Diesel Truck Forum - TheDieselGarage.com - View Single Post - 6.0 Alphabet soup - making sense of all the Jargon
View Single Post
post #6 of (permalink) Old 04-14-2013, 02:56 PM Thread Starter
Weld engineer
Weld engineer's Avatar
Addition to list
STC -
Snap To Connect - is a fitting in the HPOP system that is prone to failure on later models of the 6.0 high pressure oil system. It is found near the pump. Upgraded versions are available to remedy the issue
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
The Following User Says Thank You to Weld engineer For this addition to TDG:
broncobob (04-14-2013)
