Urea Injection System - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jeremiah, this thread has received 51 replies and been viewed 33860 times.
post #1 of 52 (permalink) Old 09-30-2009, 03:35 AM Thread Starter
Banned
Question Urea Injection System
How exactly does this work and how often do you have to refill it? Anyone know if there are places to buy the fluid now? Any prices on this stuff?
( on edit, looks like I just found out how much it cost in another thread, $2.50 per gallon - seem right? ) Just trying to see if this truck will be cost effective...
Jeremiah is offline
post #2 of 52 (permalink) Old 09-30-2009, 06:43 AM
Superdutytd's Avatar
Images: 3
I think it holds like 5-7 gallons and has to be refilled once every like 5k miles. Spending a few bucks for every 1000 miles driven isn't a big deal to me?
2008 Red CCSB 6.4 Auto Lariat.
Stock 20's wrapped in 35x12.50R20 Toyo MT's, 3.73 gears, Nav, Backup Cam, Tailgate step, Upfitters, etc.
Mods: AFE Intake, Line-X, 20% Tint, Clear Bra, Husky Mats, Smoked Recon Mirror markers/3rd brake light, Bushwacker Pocket style flares w/ mud flaps + an aluminum Rapid Hitch (one of the best investments!)
Feel free to PM with any questions about any of my mods.
SRW Club #55
American Club #55
Last road trip-567 miles @ 20.7 mpg @ 67mpg average speed.
Superdutytd is offline
post #3 of 52 (permalink) Old 09-30-2009, 08:12 AM
6.7L Man Van
-lenny-'s Avatar
I know you can buy it from any Fleetguard dealer, they call it Diesel Exhaust Fluid. 1, 2.5 or 5 gallon jugs. I would think that should keep you going for a while. I'm interested to see how this set up works. Also if it would be any harder to tamper with?
08 MC 3500 68RFE
Mostly Stock
-lenny- is offline
post #4 of 52 (permalink) Old 09-30-2009, 11:24 AM
Got Torque?
ralphinnj's Avatar
Images: 80
To understand how DEF works, you need to understand the idea behind SCR. SCR is a technology that uses a urea based diesel exhaust fluid (DEF) and a catalytic converter (just like the old days) to significantly reduce oxides of nitrogen (NOx) emissions. SCR stands for selective catalytic reduction.
The only purpose of the SCR system is to reduce levels of NOx being pushed out of your tailpipe. DEF is nothing more than a 32.5% w/w solution of urea. Urea is a chemical made in massive quantities for the fertilizer industry, but it is also made every day by each of you. We excrete about an ounce of the stuff (pure urea) every day in our urine. It is a by-product of cell metabolism, so if you sampled any part of your body, you would detect some urea.
Here is how it works. Small quantities of diesel exhaust fluid (DEF) are injected into the exhaust upstream of a catalyst, where it (the urea and water) vaporizes and decomposes to form ammonia and carbon dioxide (the water just goea along for the ride; the urea is the workhorse here). The ammonia (NH3) is the desired product which in conjunction to the SCR catalyst, converts the NOx to harmless nitrogen (N2) and water (H2O). Pretty cool, piss turns NOx into harmless stuff!
Black 2003 F350 Dually, Nothing Stock
Other Rides:
Black 2006 300C SRT8
Black 2012 CTS-V (630HP)
Black 2008 Mercedes E550
ralphinnj is offline
The Following 11 Users Say Thank You to ralphinnj For this addition to TDG:
allstarsixo (09-30-2009), Eric.Larson (01-13-2010), fordt (09-30-2009), GOS (10-27-2009), groceryman (10-01-2009), jdydiesel (09-30-2009), Jeffybuilt (09-30-2009), Jeremiah (09-30-2009), Rcannon (09-30-2009), TOWERMAN (10-11-2009), ZeroOne (10-26-2009)
post #5 of 52 (permalink) Old 09-30-2009, 11:26 AM
Got Torque?
ralphinnj's Avatar
Images: 80
Oh, if you can buy pure urea cheaply, you could make your own DEF. Just make a 32.5% solution, it is simple.
Other Rides:
post #6 of 52 (permalink) Old 09-30-2009, 03:12 PM
Got Torque?
ralphinnj's Avatar
Images: 80
One last thing....if the DEF is really just urea and water, then it is an EXCELLENT skin softener. I work in the dermatology field and we use 30-50% creams and lotions for thick skin. It is great in one of those sonic bath contraptions. You put a gallon in and heat it a little (like hot tub temp), and then immerse your feet for 20 min. It softens dry skin by bonding water. It also has some other interesting properties:
-antibacterial - it will kill bacteria rapidly on contact
-antifungal - it will kill this too, but if you have the fungus under your toe nails, it takes time.
-deoderant - if you have smelly feet, this will cure them if you soak regularly.
I know it sounds weird that a chemical you are using in your truck can be used medicinally, but it is totally true! Here is a link with more on urea:
http://health.centreforce.com/health/urea.html
and below is an excerpt from that.
Medical researchers have also proven that urea is one of the best and only medically proven, effective skin moisturisers in the world. In many years of laboratory studies, researchers discovered that, unlike just about all other types of oil-based moisturisers that simply sit on the top layers of the skin and do nothing to improve water retention within skin cells (which gives skin its elasticity and wrinkle-free appearance), urea actually increases the water-binding capacity of the skin by opening skin layers for hydrogen bonding, which then attracts moisture to dry skin cells.
Now, I'm not saying to go and use DEF for skin disorders.....but you could, and it would work! (assuming no other ingredients are in there but water and urea). My main point here is that DEF is a very natural product, not a dangerous chemical or something mysterious.
Other Rides:
The Following 13 Users Say Thank You to ralphinnj For this addition to TDG:
allstarsixo (09-30-2009), desertghosts (10-07-2009), Eric.Larson (01-13-2010), fordt (09-30-2009), groceryman (10-01-2009), jdydiesel (09-30-2009), Jeffybuilt (09-30-2009), Jeremiah (09-30-2009), Rcannon (09-30-2009), todt061458 (10-03-2009), uga33 (10-21-2009), woodsman (09-30-2009), ZeroOne (10-26-2009)
post #7 of 52 (permalink) Old 09-30-2009, 03:16 PM
Administrator
fordt's Avatar
Images: 5
Thanks Ralph, that's pretty damn interesting!
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #8 of 52 (permalink) Old 09-30-2009, 03:31 PM
greggara is offline
post #9 of 52 (permalink) Old 09-30-2009, 04:17 PM Thread Starter
Banned
yes, i agree that really makes it seem better...:
Jeremiah is offline
post #10 of 52 (permalink) Old 09-30-2009, 07:15 PM
Dually Club #3
jdydiesel's Avatar
So what will prevent someone from just putting water in the tank? Are there sensors that can sedtect the % of urea in water? Also does this get rid of the DPF or are those still in play?
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
Industrial Injection 62/70 06f250sd Supporting Vendors Forum 5 04-01-2009 09:48 AM
2011 Scorpion on UREA???? richm01 Mid Atlantic 2 02-17-2009 03:04 AM
Industrial Injection PS 62 thekidfan Whats Been Sold 0 04-30-2008 06:10 AM
Injection Pump bigriggin it 7.3L and 6.9 IDI (Pre 1994) 2 09-08-2007 01:18 PM
ICP (Injection Control Pressure) & IPW (Injection Pulse Widths) hhrecovery 2003-2007 6.0L Power Stroke 4 08-04-2006 07:04 PM
