16k Reese Fifth Wheel Hitch w/Kwik-slide, out of a 2001 Dodge Ram 2500 short bed.
4-Way Pivot
Usable with full-size or mini-trucks.
5o side-to-side pivot to better accomodate hook ups on uneven ground.
Removed easily from the truck bed by pulling four pull pins.
Feature a dual jaw locking system. This jack locking mechanism surrounds the fifth wheel king pin to assure proper towing. Also include cushion handle grips and durable powder-coat black paint finish.
16K Fifth Wheel w/Kwik-Slide features:
Kwik-Slide rollers have a position indicator and latching system
Designed for shortbed trucks to provide turning clearance and prevent damage to truck and trailer in tight spaces at low speeds
release the high-leverage handle
set your trailer brakes
pull forward to slide it into position
Adjustable with trailer attached
Patent Pending
Less torque fatigue for a smoother, more comfortable ride
Removes in seconds for full access to the truck bed
Adjusts from 15" to 18" high
16,000 lb. capacity, 4,000 lb. Pin weight capacity
Reese recommends the use of a 13" minimum extended pin box on trailer.
Will sell for $350.00.
Perfer local pick up, but will ship via UPS. Will have to get quote for shipping price to your address. I am sure shipping will be very expensive though. Location Rancho Cucamonga, CA
4-Way Pivot
Patent Pending
