Diesel Truck Forum - TheDieselGarage.com - View Single Post - xlnt coolant write up-should be a sticky
View Single Post
post #10 of (permalink) Old 07-07-2011, 03:02 PM
NYC F-350
NYC F-350's Avatar
To help prevent the coolant from flowing into the intake during your flushing process, you can just unplug the EGR valve. Unplug it when the truck is cold and off. It should be OK to do this for your flush, since your not likely to overboost it and force the valve open and since you will be relieving the pressure on the cooling system, the chances of hydrolock are minimal.
Unplugging the EGR valve will throw a code and illuminate the CEL.
NYC F-350 is offline
