6.7 Down With Pics - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jeffro, this thread has received 34 replies and been viewed 7295 times.
post #1 of 35 (permalink) Old 01-11-2011, 02:01 AM Thread Starter
6.7 Down With Pics
So a truck came into the shop this weekend. Complaint is vehicle stalled and will not start. Compression check shows problem on bank one. Manual compression check of cyl 4 shows 0 psi compression. When glow plug was removed it was noticed that tip was missing. Removed injector and found tip of injector damaged. Engine will come apart tomorrow. I am not the tech working on this vehicle but I am watching closely to see what is going on.
jeffro is offline
post #2 of 35 (permalink) Old 01-11-2011, 02:05 AM
fine69's Avatar
That CANT be good!
H-M.W.H. Club #2
Union Club #1
Singles #237
B.O.M.B. Squad #12
Ridin' Dirty Club #17
American Club #15
fine69 is offline
post #3 of 35 (permalink) Old 01-12-2011, 05:41 AM
Euro Sparky/ Wrencher
french277's Avatar
I have one question on this series of the engine how far do the glowplugs extended to the cylinder area ??
Merci.
Marc
Pas de problème,il marche n'est-ce pas?"(No problem, it works doesn't it?)
french277 is offline
post #4 of 35 (permalink) Old 01-12-2011, 07:46 AM
4play's Avatar
This looks like the same thing I saw a couple months ago
Posted here
Merci.
Marc
The glow plugs go through the valve cover, into the head and the tip is directly in the combustion chamber. They dont really stick out in the combustion chamber as there is no room when the piston is at TDC. BTW the glow plugs and injectors go through the valve cover and are serviced without removing the covers, just the inner fender and a few noise shields and GPM on RH side
4play is offline
french277 (01-13-2011)
post #5 of 35 (permalink) Old 01-12-2011, 04:44 PM Thread Starter
Don't know what happened first. Glow plug failure or valve failure? All I know is a whole lot of parts get damaged. If you look at one angle, the glow plug has a bulge near the base. I would think this is from something hitting the tip and causing the damage. I'm not an engineer but I would think that would mean something was in the cylinder that hit the glow plug before it broke.
jeffro is offline
post #6 of 35 (permalink) Old 01-12-2011, 05:45 PM Thread Starter
Here are some more pics. In MY opinion I think it dropped a valve or valve seat and then everything came apart. We will never know for sure......
jeffro is offline
post #7 of 35 (permalink) Old 01-12-2011, 06:24 PM
Mafia member #6
Rutcutter's Avatar
So when does the new engine go in?
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
post #8 of 35 (permalink) Old 01-12-2011, 06:47 PM
Administrator
fordt's Avatar
Images: 5
Excellent pictures!
Please keep us updated.
Any idea if there was a prgorammer, or anything aftermarket involved?
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #9 of 35 (permalink) Old 01-13-2011, 12:36 AM Thread Starter
New engine should be here soon. I don't think there is an issue of a aftermarket program. I think was just one small part failure that caused a lot of damage. I am sure all the old parts will be called back and inspected and a solution will be found.
I checked how far the glow plug sticks into the cyl and it looks like 3/8 of an inch. They do stick in more than a 6.0 or 6.4.
jeffro is offline
The Following User Says Thank You to jeffro For this addition to TDG:
post #10 of 35 (permalink) Old 01-13-2011, 05:14 PM
Where are the pictures? They aren't popping up on my computer nor is a link to them.
Truckmaniac is offline
08 450 pics BIG BLACK DUALLY The Parking Lot 33 05-04-2009 01:03 AM
got some pics Orangepstroke 1994-2003 7.3L Power Stroke 25 01-01-2008 04:29 AM
A few new pics Betaracer General Ford Truck and Excursion 4 08-15-2006 10:59 AM
And A Few More pics........ bigdraft The Parking Lot 1 05-15-2006 08:54 PM
