Oasis request for 04 f-350 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Mskinner, this thread has received 3 replies and been viewed 850 times.
post #1 of 4 (permalink) Old 04-29-2010, 09:05 PM Thread Starter
Vin number 1FTSW31P04EA50734
Thanks for the Info.
04 F 350
Mskinner is offline
post #2 of 4 (permalink) Old 04-30-2010, 04:15 PM
Ford OEM Parts Supplier
OASIS RESULT:
1FTSW31P04EA50734
USA
EN
04/30/2010
11:14:52
FCXWS447
Copyright 2002-2010 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
PAINT COLOR
DARK SHADOW GRAY RADIO
AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT
9900 LB. GVW
AXLE RATIO
3.73 FINAL DRIVE RATIO WHEEL SIZE
7.0 X 16" 6 WINDOW ALUM WHEEL FRONT TIRE
LT265/75R-16E OWL A-T
ARN MESSAGES
INSTALL 6A642-CA KIT WHEN REPLACING EGR COOLER UNDER 09-08-03
TO ENSURE OPTIMUM COOLING SYSTEM PERFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/16/2003 BUILD DATE
08/21/2003 SALE MILEAGE
New Vehicle Base Warranty
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
| On-line 1878
END OF OASIS REPORT FOR 1FTSW31P04EA50734
fordparts is offline
post #3 of 4 (permalink) Old 04-30-2010, 04:15 PM
Standard Claims List For Model Year 2004
1FTSW31P04EA50734 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-AUG-2003 16-SEP-2003 156559 USA 1 6Y05 000001 * TDRIVE * A96 82 6
AWS Claim Key: 23276 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08379 - * Name: ED KENLEY FORD INC Ph: 801-7764201 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:19-SEP-2003 Doc #:6965661
Cust Comments: TEST DRIVE FOR 6.0L PDI
Tech Comments: TEST DRIVE COMPLETED
1FTSW31P04EA50734 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-AUG-2003 16-SEP-2003 156559 USA 1 6P07 010301 * 5420124 * B15 07 438
AWS Claim Key: 26067 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08379 - * Name: ED KENLEY FORD INC Ph: 801-7764201 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2003 Doc #:6966552
Cust Comments: CK PASSENGER FORNT DOOR IS HARD TO CLOSE
Tech Comments: ADJUST R FRONT DOOR STRIKER
1FTSW31P04EA50734 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-AUG-2003 16-SEP-2003 156559 USA 1 3T06 070701 F81Z 7B215 BA L73 D8 438
AWS Claim Key: 26066 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08379 - * Name: ED KENLEY FORD INC Ph: 801-7764201 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2003 Doc #:6966551
Cust Comments: CK UNDETERMINED TRANS FLUID LEAK
Tech Comments: REMOVE DRIVELINE (REAR) REPLACED LEAKING T CASE R OUTPUT SEAL
1FTSW31P04EA50734 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-AUG-2003 16-SEP-2003 156559 USA 1 6A06 010809 4C3Z 16450 CAA F06 D4 662
AWS Claim Key: 40071 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08379 - * Name: ED KENLEY FORD INC Ph: 801-7764201 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2003 Doc #:6968971
Cust Comments: CK CHROME IS PEELING OFF PASS SIDE RUNNING BOARD
Tech Comments: R & R RUNNING BOARD
1FTSW31P04EA50734 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-AUG-2003 16-SEP-2003 156559 USA 5 7S22 180106 3C3Z 14A068 EA D21 X2 7854
AWS Claim Key: 323298 Trx Code: 1 Labor Hrs: 5
Dlr Cd-Sub Cd: 08379 - * Name: ED KENLEY FORD INC Ph: 801-7764201 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2004 Doc #:7041881
Cust Comments: CK CUTS OUT MISSSES JERKS ON ACCEL & STALLS AT TIMES STARTED & WAS IDLEING STALLED WONT RESTART
Tech Comments: REMOVE EDGE PRODUCTS BOX FROM PCM REPROGRAM PCM PER TSB RETEST SITLL RUNS POOR PERF DIAG., EGR OK ICP ERRATIC WDS DATA LOGGER ICP BETWEEN 300 PSI AND 2700 PSI TRACE WIRING FOUND ICP WIRING SHORTED TO SIGNAL RETURN WIRE BEHIND TURBO REPAIR WIRING AND RETEST HAS OPEN LOW FICM BOLTAGE PP TEST OPEN IN FUSE PANEL REPLACED FUSE PANEL RETEST ALL OK.
1FTSW31P04EA50734 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-AUG-2003 16-SEP-2003 156559 USA 27 2E01 030008 3C3Z 9F838 EA D42 42 17507
AWS Claim Key: 7685084 Trx Code: S07 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 08379 - * Name: ED KENLEY FORD INC Ph: 801-7764201 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2005 Doc #:73061101
Cust Comments: INT ROUGH/LOPPING IDLE COLD, LACKS POWER TAKEOFF
Tech Comments: REPROGRAM PCM, FICM, TCM, STILL RUNS POOR PERF. DIAGNOSIS REPLACED ICP RETEST ALL K
1FTSW31P04EA50734 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-AUG-2003 16-SEP-2003 156559 USA 40 * * * * * * * 23311
AWS Claim Key: 10888993 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08379 - * Name: ED KENLEY FORD INC Ph: 801-7764201 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2006 Doc #:74439402
Cust Comments: 59B01 TEST DRIVE
Tech Comments: ROAD TEST GOOD
AWS Claim Key: 10888992 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08379 - * Name: ED KENLEY FORD INC Ph: 801-7764201 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2006 Doc #:74439401
Cust Comments: RECALL 06E17 PCM
Tech Comments: REPROGRAMMED MODULES PER RECALL
1FTSW31P04EA50734 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-AUG-2003 16-SEP-2003 156559 USA 42 2H01 030008 3C3Z 6K854 DA E41 01 24586
AWS Claim Key: 11224075 Trx Code: E72 Labor Hrs: 3.6
Dlr Cd-Sub Cd: 08379 - * Name: ED KENLEY FORD INC Ph: 801-7764201 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2007 Doc #:74621401
Cust Comments: CHECK EXHAUST LEAK, EXHAUST FUMES ARE COMING INTO CAB OF VEHICLE(LEAKS ON DRIVERS SIDE?) CAB OF VEHICLE(LEAKS ON DRIVERS SIDE?) CAB OF VEHICLE(LEAKS ON DRIVERS SIDE?)
Tech Comments: VERIFIED CONCERN FOUND HOLE IN EXHAUST UPPER PIPE RR EXHAUST ROAD TESTED ALL GOOD.
post #4 of 4 (permalink) Old 04-30-2010, 11:34 PM Thread Starter
Dang thanks for the quick report!
04 F 350
Mskinner is offline
oasis request mxracer201 Ford Oasis requests 1 06-15-2009 12:18 AM
oasis request. BENDER Ford Oasis requests 3 04-06-2009 02:17 AM
Oasis request please BlueCake Ford Oasis requests 1 03-24-2009 08:07 AM
Oasis Request Please LIVIN Ford Oasis requests 1 11-17-2007 03:28 AM
Oasis Request Please G SQRD Ford Oasis requests 1 07-14-2006 10:35 AM
