Fass 150/180 w/ Itp RR $600 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dusty's Diesel, this thread has received 10 replies and been viewed 2462 times.
post #1 of 11 (permalink) Old 04-12-2010, 02:55 AM Thread Starter
Dusty's Diesel's Avatar
This is off my truck everything worked great when it was pulled. The gears on the pump have been teflon coated by Fass to prevent falure. I went through several of these than they did that for me and never had another problem. The ITP RR is complete other than the piece that mounts on the side of the filter housing. I eliminated my filter and just put a tee there to the heads. I also ran braided hose from were the Fass lines stoped up to the motor to up the volume. This setup would hold 62 psi under Wot w/ any of the injectors that was in my truck. 225's and 190's. Buyer will have to pay shipping. Thanks Dusty
Dusty's Diesel is offline
post #2 of 11 (permalink) Old 04-13-2010, 07:10 AM
Big Stroker
Keanoknick's Avatar
Send a message via MSN to Keanoknick
How much for just the FASS system, I don't need the ITP RR kit, I already have RR kit installed.
Thanks
2005 F250 CC SB FX4
8" lift; 38.5" Procomps; ARP Headstuds; Banks Intercooler and High Ram Elbow; 4" Exhaust; SCT with custom tunes by Tony Wildman; Isspro Performax guages; '08 TT mirrors; Bushwacker Pocket Style Flares; Recon somked cab and mirror lights; Frontier front bumper replacement; AMP Research power runnning boards; Fabtech floating traction bars
North Texas Powerstroke Association www.NTxPSA.com
Riding High Club #3
Ridin' Dirty Club #10
American Club #39
Keanoknick is offline
post #3 of 11 (permalink) Old 04-20-2010, 02:42 AM Thread Starter
$550 shipped in the lower 48 for everything. Don't want to split it up sorry
post #4 of 11 (permalink) Old 04-21-2010, 05:50 PM
So you dont have that filter housing fitting laying around somewhere?
'03 F250 CCSB SRW, SCT, K&N, MBRP STRAIGHT PIPED, SNOW STG 3, LIFTED 6" ON 37'S, RCD's EGR DELETE, AP HD200, TP STG 1 FUEL SYSTEM, HYPERMAX STG 1 INJECTORS, ARP'S, ID TUNED, VARIOUS LITTLE GOODIES...
R33615 is offline
post #5 of 11 (permalink) Old 04-22-2010, 12:18 PM Thread Starter
No it went in the trash when I took it off. I am sure you can get one from itp.
post #6 of 11 (permalink) Old 04-23-2010, 08:16 PM
SLAPS President
teamroper60's Avatar
Images: 9
Actually, you can't. This is from their website page for the RR system:
NOTE: WITH THE EXCEPTION OF FUEL PRESSURE REGULATORS AND LIQUID FILLED FUEL PRESSURE GAUGES, WE DO NOT SELL INDIVIDUAL PIECES OF OUR FUEL SYSTEMS.
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #7 of 11 (permalink) Old 04-29-2010, 02:17 AM
vcassens's Avatar
can you give me a compleat run down on every thing that is included does it have everything from the tank to the motor or does it tie into the factory lines and does it fuel from both front and rear or just the front thanks and where are you located
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #8 of 11 (permalink) Old 04-29-2010, 12:48 PM Thread Starter
Everything is there. The Pressure line from the pump runs all the way from the pump to the motor. The return line from the motor ties into the factory hard line. The only thing you need for this to work is the compression fitting to go from the return line to the hard line. I don't know what you mean front or back?? I am in ohio. You don't have to cut your filter housing off you can just mount the tee beside it and just not use it.
post #9 of 11 (permalink) Old 05-03-2010, 02:33 AM Thread Starter
$450 shipped in lower 48 I want this off my bench in the shop
post #10 of 11 (permalink) Old 05-03-2010, 03:31 AM
vcassens's Avatar
will the fass pump warenty if any still be honored? and if it has a warenty what is it thanks
singles club #206
bomb squad #67
vcassens is offline
Air Dog or Fass $? Morpheus cycles Supporting Vendors Forum 6 05-10-2009 06:40 PM
FASS 150/180 for an 03 6.0L WHITEPOWERstrok Supporting Vendors Forum 3 02-11-2009 08:47 PM
Fass GhettoMedic Supporting Vendors Forum 1 02-08-2009 04:32 PM
fass 150 help!! bagged_s_dime 5.9L Cummins (2003-2007.5) 5 06-14-2007 01:12 PM
FASS 95 vs. 150 dieselbm 5.9L Cummins (2003-2007.5) 4 07-31-2006 08:22 PM
