2011 truck question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Mike687, this thread has received 6 replies and been viewed 1791 times.
post #1 of 7 (permalink) Old 04-03-2011, 08:01 PM Thread Starter
2011 truck question
Hello I'm not sure if i'm posting this in the right section but I have heard that you cant put exhaust stacks or the saddle-like aluminum fuel tanks (like they use on tractor trailers) on the 2011 trucks and was wondering if that is true? Any info would be great. Thank you
Mike
Mike687 is offline
post #2 of 7 (permalink) Old 04-04-2011, 01:41 PM
Tebow-in'...
mudguppy's Avatar
i'm confused. what pickup trucks can you put saddle tanks on?
Travis
2011 F350 SRW CC/SB 4x4 Lariat 6.7 PSD Dark Pearl Metalic
1974 Bob'd Deuce on 16.00-20 XZLs, locked front and rear, hydro steering, front and rear winches, 5.9CTD/nv4500, hydro-boosted disc brakes
Member since Jul 05, Dually Club Member #63, American Club Member #42, FOSP Member #8
mudguppy is offline
post #3 of 7 (permalink) Old 04-08-2011, 02:13 AM
I'm so confused
marcomjl is offline
post #4 of 7 (permalink) Old 04-10-2011, 01:50 AM
I think exhaust stacks would eliminate the emissions parts on the exhaust system and bring you out of compliance with federal/state law (if you care). The tank issue can be resolved by a replacement tank. I installed a 50 gallon Transfer Flow tank. It cost about $800, but my range is now over 650 miles unloaded and over 450 loaded with a 3000# camper while towing a Jeep.
Rixtruck is offline
post #5 of 7 (permalink) Old 04-12-2011, 05:17 PM
Let it all Ride
Eazydeezy's Avatar
I have never seen a sadle type fuel tank on a pickup truck.
Dominic
Eazydeezy is offline
post #6 of 7 (permalink) Old 04-12-2011, 11:33 PM
Old Fart
dbennett48's Avatar
I h
dbennett48 is offline
post #7 of 7 (permalink) Old 04-14-2011, 03:55 PM
Man. Trans 2wd Enthusiast
saddle tanks only look cool if you have a chassis cab, with a sleeper, no bed, and a fifth wheel plate or gooseneck ball on the bare frame. otherwise, saddle tanks look like utter **** IMHO. especially under flatbeds.
now if you are talking putting a semi truck 150 gallon or so tank into the bed, I would say save the bed space and get a titan tank. as far as the stacks...do what you want. I hate them, but others think they are ******, so to each their own.
99 Chev C3500 6.5L NV4500 14 bolt 2wd 4.10 130K White Ext, Gray Int. RC159.5" WB DRW Chassis Cab with utility box Runs Great, building up
96 GMC C2500HD 6.5L NV4500 14 bolt 2wd 3.73 240K White Ext, Blue Int. ECLB 155.5"WB SRW Pickup runs bad, getting motor right now
95 GMC C2500HD 6.5L NV4500 14 bolt 2wd 4.10 135K White Ext, Grey Int. RC 131.5"WB SRW Pickup with utility box runs strong, yet huffs on 1 hole
95 Chev C3500HD 6.5L NV4500 D80 2wd 5.13 132K White Ext, Grey Int. RC 159.5"WB DRW Chassis Cab with flatbed bad heads, needs motor re-do
94 GMC C2500HD 6.5L 4L80E 14 bolt 2wd 3.73 300K White Ext, Blue Int. Suburban needs engine
91 GMC C1500, 6.2L SM465 10 bolt 2wd 3.42 59K Red Ext, Red Int. RCLB 131.5"WB SRW Pickup needs injectors, oil cooler lines
91 Chev C1500 4.3L 5LM60 10 bolt 2wd 3.42 ??K White Ext, Red Int. RCLB 131.5"WB SRW Pickup needs...alot
Dad's:
98 GMC C3500 5.7L Vortec NV4500 208K down right now, needs head gaskets (dex cool claims another set! )
92 GMC C3500HD 6.5L Turbo NV4500 160K needs exhaust system and oil cooler lines
93 GMC C3500HD 6.5L Turbo 4L80E 260K had a crate 6.5L sometime
All above are 159.5" C&C, 10'-12' flatbed, Summit white, RC, SL trim, 2wd
96 GMC C2500HD SL ECLB 6.5L 5spd 2wd. 215K (sold to dad, ran good for a bit, started missing at idle, had blowby since purchase
84 Pete 362 COE, 300 BCIII RTOO 13 spd Fuller (3 OD ratios, hard to find) Single axle tractor, air seats, cab, suspension, OEM twin 200 gallon tanks.
74 Pete 352 COE, cat, 13spd TS, B&H grain truck
90 Marmon 57P long hood conventional, 60"flattop, 12.7L60 Series, 13 spd fuller, TS tractor
76 Marmon COE 8V92T 13spd fuller, TS B&H grain truck
95 IHC 9600 COE M11, 10 spd, SA tractor.
GM Guy is offline
2011 Ford F-550 Super Duty First Responder Truck Rutcutter 2011+ 6.7L Power Stroke Diesel 5 01-11-2010 12:00 AM
Ford claims question 2011 truck todt061458 General Dodge Discussion 3 12-29-2009 11:45 PM
2011 F450 suprise appearance at Truck pull VIDEO mustang mike 93 2011+ 6.7L Power Stroke Diesel 16 11-08-2009 01:18 AM
question about my new truck BIG BLACK DUALLY The Parking Lot 5 04-15-2009 04:25 AM
Truck Question codyr6 The Parking Lot 5 02-20-2008 06:14 AM
