64/71/70 6L turbo - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by strokin6L, this thread has received 11 replies and been viewed 2901 times.
post #1 of 12 (permalink) Old 11-04-2010, 03:06 AM Thread Starter
strokin6L's Avatar
64/71/70 6L turbo
I'm gonna be selling a 64/71/70 non wastegated 6L turbo that is currently on my truck. It runs great, but i have different plans for the truck. I'm thinking about putting the stock turbo back on it and gettin the procharger kit from empire diesel. Then eventually getting the garrett powermax turbo to run with the procharger. But i'm not gonna do anything till i sell this 64/71/70 turbo...if i can. It has a polished compressor housing. If anyone is interested PM me. Here's some pics. of the turbo pedistal and drainline.
ID:	27373   Click image for larger version
ID:	27374   Click image for larger version
ID:	27375   Click image for larger version
ID:	27376   Click image for larger version
strokin6L is offline
post #2 of 12 (permalink) Old 11-04-2010, 06:32 AM
8yourv8's Avatar
can you tow with it? and what are you looking for a price?
Driving 2007 Chevy LTZ CCSB LMM so far just EGR delete, Straight Pipe, ported fuel fitting, trans-go and PPE HOT RACE
SOLD SADLY 2004 F-350 CC SB 4Inch lift 35in tires on 20s 6.0lt EGR delete ported intake AFE stage 2 SCT Tuner ARP stud's back to stock injectors CFM Large mouth and 5" Magnaflow with 4"Down pipe 6" tip
8yourv8 is offline
post #3 of 12 (permalink) Old 11-04-2010, 02:09 PM Thread Starter
strokin6L's Avatar
i never towed with it. It should be good enough to tow up to 8K lbs, nothing really heavy, but you need bigger injectors and the right programmin to do so. You should really have bigger injectors when runnin this turbo. It has roughly 8k miles on it, and i'm askin $1500 for it right now.
post #4 of 12 (permalink) Old 11-05-2010, 01:45 AM
PiRiPi's Avatar
Send a message via AIM to PiRiPi
max psi?
6.0L2005 2wd crew cab,afe intake,5" exhaust,coolant filter,high idle mod,EGR delete,APR studs,Harley lights and Grill,6000k hids,fomoto drain valve,60gal rds tool tank,egt,pyro,trans isspro gauge 2" leveling front,moog ball joints, rancho 5000's, & TUNES BY
Innovative Diesel
Soon-Air dog 2, 155 rcd injectors, vgt-ss Stage I
PiRiPi is offline
post #5 of 12 (permalink) Old 11-05-2010, 02:31 AM Thread Starter
strokin6L's Avatar
I've seen between 40-45psi with it.
post #6 of 12 (permalink) Old 11-05-2010, 02:34 AM Thread Starter
strokin6L's Avatar
I shouldn't have said that you really need bigger injectors to run this size of a turbo...but the extra fuel does help. i remember eric tellin me a while back that if runnin the stock injectors on a bigger turbo...running the x-street or x-race file will work the best for spooling the turbo so that it wouldn't be so laggy.
post #7 of 12 (permalink) Old 11-05-2010, 02:40 AM
Too much into it now...
Extended Power's Avatar
I checked with the OP before I posted this:
I have the exact same turbo.
I have run it with 190's and currently with stock injectors. (Since early summer)
It made 42+ psi of boost with the 190's, and just over 37 psi with stock injectors.
I pulled my 30 foot holiday trailer this summer, with stock injectors, with no problems at all.
The OP is correct, bigger injectors are alot more fun with this turbo, but it's nice to know that you can get the turbo before the injectors in this case.
Good Luck with the sale!!
Extended Power is offline
The Following User Says Thank You to Extended Power For this addition to TDG:
strokin6L (11-05-2010)
post #8 of 12 (permalink) Old 11-17-2010, 05:37 PM
Hi my name is Josh. Im new here and cant send a PM to you yet. I was wandering if this turbo still up for sell? If so what kind of miles do you have on it and does it have shaft play? I also seen you are looking to procharge a powermax. I have a powermax that i just put on my truck 1700 miles ago. I have 190s that i run with it and never seen over 1200 on it. Im looking for a charger like the one you have if you are willing to trade and all is good on the charger give me a call at 812-267-1394 or text me thanks.
Stroker6.04life is offline
post #9 of 12 (permalink) Old 11-17-2010, 06:16 PM Thread Starter
strokin6L's Avatar
It still is for sale and has between 8000-9000 miles on it with no shaft play. If i sell it i am going to run the stocker cause i'm still unsure what i want to do and if i still want to go with the powermax.
post #10 of 12 (permalink) Old 11-17-2010, 06:41 PM
Ok that's fine just thought I would ask thanks.
Isspro Turbo monitor or Turbo timer proud1 1994-2003 7.3L Power Stroke 4 03-12-2010 12:46 AM
1991 Ford 7.3 Non Turbo I Need To Figure Out How To Turbo It blacksmokeobs 7.3L and 6.9 IDI (Pre 1994) 7 04-01-2009 01:51 AM
E350 psd turbo vs F350 psd turbo ichthus 2003-2007 6.0L Power Stroke 5 06-08-2007 05:15 AM
Wanted: Early 99 PSD Turbo Pedistal with or without turbo. WyoDieselCowboy Whats Been Sold 3 04-22-2007 10:20 PM
Very oily tube post turbo. Means Bad turbo seals? I10HaulR 2003-2007 6.0L Power Stroke 1 03-07-2007 11:59 PM
