Trade 12V for NV4500 conversion - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TLadd, this thread has received 0 replies and been viewed 1284 times.
post #1 of 1 (permalink) Old 04-24-2009, 10:45 PM Thread Starter
Wanting to trade a 12V Cummins Turbo Diesel for a 5-speed conversion with everything needed to convert from automatic to manual. Manual transmission must be rebuilt(1998-2002) and come with bell housing, need either NP 241 DHD transfer case or the input shaft conversion for the NP241 DLD, need clutch hydraulic system, driveshafts for an extended cab long bed, a clutch, and clutch fork. 12V engine came from a 1990 Dodge Ram 250. Engine comes with refurbished cylinder head with new valve stem seals and a valve job. New head gasket, oil pan gasket set, timing cover gasket set, newer oil pan, VE Injection Pump, turbocharger off of a newer 24 Valve Dodge(2003-2004) extra set of valve covers, adapter plate, and a set of ARP Head Studs. If you think you can make a deal and/or have some amendments to the above paragraph, please PM me , Thanks. Also have a 47RH 4x4 transmission and possibly NP241DLD(if I don't receive one with a 5 speed) that I won't be needing after the conversion.
TLadd is offline
Nv4500 TheNightmare 5.9L Cummins 12 Valve (1994-1998.5) 2 03-11-2008 01:28 AM
zf5 vs. nv4500? danktank6.9 7.3L and 6.9 IDI (Pre 1994) 6 02-22-2008 11:27 PM
2wd NV4500 COnversion Kit Dazedandconfused Whats Been Sold 1 12-05-2007 03:28 AM
NV4500 conversion Dazedandconfused Whats Been Sold 0 12-01-2007 08:01 PM
Everything needed for nv4500 conversion? CJW 5.9L Cummins (Pre 1994) 4 01-22-2007 02:47 PM
