3FTNW21F92MA07421 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 20-SEP-2001 12-OCT-2001 123306 USA 13 2E03 100103 YC3Z 9J323 CA L65 42 31224
AWS Claim Key: 3248172 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2002 Doc #:069157A
Cust Comments: OIL LINE THAT CAME LOOSE ON TOP OF ENGINE
Tech Comments: 31224 CK OIL LEAK W95 CHECK FOR OIL LEAK INSPECTED AND FOUND LEAK AT HIGH PRESSURE PUMP REPLACED HIGH PRESSURE LINE ASY AND FITTING ASY CHECK FOR LEAKS OK CAUSE PART LOOSE FIT ON LINE
3FTNW21F92MA07421 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 20-SEP-2001 12-OCT-2001 123306 USA 13 5I01 110204 * 3A674 * H22 42 31239
AWS Claim Key: 3248173 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:30-OCT-2002 Doc #:069255A
Cust Comments: WHEN PUTTING IN GEAR IT HAS NO POWER STEERING
Tech Comments: 31245 CHECK P S SYSTEM BLEED P S SYSTEM ROAD TEST SHOWED CUST S M #15446
3FTNW21F92MA07421 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 20-SEP-2001 12-OCT-2001 123306 USA 15 2G88 000615 * NPF * L29 42 35998
AWS Claim Key: 3978275 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:30-DEC-2002 Doc #:070825B
Cust Comments: RIGHT TURN SIGNAL INDICATOR ON INSTRUMENT PANEL STARTED BLINKING FAST LIKE BULB WAS BLOWN OUTSIDE,BUT IT WAS NOT & THEN IT STARTED BLINKING NORMAL AGAIN CUST WANTED TO MAKE
Tech Comments: 35999 W 95 CHECK BULBS & CHECK FOR SHORT NO PROBLEM FOUND
3FTNW21F92MA07421 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 20-SEP-2001 12-OCT-2001 123306 USA 15 2G88 000615 * NPF * C50 42 35998
AWS Claim Key: 3978274 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:30-DEC-2002 Doc #:070825A
Cust Comments: CUSTOMER SAYS STEERING WHEEL WILL NOT TURN WHEN SITTING STILL NO ASSIST UNTIL YOU MOVE
Tech Comments: 35999 W 95 CHECK FOR LEAKS & CHECK FLUID LAVEL & ITS OK & RUN ON OASIS & THIS IS NORMAL
No worries about the duplicate fiddy, I appreciate your help so much. Thanks. This truck has 247,000 but I think I might want it, maybe get a reasonable price as the bank has it as a repo.
Related Threads
The Diesel Garage
1.2M posts
57.3K members
Since 2005
