Tank's library - Page 3 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TANK'S 250, this thread has received 25 replies and been viewed 21727 times.
Closed Thread
post #21 of 26 (permalink) Old 12-23-2008, 04:04 AM Thread Starter
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
As for the bumper...you have to do that last,..and you have to "eye-ball" a good line to cut,...use a grease pencil to draw a line that you'll want to cut....try to follow the arch of the flares...I didn't get mine exactly how I wanted it....but I made my own bumper...so it doesn't matter about matching once you put an aftermarket bumper on.
The flares come with a rubber edge molding, that goes between the flare and the fender,...I had some left over,... so I glued it to the cut area on the bumper.
Finished product:
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #22 of 26 (permalink) Old 12-23-2008, 04:04 AM Thread Starter
TANK'S 250's Avatar
Images: 38
Before:
After:
Schrapnel:
[/QUOTE]
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #23 of 26 (permalink) Old 12-23-2008, 04:05 AM Thread Starter
TANK'S 250's Avatar
Images: 38
Differences between Early 99 & late 99
Early 99 has a wicked wheel in it from the factory.
The early99 has 120cc(AB code) injectors and the late99-03 has 140cc(AD code) injectors.
The early99 has 2" intake runners. The late99-03 has 3" intake runners.
The early99 has a 15* swash plate HPOP. The late99-03 has a 17* swash plate HPOP.
The early99 has one glow plug relay. The late99-03 has one glow plug relay and one air intake heater relay side by side. Both relays are on the passenger side valve cover toward the front of the truck.
The early99 has a totally different air filter that is not inter changeable with the late99-03. But you can put the late99 air cleaner assembly in the early99 truck. The only two aftermarket air filters that work on the early99 are the AFE stage 2 and the AIS.
The early99 track rod has smaller mounting bolts than the late99-03.
The early99 has shallower rotors than the late99-03.
The early99 has shorter hub-bearings than the late99-03.
The early99 front axle U bolts are square where they go over the spring pack. The late99 U bolts are round.
The early99 has a different pitman arm than the late99-03.
The early99 does not have the AIH like the late99-03.
The early99 does not have the automatic transmission fluid cooler in the radiator.
The early99 has no indicator light showing that "cruise" is on. Late99-03 has a cruise light that will come on when you set the cruise control. The early99 truck has the light in the dash already. A newer PCM(Yes it will plug in and will run better too) must be used to make the cruise light illuminate. It is a green light on the right side edge, half way up.
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #24 of 26 (permalink) Old 12-23-2008, 04:06 AM Thread Starter
TANK'S 250's Avatar
Images: 38
AXLES:
axles
1977-PREVIOUS F350, F250 snowfighter: low pinion dana 60, very weak.....
1978-1979 F350, F250 snowfighter: high pinion dana 60, kingpins, 35 spline outters, 30 spline inners, internally splined lockout hubs
1980-1985 F350/F250: high pinion TTB dana 50
1986-1991 F350: solid high pinion dana 60, king pins, 35 spline outers, 30 spline inners, internally splined lockout hubs, different spring spacing that 78/79 axle
1986-1989 F250: TTB dana 44HD/ TTB dana 50, both high pinion
1991-1997 F350: solid dana 50/solid dana 60, 50 hase smaller ring gear and axle shafts than 60
1990-1997 F250: TTB dana 50, high pinion
1999-2008 F250: solid dana 60, solid dana 50, both high pinion, metric pattern
1999-2008 F350: solid dana 60, high pinion, metric pattern
2002 and up f250, f350 and f350 DRW have the dana 60 front diff. 99-2001 f250 and f350 SRW have dana 50 front diff. 99-2001 f350 DRW have dana 60 front diff
LUG nuts:
You need 14mmx2.0
Ford didn't change to the 14mmx1.5 until 2003.
Special thanks to:
KLMperformance.com
Black Ops Bumpers
post #25 of 26 (permalink) Old 12-23-2008, 04:24 PM
plainredtruck's Avatar
Images: 11
That's a rather impressive list, Tank.
Much thanks.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #26 of 26 (permalink) Old 12-30-2009, 04:20 PM Thread Starter
TANK'S 250's Avatar
Images: 38
Replacement Light Part Numbers:
2004 FORD F250-F550 (With halogen capsule headlamps)
High & low beam headlamp
9007
9007SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9007ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9007EB EcoBright - Your Environmental Choice
9007XV XtraVision Halogen - The Brighter Light
9007CB Cool Blue Halogen - The Whiter Light
Parking light
3157NALL
3157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
3157NALL
Rear turn signal
3157LL
Tail light
3157LL
Stop light
3157LL
High mount stop light
922
922LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
9145
9145ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
3156LL
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Glove box
161
161LL Long Life Upgrade: Up to twice the life of the standard lamp
Dome light
578
912
912LL Long Life Upgrade: Up to twice the life of the standard lamp
Step/Courtesy light
168
Trunk/Cargo area
906
906LL Long Life Upgrade: Up to twice the life of the standard lamp
Special thanks to:
KLMperformance.com
Black Ops Bumpers
The Following User Says Thank You to TANK'S 250 For this addition to TDG:
John_G (11-13-2010)
Closed Thread
