Low windshield waher fluid warning - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by darren32, this thread has received 8 replies and been viewed 1900 times.
post #1 of 9 (permalink) Old 12-06-2010, 03:54 PM Thread Starter
darren32's Avatar
Is there no low windshield washer fluid warinig light? Just ran out of fluid and no light came on. I can't find anything in the manual so maybe there isn't one? Seems a bit odd....
Thanks
darren32 is offline
post #2 of 9 (permalink) Old 12-06-2010, 03:59 PM
bushpilot's Avatar
you kidding me ?
part of RESPONSIBLE ownership REQUIRES you to periodically open the the HOOD & check
ALL the fluids - including OIL, Transmission, Power Steering, Coolant *AND* washer fluid(s) !
Don R.
Truck Audio,
bushpilot is offline
post #3 of 9 (permalink) Old 12-06-2010, 04:11 PM Thread Starter
darren32's Avatar
I do, that is why this is the first time I have run out. With the road conditions here I went through the whole thing in 2 days. Would be nice to know before you run out.
darren32 is offline
post #4 of 9 (permalink) Old 12-06-2010, 04:32 PM
bushpilot's Avatar
i hope youre using a diluted mixture, some of that stuff can be
pretty rough on the paint & soft parts.
you must really burn thru some windshield wiper blades then too.
No edition of the superduty, that i am aware of, has EVER had a
windshield washer fluid level sensor.
none of my cars have it either <do your cars have 'em level sensors/arms> ?
the jug on my superduty is close to, if not over, a gallon in capacity.
Don R.
Truck Audio,
post #5 of 9 (permalink) Old 12-06-2010, 04:48 PM Thread Starter
darren32's Avatar
Bushpilot, yes I do, I am on my second set of blades already. I can't dilute the fluid much or it freezes. When it heats up in the winter here and the roads melt a bit you pretty much need to use the washer fluid continuously. This is my first Ford so just suprised me as all my other vehicles had it. For me it was nice to know you were low so you didn't have to pull over and fill it up on the side of the road. I have been driving Toyota Tundra's since they came out until now and they all had it. My wifes old Honday CRV had it and her Lexus has it. Even my 1988 Dodge 1500 had it. Not a big deal, I will just fill it up more often when the roads are messy. I was not keeping a close eye on it because I assumed there would be a low warining.
Anyway, thanks, now I don't have to go to the dealership and tell them something I don't have is not working!
darren32 is offline
post #6 of 9 (permalink) Old 12-06-2010, 04:49 PM
I've never dilluted the stuff with ZERO problems. I wish there was a sensor, all the other vehicles I have owned have had them.
2011 F350 CC/SB FX4
Tuxedo Black and Black interior
295/60R20 Nitto Terra Grapplers
6,000k HID Hi/Lo beams
Line-X
11Strokin is offline
post #7 of 9 (permalink) Old 12-10-2010, 03:32 AM
nitrogen's Avatar
my semi has about 2-2.5 gallons and i have emptied it in less than 2 days, our roads get sloppy up here, when a chinook blows in. drive through the city and i have basically run the wipers nonstop, and the washers every 15-30 seconds for 45 minutes straight
Canadian Club #31
nitrogen is offline
post #8 of 9 (permalink) Old 12-10-2010, 03:29 PM
4play's Avatar
Not directed to the OP but, If you use that much washer fluid you just need top it off sooner or every morning or evening for awhile until the road conditions get better. I understand the convenience of the sensor but I dont think it should have one just because other cars do.
Things like these make me wonder if all engines had low oil level sensors, would that make people never check their oil until its that low?
4play is offline
bushpilot (12-10-2010)
post #9 of 9 (permalink) Old 12-13-2010, 01:10 PM
EpicCowlick's Avatar
My 99 Expedition and 2000 Excursion had the sensors in the washer fluid tank.
2017 Ford F350
60 gallon S&B fuel tank
2.5 Readylift level
Viair dual compressor onboard air system
Airlift wireless airbags
https://www.youtube.com/channel/UCsu..._as=subscriber
EpicCowlick is offline
windshield visors nickdoni 2008-2010 Body & Suspension 4 11-12-2009 10:38 AM
I need a new windshield WasGas 2003-2007 6.0L Power Stroke 0 05-29-2009 06:24 AM
tinted windshield Sethc08 General Dodge Discussion 10 08-13-2007 05:26 PM
Help me think of something to put on my windshield Teelo The Parking Lot 19 06-23-2007 07:28 AM
foggy windshield 2006f250bob General Ford Truck and Excursion 7 11-19-2006 02:18 PM
