-26-2010, 09:21 PM
Standard Claims List For Model Year 2005
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 3 2E05 100106 3C3Z 9B249 AB G29 42 7805
AWS Claim Key: 330878 Trx Code: 1 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:10-DEC-2004 Doc #:08238751
Cust Comments: WATER IN FUEL LIGHT COMES ON WHEN MAKING TURNS
Tech Comments: INOP REPLACE FUEL CONDITIONING MODULE
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 6 5S01 100101 * 9002 * G29 42 10870
AWS Claim Key: 551586 Trx Code: S07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2005 Doc #:08900051
Cust Comments: WATER IN FUEL LIGHT COMES ON WHEN MAKING SHARP TURNS
Tech Comments: ADDITIONAL MISC . REPAIRS
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 16 2E05 100106 6C3Z 9B249 A G29 42 11846
AWS Claim Key: 3298388 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-JAN-2006 Doc #:01075853
Cust Comments: WATER IN FUEL LIGHT CAME ON WHEN MAKING A TURN
Tech Comments: INOP HEADER FUEL FILTER REPLACE
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 16 * * * * * * * 11846
AWS Claim Key: 3298387 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-JAN-2006 Doc #:01075851
Cust Comments: RECALL 05E15, EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEMAND ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: 05E15 05E15
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 16 6X01 010907 1L2Z 17700 AA M06 33 11846
AWS Claim Key: 3298389 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-JAN-2006 Doc #:01075854
Cust Comments: THE REAR VIEW MIRROR ON THE WINDSHIELD IS LOOSE AND FALLS OFF SOMETIMES
Tech Comments: LOOSE MIRROR REAR VIEW INSIDE REPLACE
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 17 * * * * * * * 14131
AWS Claim Key: 3793918 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2006 Doc #:01338652
Cust Comments: OWNER NOTIFICATION 05B32, DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: 05B32 COOLANT DEGAS BOTTLE LABEL INSTALLATION AND COOLANT LEVEL AD
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 17 2E05 100106 6C3Z 9B249 A G29 42 14131
AWS Claim Key: 3811557 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2006 Doc #:01338651
Cust Comments: WATER IN FUEL LIGHT COMES ON WHILE DRIVING
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 21 7H05 12XXXX 6C3Z 19980 AA C20 42 20333
AWS Claim Key: 5038763 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2006 Doc #:02084453
Cust Comments: CUST. STATES THE EATC SYSTEM DOES NOT POWER UP ON START UP SOMETIMES
Tech Comments: INOP CONTROL ASSEMBLY AIR CONDITIONER REPLACE
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 21 2G05 031405 * RECAL * G29 07 20333
AWS Claim Key: 5038762 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2006 Doc #:02084451
Cust Comments: WATER IN FUEL LIGHT COMES ON WHILE DRIVING, IT COMES ON AFTER MAKING A SHARP TURN
Tech Comments: ADJUST WATER IN FUEL (WIF) LAMP ON
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 21 2H01 030008 4C3Z 6K682 BA D41 D8 20333
AWS Claim Key: 5052286 Trx Code: S07 Labor Hrs: 8.9
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2006 Doc #:02084452
Cust Comments: CUST. STATES THERE IS A SHUDDER OR SPUTTER WHEN ACCELLERATING UNDER LOAD (PULLING A BOAT) SOMETIMES THEN GOES AWAY
Tech Comments: LEAKING ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 21 2E05 100106 6C3Z 9B249 A G29 42 20414
AWS Claim Key: 5038764 Trx Code: E84 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-JUN-2006 Doc #:02122651
Tech Comments: INOP EVAPORATIVE EMISSIONS SYSTEM LEAK TEST DIAGNOSIS
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 24 2E05 100106 6C3Z 9B249 A G29 42 24990
AWS Claim Key: 5844336 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-SEP-2006 Doc #:02676752
Cust Comments: CUSTOMER STATES WATER IN FUEL LIGHT ON AGAIN
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 27 2E05 100106 6C3Z 9B249 A D50 42 25842
AWS Claim Key: 6675198 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-DEC-2006 Doc #:03341452
Cust Comments: CUSTOMER STATES WATER AND FUEL LIGHT IS ON AGAIN
Tech Comments: INOP COMPLETED TSB 06 22 12
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 27 2E03 030402 4C3Z 9E527 AA D50 42 25842
AWS Claim Key: 6675197 Trx Code: S07 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-DEC-2006 Doc #:03341451
Cust Comments: CUSTOMER STATES TRUCK IS STILL RUNNING ROUGH
Tech Comments: INOP NOZZLE INJECTION PUMP REMOVE AND INSTALL OR REPLACE
1FTSW21P65EA69123 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 18-SEP-2004 08-OCT-2004 124061 USA 27 2E06 100106 3C3Z 9C407 AB D50 42 25842
AWS Claim Key: 6675199 Trx Code: E84 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 04892 - * Name: DON REID FORD, INC. Ph: 407-6447111 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-DEC-2006 Doc #:03341453
Cust Comments: BATTERY TEST, CHARGE, AND RE TEST
Tech Comments: INOP BATTERY TEST, CHARGE, AND RE TEST
2004 F-250 SC Lariat nummit Whats Been Sold 9 04-08-2009 02:00 PM
2004 F-350 x-Cab 4x4 Lariat Mertz Whats Been Sold 0 03-27-2008 04:49 PM
99-04 Lariat wheels and 255/85-16 BFG M/T 444turbodiesel Whats Been Sold 12 10-17-2007 05:44 AM
XLT or Lariat? Mbixler 2008-2010 6.4L Power Stroke 20 07-24-2007 07:21 AM
New shoes for Mr. Lariat adrianspeeder The Parking Lot 9 05-17-2006 12:10 PM
