2011 F250 Lariat with no upfitter switch... can I install myself - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Uncle Dimmy, this thread has received 8 replies and been viewed 6696 times.
post #1 of 9 (permalink) Old 05-21-2012, 04:14 PM Thread Starter
Uncle Dimmy's Avatar
I am looking at possibly buying a 2011 F250 4x4 Lariat, has ever option but no up fitter switches. This is one of the main things I really need. The truck is at a good deal for me, but I need to know if I can, how much am I looking at to install up fitter switches on this truck. If it's only a few hundred bucks, I'm going to pull the trigger. If it's too much, it's not worth going through all of this.
Mine:
2010 Ford F250, CC, SWB, 4x4 Off-Road, Lariat, Black w/Ebony interior, loaded with every single option.
2010 Toyota Tundra Crew Max, 4x4, Limited, White w/Red Rock Leather Interior, loaded with every option other than the Sun Roof.
Hers:
2008 Toyota Sequioa Platinum..... nuff said, White w/Tan leather.
Uncle Dimmy is offline
post #2 of 9 (permalink) Old 05-21-2012, 11:47 PM
GUTTS's Avatar
On the older trucks it is prewired so it is just plug and play as far as I know
GUTTS is offline
post #3 of 9 (permalink) Old 05-22-2012, 10:45 PM
It's about $100ish if I remember. Easy install. Plugs in under the dash. Just remove the coin insert and put up fitters in.
Pm me for instructions and the guy to go through for best prices...
-Jay-
- www.TheBlinkProject.com -
Automotive Reviews and Install videos
'11 6.2L F250 Super Duty -- Crew
RollBak cover - Recon Smoked all around - 37" Toyo MT - 20" BMF Novakane - 6" Pure Performance Lift - Train Horns - Bulldog Lighting
SlickYamaha is offline
post #4 of 9 (permalink) Old 05-23-2012, 04:30 AM
here
John Deere's Avatar
Haven't seen you around for awhile Jim. How's life treating you?
Brady
2002 Ford F350 Crew cab, 4x4, XLT, 7.3 Powerstroke Diesel, AIS filter kit, 6 speed, Ali-arc aluminum frontend replacement
88' Ford F250, 4x4, 7.3L Diesel, Banks Sidewinder, 5 spd, flatbed, feed-truck
78' Ford F250 supercab, Dana 60's, C-6 and a slightly modified 400m- dead, soon to be a 460. 6" skyjacker lift with 38.5 boggers, play-truck
John Deere is offline
post #5 of 9 (permalink) Old 05-29-2012, 09:14 PM
Upfitter Switches
I found the OEM Upfitter switch kit on E-Bay and it came complete with the wiring harness for around 150 bananas. It was real easy to install but you will have to hunt around for the harness connector. The bracket that came with my kit didn't seem to be the right one but a few nylon tie straps secured the relay block under the dash real nice. All in all it was worth the installation since I no longer have to hunt around for an auxilliary hot lead.
Starwarrior is offline
post #6 of 9 (permalink) Old 05-30-2012, 12:41 AM
GUTTS's Avatar
Nice
GUTTS is offline
post #7 of 9 (permalink) Old 05-31-2012, 05:31 AM
ADMIN/MAFIA
neeltburn's Avatar
Can these switches be used in anything other than a ford if I take the time to wire them in?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #8 of 9 (permalink) Old 05-31-2012, 05:37 AM
ADMIN/MAFIA
neeltburn's Avatar
Could not find them on Ebay.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #9 of 9 (permalink) Old 05-31-2012, 04:32 PM
Let it all Ride
Eazydeezy's Avatar
Neel, yes you can. Like you said, you would just need to take the time to hard wire.
Dominic
Eazydeezy is offline
High Idle with Upfitter Switch Johnathan 2003-2007 6.0L Power Stroke 1 01-04-2008 01:10 AM
upfitter switch wiring imported_JDeere5105 2003-2007 6.0L Power Stroke 9 09-09-2007 07:12 AM
Upfitter Switch Leads Trbotime 2003-2007 6.0L Power Stroke 14 02-10-2007 04:09 AM
Hooking engine fan to upfitter switch Rutcutter 2003-2007 6.0L Power Stroke 24 08-03-2006 09:31 PM
Upfitter Switch Install NMU98 Ford - Modification instructions, Product installs and Tech Articles 2 05-19-2005 12:01 PM
