7.3 CPS Recall - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by John_DeereGreen, this thread has received 4 replies and been viewed 10271 times.
post #1 of 5 (permalink) Old 12-28-2008, 10:05 PM Thread Starter
TDG Mafia #76
John_DeereGreen's Avatar
7.3 CPS Recall
This was posted over on Powerstroke Nation:
Originally Posted by FTE
TO: All U.S. Ford and Lincoln Mercury Dealers
SUBJECT: Safety Recall 07S57:
Certain 1997 - 2003 F-Super Duty, Excursion, and E-Series Vehicles
Equipped with 7.3L Diesel Engines
Camshaft Position (CMP) Sensor Inspection / Replacement
AFFECTED VEHICLES
Vehicle Line Model Years Assembly Plant Production Dates
Econoline 1997-2003 Lorain Assembly Plant 4/3/1996 - 9/16/2003
Excursion 2000-2003 Kentucky Truck Plant 3/25/1999 - 11/1/2002
F650/750 Series 2000-2003 Cuautitlan Assembly Plant 1/20/1999 - 10/31/2002
F-Series 1997 Kentucky Truck Plant 6/18/1996 - 12/17/1997
F-Series 1997 Cuautitlan Assembly Plant 6/11/1996 - 12/10/1997
F-Series 1999-2003 Kentucky Truck Plant 9/3/1997 - 11/4/2002
F-Series 1999-2003 Cuautitlan Assembly Plant 10/2/1998 - 7/21/2003
Affected vehicles are identified in OASIS. In addition, for a list of vehicles assigned to your dealership,
visit [url
https://web.fsavinlists.dealerconnection.com[/url] . This information will be available on December 04,
2007.
REASON FOR THIS SAFETY RECALL
In some of the affected vehicles, the Camshaft Position (CMP) Sensor may fail due to circuit
degradation. If the CMP Sensor should fail, the engine may stall. In the event of an engine stall, a
crash could result without warning. A new CMP Sensor with improved reliability is now available.
SERVICE ACTION
Dealers are to inspect the CMP Sensor to verify which design level sensor is installed in the affected
vehicles, and replace all prior level sensors. This service must be performed on affected vehicles at no
charge to the vehicle owner.
OWNER NOTIFICATION MAILING SCHEDULE
Parts to repair this condition are currently not available in sufficient quantities to service all of the
affected vehicles. Therefore, to ensure that an ample supply of parts is available, owners of affected
vehicles will be notified in separate phase mailings over several months. Phase mailing will begin the
week of December 17, 2007; prioritized by age of vehicle. Dealers should repair any affected vehicles
that arrive at their dealerships, whether or not the customer has received a letter.
You can go to:
http://www.ford.com/owner-services/c...ll-information
Jarrett
04.5 qcsb commonrail
Smarty TnT
John_DeereGreen is offline
post #2 of 5 (permalink) Old 12-28-2008, 10:06 PM Thread Starter
TDG Mafia #76
Sticky for anyone new coming in?
This was a sticky before.
I'm going through Google's caches to help rebuild the site.
Jarrett
Smarty TnT
post #3 of 5 (permalink) Old 12-29-2008, 01:29 AM
MAFIA MEMBER 106
camojeeper's Avatar
dont do the recal until yours fails lots of people my self includid have seen loss of mpg and idle issues also the gray cps has problems with cyl cont tests so if you still have a black one keep it
STEVE TDG MAFIA#106
camojeeper is offline
post #4 of 5 (permalink) Old 12-29-2008, 01:43 AM Thread Starter
TDG Mafia #76
I haven't had a bit of trouble with mine, Steve...
Well, since I can't submit another post, I'll edit this into it:
Curtis (Pocket) sent this to me in a PM and since he can't add to the thread, I'll add it in.
Originally Posted by Pocket
I wanted to add to the sticky thread, but since the forums got wiped out, I can't post to any sticky thread yet until my post count comes up.
Anyway, there is a Ford TSB out about the CPS recall. I was going to post that since it goes hand in hand with the recall itself.
The grey CPS can cause issues, and Ford knows it. If anyone wants to go forward with the recall, they need to know of potential issues that can pop up, so that they know where the problem is. Otherwise, they might spend extra time and money chasing a phantom problem (ie: cylinder contribution tests, IDM test, etc.). Here is the information regarding the TSB:
203 - SOME 1997 THROUGH 2003 MY 7.3L VEHICLES MAY EXHIBIT A PHANTOM P0284, P0281, P0278, P0275, P0272, P0269, P0266, AND/OR P0263 DIAGNOSTIC TROUBLE CODE (DTC)
SOME 1997 THROUGH 2003 MY 7.3L VEHICLES MAY EXHIBIT PHANTOM P0284, P0281, P0278, P0275, P0272, P0269, P0266, AND/OR P0263 DIAGNOSTIC TROUBLE CODES (DTC) WITHOUT DRIVABILITY SYMPTOMS IN CYLINDER CONTRIBUTION TEST (CCT) ON VEHICLES EQUIPPED WITH A NEW STYLE (GRAY) CMP SENSOR. THE NEW STYLE SENSOR WOULD HAVE BEEN INSTALLED UNDER SAFETY RECALL 07S57. ENGINEERING IS CURRENTLY WORKING ON A RESOLUTION TO ELIMINATE THE PHANTOM CODES.
Hope this helps add a bit of info to the thread.
Thanks,
Curtis
Jarrett
Smarty TnT
Last edited by John_DeereGreen; 12-29-2008 at 05:54 PM. Reason: Added info that Curtis sent me
post #5 of 5 (permalink) Old 12-29-2008, 02:17 AM
Super Moderator
4rcFed's Avatar
Images: 12
For some reason, your link that you posted didn't work for me.
Here is the link that I have used before:
Link to Customer Support for Recall Information
4rcFed is offline
The Following User Says Thank You to 4rcFed For this addition to TDG:
CHEROKEE 57 (05-30-2009)
ford recall information camojeeper 1994-2003 7.3L Power Stroke 2 01-03-2009 02:57 AM
