Need some help selecting a big cutoff switch. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 5 replies and been viewed 1298 times.
post #1 of 6 (permalink) Old 04-03-2015, 01:35 AM Thread Starter
I thought this was going to be an easy search. I have used battery cut off switches many times in the past. But I think I might be looking in the wrong direction. I have looked at page after page of cutoff switches and the selections in the parts stores is terrible.
So here is the plan. I am running 2 gauge battery cable from the battery to the back of the truck so I can power the winch on my trailer. I want to install a cutoff switch in the cab so the cable is not hot all the time. I want the switch to handle the power, be somewhat simple to install, and not look too bad all at the same time. Any suggestions?
post #2 of 6 (permalink) Old 04-04-2015, 05:01 PM
Jasong's Avatar
Since you won't be switching under load I'd suggest a knife switch.
Jasong is offline
post #3 of 6 (permalink) Old 04-06-2015, 02:47 AM
Dodgefarmer's Avatar
If you haven't looked yet, NAPA has around 25 different Master switches in their catalog. Also Caterpillar used Master disconnect switches in a lot of there equipment. Don't know if they will meet your needs but give them a try.
singles club # 198
Dodgefarmer is offline
post #4 of 6 (permalink) Old 04-06-2015, 03:40 AM
singles club # 198
post #5 of 6 (permalink) Old 06-10-2015, 11:33 PM
There are a couple different ways you could do this ,on our liftgate trucks we use a 150 amp resetable circuit breaker.we purchase these from Ryder fleet products,you can go to their website and search Bussmann CB185-150.another way is use a frame mounted continuous duty solenoid and activate it with a toggle switch in the cab.also at ryder fleet products the sell many master disconnect switches. Bob
burkeftm is offline
post #6 of 6 (permalink) Old 06-11-2015, 12:47 PM Thread Starter
Thanks, I had not thought of that.
please help me with selecting a tuner powerstroke90 2003-2007 6.0 Tuner Forum 30 11-04-2009 02:02 AM
Where's fuel cutoff selenoid? SchaefferUSMC 7.3L and 6.9 IDI (Pre 1994) 3 01-13-2008 08:17 PM
safe pyro cutoff temps 06 lbz allison with outlook and triple dog smokin in vt LBZ & LLY Tuner Forum 0 08-09-2007 01:01 AM
Intermitent cutoff AaronS 1994-2003 7.3L Power Stroke 11 04-22-2007 03:15 PM
Early 99 - 99.5 cutoff date? Snowaholic 1994-2003 7.3L Power Stroke 7 08-08-2006 10:37 PM
