Diesel Truck Forum - TheDieselGarage.com - View Single Post - 6.0 Alphabet soup - making sense of all the Jargon
View Single Post
post #1 of (permalink) Old 02-16-2013, 07:03 PM Thread Starter
Weld engineer
Weld engineer's Avatar
Neeltburn
Hopefully we can make this a sticky after some feedback and review
https://www.thedieselgarage.com/uploads/6_0bible.htm
AR – Archoil oil additives (manufacturer)
ARP – Manfacturer of studs for replacing stock head bolts
AP – Accelerator pedal
Baro – barometric pressure
BST – Boost or pressure created by the turbo at the intake of the engine
CAT – Catalytic converter
CKP – crankshaft position
CMP – Camshaft position
ECT – Engine coolant temperature
EGRVP – Exhaust gas recirculation valve position
EOP – Engine oil pressure (it is a switch on the 6.0 not a real gauge)
EP – Exhaust pressure
EBP –Exhaust back pressure
ELC – Extended life coolant (some members prefer it over Ford Gold coolant normally associated with Caterpillar)
ECM – Electronic Control module
EGR – Exhaust gas recirculator (valve) (cooler)
ESOF – Electronic shift on the fly (vacuum actuated lockouts and transfer case actuator)
FICM – Fuel Injection Control Module
GPCM – Glow plug control module
HEUI – Hydraulically actuated Electronically controlled Unit Injector (Caterpillar design licensed to International)
HG- Head gaskets
HFCM – horizontal fuel conditioning module (located on the frame rail and has 1st stage filter in it and water separator
HPOP – High pressure oil pump (supplies the injectors with high pressure oil for injecting fuel into the cylinders)
IAT1 – intake air temp 1
IAT2 – intake air temp 2
ICP – Injection control pressure (a sensor near turbo on 2003 and early 2004, on the passenger side valve cover of all later models)
IPR – Injection Pressure regulator (used to adjust commanded oil pressure to the injection system
MAF – Mass air flow
MAP – Manifold absolute pressure
MC – Motorcraft (Ford OEM)
OEM – Original equipment manufacturer
PCM – Progammable control module
REV-X – a brand of oil additive (manufacturer)
SCT – a brand of tuner that programs the PCM with engine and transmission file to create a particular performance level
SG2 – Scangauge 2 (or II it is a low cost gauge that can display most of the 6.0 sensors and diagnostic codes works off of the OBD-II port while engine is running)
TFT – Transmission fluid temperator
TTY – torque to yield (stock head bolts are torqued until they yield unlike ARP studs)
VGT – Variable Geometry Turbo – (Garrett Design)
VGTCV – Variable Geometry control valve
VVT – Variable Vane Turbo – (see VGT)
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
The Following 5 Users Say Thank You to Weld engineer For this addition to TDG:
Bderick67 (02-22-2013), bear1 (06-09-2013), harry6.0 (02-17-2013), mabynack (10-28-2014), MT Pockets (02-17-2013)
