Rear locker - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by diesel dan, this thread has received 5 replies and been viewed 674 times.
post #1 of 6 (permalink) Old 03-17-2006, 11:50 PM Thread Starter
Destroked
diesel dan's Avatar
Rear locker
Looking for a rear locker for my 10.25 Sterling....any leads please reply.
diesel dan is offline
post #2 of 6 (permalink) Old 03-18-2006, 11:15 AM
BogginF350's Avatar
well, make sure you get one for a 10.5 instead of a 10.25. Well, a 10.25 will work in a 97 and older truck...
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #3 of 6 (permalink) Old 03-18-2006, 11:18 AM Thread Starter
Destroked
diesel dan's Avatar
Ok...I thought they were the same in all the latest years. Whatever I need for my 05' is what I gotta have....Open diffs suck!
post #4 of 6 (permalink) Old 03-18-2006, 08:46 PM
I thought the 10.25 and 10.5 internals were interchangeable :shrug:
Also, I remember reading the 05+ 10.5 went to a 37 (?) spline rear axle.I dont know if it is true or not but I did read this on TDS.
You may want to check into it and see if it's true.
nummit is offline
post #5 of 6 (permalink) Old 03-18-2006, 09:59 PM
Detroit Locker
Unbroken is offline
post #6 of 6 (permalink) Old 03-18-2006, 11:44 PM
BogginF350's Avatar
The 10.25 ring and pinion will fit in the 10.5 case with the 10.25 pinion race. The race was just modified from a 10.25 case to put the pinion 1/8 inch deeper to accept the 10.5 ring gear. I am not sure if they will interchange, now that I think of it they should.... I bolted the 10.25 ring on a 10.5 trac lock in my 03`. And for the 05 and later I am pretty sure that only the Drw had the 37 spline. (dana 80) anyhow the pinion is the weak link on a sterling I almost twisted mine off. It was bent and had about 6 or 7 stress cracks in it.
Josh Davis
6.0L Ford
6.4L Ford
(309) 699-2488
