Weird: Rolls Royce Diesel Wankel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kargerthepinko, this thread has received 12 replies and been viewed 17858 times.
post #1 of 13 (permalink) Old 03-03-2010, 03:25 AM Thread Starter
I wasn't sure where to put such an odd thing so I chose the PL...
kargerthepinko is offline
post #2 of 13 (permalink) Old 03-03-2010, 04:04 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
Now that does look pretty darn cool
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 13 (permalink) Old 03-03-2010, 11:04 AM
gone fishin!
its a 10,000 rpm coal roller!!!!
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #4 of 13 (permalink) Old 03-03-2010, 04:18 PM Thread Starter
Yeah you imagine what that sounded like?
post #5 of 13 (permalink) Old 03-03-2010, 04:25 PM
CRAZY CANUCK
it would sure make someone look long and hard..... the 2-R6 made 350BHP, and only weighed 939lbs.... and you could turbocharge or super charge it..... how much HP would it produce then? the only thing i dont see is the Torque #'s which is what a diesel is famous for... id like to see how much torque it made, and where in the RPM band it made it, because even if it does roll to 10000rpm, if it cant move the load whats the point?
Ridin Dirty Club #5
TDG TOTQ
post #6 of 13 (permalink) Old 03-03-2010, 05:00 PM Thread Starter
Wankels have a relatively low level of torque compared to a piston engine because it has very low rotational mass.
post #7 of 13 (permalink) Old 03-03-2010, 07:49 PM
I Eat Rice
forcefed6.4ford's Avatar
you wouldnt need alot of torque with that kind of hp. Look at a F1 engine. 800-900hp and less then 300ftlbs.
A turbo or a supercharger wouldnt be needed either. the large lp weinkle is the supercharger.
IF.... you convert the numbers based on a 1265cc displacement. Bump the diplacement to modern levels. the number is
1770hp
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #8 of 13 (permalink) Old 03-03-2010, 10:19 PM
gone fishin!
there are a bunch of 2 and 3 rotor wankle's in the 1000-1200 hp power levels.....i just didnt think you could build enough compression with a rotory to fire off diesel.........but the sky is the limit hp wise...no HG....no crank.....no valve float.....the hold on the rotry now is how to get enough oil to the bearings fast enough to keep the harmonics from killing the bearings..... its not uncomon to see a 3 rotor making 1200hp and 100-120psi boost at 10+ thousand rpm!!!
post #9 of 13 (permalink) Old 03-03-2010, 10:27 PM Thread Starter
Wankels see a lot of leakage through seals. Apparently it's difficult to close up the engine and isolate the intake and exhaust sides.
However, very high compression can be obtained as long as the materials are strong enough.
post #10 of 13 (permalink) Old 03-03-2010, 10:41 PM Thread Starter
Also, here is what a ****** wankel sounds like...
(I couldn't find a diesel)
Weird sound RHCDIESEL 2003-2007 6.0L Power Stroke 11 06-15-2009 03:06 AM
Weird sounds slow23bj 2008-2010 6.4L Engine Tuner Forum 22 05-22-2009 09:18 PM
Just GOT SCT and weird issues? dayusex 2003-2007 6.0L Power Stroke 5 12-03-2007 03:02 AM
Weird Weather King of Obsolete Medium and Heavy Duty 6 11-25-2007 08:36 PM
Weird..... Billysgoat Dodge Performance Forum 16 06-04-2005 02:22 PM
