2011 won't idle up in the cold - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4mcntrls, this thread has received 7 replies and been viewed 7215 times.
post #1 of 8 (permalink) Old 01-13-2011, 04:00 PM Thread Starter
Hey Guys, my new 2011 F350 starts up in the morning goes to fast idle for about 15 min and that then that is it. The thing slows back down to normal idle speed and stays there for the day. Engine temp is ice cold and won't warm up. Anyone else have an issue like this? -33C outside temp and the rad covered over.
Thanks
11 F350 4X4 6.7L Black CCSB FX4
11 F350 4X4 6.7L Platinum CCSB FX4
10 F350 4X4 6.4L Cabella's CCSB FX4
08 F350 4X4 6.4L Lariat CCSB Blue FX4
08 VW Touareg V10 TDI
4mcntrls is offline
post #2 of 8 (permalink) Old 01-19-2011, 02:59 AM
nitrogen's Avatar
the primary factor for the fast idle has been the oil temp although other thing play into it as well. once it decides its not frozen solid it slows down. i think the boys have figured out how to jimmy it to have a fast idle whenever you want it. since i am still in 6.0 country i havent looked at the details myself.
Canadian Club #31
nitrogen is offline
post #3 of 8 (permalink) Old 01-21-2011, 12:23 AM
Loves Jet Noise
NoWake200's Avatar
Send a message via Yahoo to NoWake200
From what I have read it is as simple as installing a resistor. I am planning on added it when it gets a little warmer.
TWA
2011 F-350 Lariat, 6.7 PowerStroke, Crew Cab, Short Bed, White with 20" Wheels.
NoWake200 is offline
post #4 of 8 (permalink) Old 01-21-2011, 02:34 AM
Jcard's Avatar
I tried to connect my pto idle to my #4 upfitter switch, like I had it on my 08 but no sucess. I even went off the ford upfit wiring diagram.
Current trucks.
2011 f350 dually, cab/chassis, 4x4, std cab, 84" cab to axle.
2011 f550 4x4 crew 84" cab to axle. Ranchand in front, tailroll in back, winch in the middle.
2011 f350 swr short crew lariet.
2008 dodge 5500 4x4.
2012 dodge dually crew.
Jcard is offline
post #5 of 8 (permalink) Old 01-21-2011, 03:19 AM
i heard you need a reho stat or risister installed to make it work on the 11's like you could do to the 03-10's
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #6 of 8 (permalink) Old 01-26-2011, 11:57 PM
GrmReaper's Avatar
i have it wired, it works.
cant remember the diagram. think my resistor is a 22k and makes for 1200 rpm.
ill find the link for it in a second
here ya go. http://www.thedieselstop.com/forums/...ctures-268611/
i wired mine with a 20k ohm resistor to get 1200 rpm
2011 F350, CC, LB, Lariat, 4x4, FX4, Tuxedo Black, 6.7L
2.5" Leveling kit
18x9 Fuel Hostage Black and Brushed
35x12.5 Dunlop Rover M/T Maxx Traction
GrmReaper is offline
post #7 of 8 (permalink) Old 01-29-2011, 03:05 AM
Duramax/Allison
747MD11's Avatar
on the chevy's there is a way to turn on and off the fast idle feature in the DIC (computer)... I'm sure the Ford has the same deal with that fancy color computer... check your menus.
2011 Duramax 2500HD LTZ
100% US Made of mostly US parts with some parts from Germany and Japan.
Video of my truck: Youtube Video
2005 E320 CDI
2008 BMW X5 4.8i
747MD11 is offline
post #8 of 8 (permalink) Old 01-29-2011, 04:15 PM
Mafia member #6
Rutcutter's Avatar
STEADY PRESET RPM:
http://i144.photobucket.com/albums/r...ireFINAL-1.jpg
Here are the resistor options. FWIW my local Ford Diesel Tech recommends 1200 RPM under no load. So that would be a 20K resistor. I used a .5 Watt Resistor in my testing.
http://i144.photobucket.com/albums/r.../Resistors.jpg
VARIABLE RPM CONTROL:
http://i144.photobucket.com/albums/r...entiometer.jpg
This is the potentiometer I used:
http://i144.photobucket.com/albums/r...0/IMG_7887.jpg
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
2011 LML cold start (15 F) 747MD11 Duramax 2011+ (LML) 12 01-17-2011 01:28 PM
No high Idle when cold Harry Nadz 1994-2003 7.3L Power Stroke 2 11-07-2010 01:00 PM
Need Help with 2011 High Idle JohnD333 2011+ 6.7L Power Stroke Diesel 14 05-17-2010 12:06 AM
Rough Idle When Cold 06F450 2003-2007 6.0L Power Stroke 7 11-14-2009 02:48 PM
NO Cold High Idle cumminsdude2001 7.3L and 6.9 IDI (Pre 1994) 7 03-15-2009 12:42 AM
