2011 PSD 6.7 Tapping noise after oil change - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bowhntr, this thread has received 25 replies and been viewed 14801 times.
post #1 of 26 (permalink) Old 02-09-2011, 09:00 PM Thread Starter
Had my truck in for its first oil change. Right after that I started hearing a tapping noise under the front drivers side wheel well. Called the dealer and he faxed me a TSB 10-19-2. Issue: Some 6.7 diesel equiped vehicles may exibit a ticking noise after an oil change. It is refered to as Typewriter Noise because of its random thyping sounds on a mechanical typewriter. Customers may report that when near a building or drive through window that this noise can be heard inside the cab. Service Info: Basically normal condition. No action is to be taken and is not Warrantable. Do not change the viscosity of the reccommended oil as this will not fix the noise.
bowhntr is offline
post #2 of 26 (permalink) Old 02-10-2011, 02:32 AM
The 6.4's had this same issue
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #3 of 26 (permalink) Old 02-16-2011, 02:34 PM
11350KINGRANCH's Avatar
It happened to a friends 6.7 as well. I have not experienced it on mine.
2011 F350 KING RANCH SB SRW FX4 IN BRONZE
6 90W STROBES,2 BLUE LED PODS IN GRILL, POLICE SIREN, VIAIR CONSTANT DUTY AIR SYSTEM IN TOOL BOX, 55w HIDS IN HEADLIGHTS, 35w HIDS IN FOGS
2" LEVELING KIT, 285/65/20 BFG A/T KO TIRES
TITAN FUEL TANK.
FOR SALE: KING RANCH FRONT BUMPER, CHROME SIDE STEPS
11350KINGRANCH is offline
post #4 of 26 (permalink) Old 03-06-2011, 12:05 AM
Gearloose1's Avatar
Had it happen with the 6.0 under extreme cold conditions with 5w-40 synth.
I would guess some sort of a clearance / oil pressure issue until it reaches operating temperature.
Gearloose1 is offline
post #5 of 26 (permalink) Old 03-14-2011, 03:48 PM
dieselboy740's Avatar
Mine has this after the first oil change. There is no way it's normal. I've got 8000mi on it now and it's getting louder. I'll run it till it pops like they told me to.
95 bronco 94 idi turbo, intercooled, maxed out pump, custom compressor, custom downpipe, 12* timing, oba, d60, 10.25, e-locker, exocage, zf5, etc.....
2011 f-550 6.7L 12ft service box, shop on wheels
80 merc 300sd, hx35, intercooled, straightpiped, modified pump, egr delete, etc.....
dieselboy740 is offline
post #6 of 26 (permalink) Old 03-14-2011, 04:21 PM
Gearloose1's Avatar
What they are telling you to do is to get the air out of the oil system....
By running it hard a few times.
post #7 of 26 (permalink) Old 03-14-2011, 06:50 PM
I run it hard everyday. It's made the noise since the first service @ 4000 mi. I just had the second service done on Tuesday last week.
I'm having this truck dealer serviced so all records are in order and they cannot try funny crap on the warranty.
I actually notice the noise is louder on hot start and after running on the freeway for a bit. It's really annoying that they won't do anything about it.
post #8 of 26 (permalink) Old 03-14-2011, 07:15 PM
Gearloose1's Avatar
OK, what oils are you using?
post #9 of 26 (permalink) Old 03-14-2011, 07:31 PM Thread Starter
Mine was serviced at the dealership so I guess motocraft. Whatever they put in it. I get free tires if I have the truck serviced there.
bowhntr is offline
post #10 of 26 (permalink) Old 03-14-2011, 07:55 PM
Gearloose1's Avatar
Go back to your invoice, check that the proper grade / viscosity of oil was used.
Lets eliminate simple suspects first.
Motorcraft what?
Was it HD Diesel oil?
Was it 15w-40?
Can you rule out some klutz putting 5w-20 gasser oil in?
I was ready to pull the trigger on 2011. Wasn't expecting huge change in GM payload!? kdubinwa 2011+ 6.7L Power Stroke Diesel 45 03-10-2010 01:10 PM
07 5.9l tapping noise goodriddance 5.9L Cummins (2003-2007.5) 7 12-22-2009 02:27 AM
6.4 tapping noise jeff gardner 2008-2010 6.4L Power Stroke 2 03-13-2009 03:31 AM
tapping power wire mastercaster 6.7L Cummins (2007.5-2011) 1 10-29-2007 05:00 AM
Ticking/tapping noise serialkiller 1994-2003 7.3L Power Stroke 3 11-06-2005 02:43 PM
