Diesel Truck Forum - TheDieselGarage.com - View Single Post - Doh! Anyone else do this while installing your DP?
View Single Post
post #1 of (permalink) Old 05-22-2013, 05:46 PM Thread Starter
mcstiggens
So I got my MBRP DP done in about two hrs. Not bad gauging from some of the horror stories I've heard. And I did it solo. I just used the sawzall to cut the stock DP and then the sawzall to cut the seam or pinch-weld thingy, then a digging bar to torque it outa the way and : Wa-la DONE!
However..... I was not able to take'er for a test drive cause, as much of a pain as the DP install was, I just HAD to make my life even MORE difficult.
While kneeling under the hood....all up on the DP zone where I'm concentrating on making space with a pry bar/sawzall etc., I managed to break off the plastic nipple on my radiator that connects the rubber hose to the overflow/filler bottle. Yea, you know the one........pretty important....
SO, the question is, is there a crafty fix for this? I'm guessing JB Weld might be too hoopty a fix in this case.
Any suggestions...other than plop down a few hundred for a new radiator?
Anyone done this yet or am I first?
Much thanks,
Mcstiggs
mcstiggens is offline
